pistonse30
    Sent from my SCH-I535 using Tapatalk 2
        The guy that is building this from the ground up is going to do my exhaust, BOV bung and maybe a custom catch can.
        Getting really close guys!
        -Wiring harness is sorted and 99% installed.
        -The intercooler mount needs some tweaking.
        -Monday I'm getting the rest of my parts for the car to run. A couple new sensors and a CSB (I forsee an aluminum drive shaft in my future).
        -Vacuum lines for BOV, waste gate and boost gauge have to be routed.
        -And some other small things need to be done.
        Yahoo!!
            those rear tires on the tube-frame car are absurd!
            Did you cut out any of the rear 1/4 panel for the flare fitment?
            I may be doing this as well
              I cut, pop riveted and glued them. Then sprayed rubberized coating all over. 8abe2y4y.jpg
              • E36M3215E
                E36M3215E
                E36M3215
                Looking good, can't wait to see this roll up to the shop instead of the e46 lol
                  Soon! After I get back from Denver it should be done in a couple of days.
                  Meanwhile, while I'm drive back from Boulder I see these bro braaahs. Got the bimmer thoughts boiling! #mpower?
                      holy balls.
                      one, semi-massive update.
                      I like it, nice work
                        holy balls.
                        Thanks! I've been trying to do some work! Can't wait to have this buttoned up. The winter clock is ticking.
                            Did you make those handles? I have seen a set like that before and theyre pretty rad.
                              @earl Condorspeedshop made them. The would be easy to make with a drill press.
                                    I have done some more work after this pic.
                                    Passenger side intercooler/pre-turbo piping tightened down. The driver side piping is cut and ready to be clamped down. First I need to get some vacuum lines/hardware in order before that is finished as well as some cutting to the body(Should be done tomorrow).
                                    The vac/boost, AF ratio and oil pressure gauges need to be wired up. They're all are mounted. Should take 2 hours max...>_>
                                    Tomorrow my daily travels will take me to Concours for some coolant and an o-ring for the oil level sensor. Water wetter is waiting!
                                    Bleed the brakes and slave.
                                    I need to find an e30 driveshaft with good u-joints. My rear joint is junk. Friday I might order a one piece aluminum shaft. Other than that the suspension is ready. Also, solid transmission mounts are in my head.
                                    My 3in stainless steal stock is in my exhaust guy's possession. $500 labor for the full exhaust! I'll see how long I can take the shorty exhaust coming out of the hood before I drive it out to dude's shop for the full thing.
                                    As for boost, I'm running my smallest spring, 2.9psi, while I break in my motor for 1000 miles. I'll try not to see any boost during that time.
                                    CCV will be ran off of the soon to be 3/4in NPT fitting on the valve cover->catch can-> exhaust to pull vacuum.
                                    Maybe start it tomorrow night?? #shootingforthemoon
                                    Tic toc.
                                      Holy crap that exhaust is going to be nuts, awesome build by the way
                                        This thing is just frightening!!! But sooooo sweet!
                                          Thanks!! I hope it works!
                                          The monster should awaken tomorrow if all goes to plan.
