  3. BMW Discussion
  4. Mitch's S52 M318 Swap
318 m3 swap eng
44 Posts 6 Posters 772 Views 1 Watching
  • M318M
    M318M
    M318
    I was told by Automotive Specialists that they couldn't turn my flywheel for my S52 because it was two piece. They told me to clean it up with a mild abrasive on a rotary tool. So I did that. Any one have any other Ideas before I put it in?
    Here it is "cleaned up" (I try to be a perfectionist)
      They are correct in that you cannot turn the dual mass flywheels. Your mating surface looks fine to me.
      Good looking build so far!
        I know a shop that can turn dual mass flywheels but it is far more expensive than turning a single mass.
        • M318M
          M318M
          M318
          Like how much? Also do you think I need to? I am a perfectionist though I wont be happy with any chattering. Also I got a brand new Sachs clutch kit.
          • M318M
            M318M
            M318
            post-3321-0-32898100-1376784022thumb.jp
            My poor S52. Here she hangs because I don't have that retarded thin metal shield.
              http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=11-14-1-734-019-BOE&catalog_description=&Automatic%2520Transmission%2520Cover%2520Plate%252C%2520BMW%2520E%2533%2536%2520%2533%2520Series%252C%2520All%2520%2520
              $13 from pelican.  Or somebody come trade him one for a fancy oil filter cap.
              • M318M
                M318M
                M318
                SHIT all i can find is the automatic transmission cover plate! Is the Manual one the same do you think? I actually need a S52 cover plate though not an m4x. Or any 6 cylinder. I dont see why the manual and auto would be different cover plates... they both bolt up the same way.
                  Same part, look at more applications on pelican, it shows manual/auto m50/52, s50/52.  Not sure why the description on realoem and pelican say "auto trans cover plate".
                  • M318M
                    M318M
                    M318
                    Thanks!
                    • M318M
                      M318M
                      M318
                      • M318M
                        M318M
                        M318
                        Got the flywheel on with the clutch (put on normal style).
                          So this not a dual mass flywheel I assume?  What is the weight on it compared to stock?
                          • M318M
                            M318M
                            M318
                            Single mass. It is 16 lbs compared to 25 lbs for the stock flywheel.
                            • M318M
                              M318M
                              M318
                              MY BAD. I ordered the OEM M3 non sprung hub clutch with a single mass flywheel... I ain't down with chattering so I returned it... Now I am waiting on this...
                              KF776-01.jpg?1329350881
                              That dere is the E39 M5 Clutch and pressure plate. Looks like i am building it right. Probably wont even start.... anyway I spent way more than I planned but oh well whats money when it comes to your BMW!
                                Exactly.
                                • M318M
                                  M318M
                                  M318
                                  Did you know that on bimmerfest.com they were telling people to put their clutch disk in backwards to get rid of chattering. What do you think about that? Is it COMPLETELY ridiculous?
                                    As long as you install with a left handed wrench it should be fine.
                                    • M318M
                                      M318M
                                      M318
                                      so many projects, so little time.
                                      16335369large.jpg?v=1
                                      16335370large.jpg?v=1
                                        I know how that goes!
                                          It won't work lol. The flywheel bolts will run into the clutch disk.
