  3. BMW Discussion
  4. Mitch's S52 M318 Swap
318 m3 swap eng
44 Posts 6 Posters 767 Views 1 Watching
  • M318M
    M318M
    M318
    READY TO GO... just waiting on my motor mounts now.
    the money shot!
    • M318M
      M318M
      M318
      Does anyone know what is going to happen once I wire this up with the obd2 wiring into my obd2 car? I have the ews2 system in my car and I doubt it is going to start because the chip in my key is different than what the DME is looking for....
        Welcome, looks like a fun project.
        • M318M
          M318M
          M318
          M3 LSD Diff. Dude, What do I put into my diff?
          • M318M
            M318M
            M318
            Custom Oil Filter cover. Let me know if u need one. $40 or $30 with core.
              Royal Purple goes in the dif.  Get it at Napa or amazon.
              http://royalpurpleconsumer.com/product-categories/automotive/#!max-gear
              Did you paint and then machine the oil filter cap, or just paint and then sand off the top of the ribs?  Looks cool either way
              • M318M
                M318M
                M318
                Of course it was crinkle coated then machined on a lathe 2 days after it was dry. (that stuff takes forever to dry) But once its dry it is hard as a rock. I used the same paint on my M44 Valve cover and it was great.
                • M318M
                  M318M
                  M318
                  I was told by Automotive Specialists that they couldn't turn my flywheel for my S52 because it was two piece. They told me to clean it up with a mild abrasive on a rotary tool. So I did that. Any one have any other Ideas before I put it in?
                  Here it is "cleaned up" (I try to be a perfectionist)
                    They are correct in that you cannot turn the dual mass flywheels. Your mating surface looks fine to me.
                    Good looking build so far!
                      I know a shop that can turn dual mass flywheels but it is far more expensive than turning a single mass.
                      • M318M
                        M318M
                        M318
                        Like how much? Also do you think I need to? I am a perfectionist though I wont be happy with any chattering. Also I got a brand new Sachs clutch kit.
                        • M318M
                          M318M
                          M318
                          post-3321-0-32898100-1376784022thumb.jp
                          My poor S52. Here she hangs because I don't have that retarded thin metal shield.
                            http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=11-14-1-734-019-BOE&catalog_description=&Automatic%2520Transmission%2520Cover%2520Plate%252C%2520BMW%2520E%2533%2536%2520%2533%2520Series%252C%2520All%2520%2520
                            $13 from pelican.  Or somebody come trade him one for a fancy oil filter cap.
                            • M318M
                              M318M
                              M318
                              SHIT all i can find is the automatic transmission cover plate! Is the Manual one the same do you think? I actually need a S52 cover plate though not an m4x. Or any 6 cylinder. I dont see why the manual and auto would be different cover plates... they both bolt up the same way.
                                Same part, look at more applications on pelican, it shows manual/auto m50/52, s50/52.  Not sure why the description on realoem and pelican say "auto trans cover plate".
                                • M318M
                                  M318M
                                  M318
                                  Thanks!
                                  • M318M
                                    M318M
                                    M318
                                    • M318M
                                      M318M
                                      M318
                                      Got the flywheel on with the clutch (put on normal style).
                                        So this not a dual mass flywheel I assume?  What is the weight on it compared to stock?
                                        • M318M
                                          M318M
                                          M318
                                          Single mass. It is 16 lbs compared to 25 lbs for the stock flywheel.
