G35 coupe or e46 330ci
barf @ the cadillac and the impala
I like the newer G35's, drive nicely, comfortable and sound good but its still not a bimmer!
+1. It sure isn't!!
Lmao yeah I know it ain't
I'd get that and keeps bmw now
That's the plan man
Lmao I ain't gonna do the wheels or camber like that lmao that's Asian still shits right there
I have no clue what your last half of that sentence even means. Lol The car is VIP inspired
Code P0011 is a common issue and is fixed temporarily with a vvt selonid or cam position sensor but always ends up coming back being the front timing cover gasket breaks apart over time and falls in to the oil pan, gasket material then gets sucked up to the heads blocking the passages to the vvt if you have owned the car since 35,000 it more than likely has already been fixed
timing chains stretch
Weak blocks if oil changes weren't done on time they will throw rods
Head gaskets go
Front diffs blow up on awd, almost always pinon bearings let loose
Rear main seals leak like a GM truck
Radiator leaks in to trans fluid ( automatic only) more radiator issue but does happen
"Swirl screw" drops in to the combustion camber
You have to remember the VQ35 is a motor used in tons of nissan cars so some of these issues are more prone to other models such as a maxima or 3.5 Altima or a murano or quest.
Its still a VQ35 engine if its an issue it will happen unless addressed
I might just say screw both and just do the 04-06 Pontiac gto 6.0 lol
Really thinkn bout it Ryan
