<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[G35 coupe or e46 330ci]]></title><description><![CDATA[<p dir="auto">I'm trying to figure out my next car</p>
<p dir="auto">I love bmw</p>
<p dir="auto">But the g35 stock is a pretty dope car too</p>
<p dir="auto">What are everybody thoughts</p>
]]></description><link>https://wibimmers.com/topic/1855/g35-coupe-or-e46-330ci</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 06:36:44 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/1855.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 08 Sep 2013 01:07:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to G35 coupe or e46 330ci on Thu, 12 Sep 2013 04:40:02 GMT]]></title><description><![CDATA[<p dir="auto">Really thinkn bout it Ryan</p>
]]></description><link>https://wibimmers.com/post/27875</link><guid isPermaLink="true">https://wibimmers.com/post/27875</guid><dc:creator><![CDATA[SubmuzikBoss]]></dc:creator><pubDate>Thu, 12 Sep 2013 04:40:02 GMT</pubDate></item><item><title><![CDATA[Reply to G35 coupe or e46 330ci on Thu, 12 Sep 2013 03:32:34 GMT]]></title><description><![CDATA[<p dir="auto">The GTO I drove was badass, and they aren't all that bad looking either.</p>
]]></description><link>https://wibimmers.com/post/27870</link><guid isPermaLink="true">https://wibimmers.com/post/27870</guid><dc:creator><![CDATA[Ryan...]]></dc:creator><pubDate>Thu, 12 Sep 2013 03:32:34 GMT</pubDate></item><item><title><![CDATA[Reply to G35 coupe or e46 330ci on Thu, 12 Sep 2013 02:07:43 GMT]]></title><description><![CDATA[<p dir="auto">I might just say screw both and just do the 04-06 Pontiac gto 6.0 lol</p>
]]></description><link>https://wibimmers.com/post/27864</link><guid isPermaLink="true">https://wibimmers.com/post/27864</guid><dc:creator><![CDATA[SubmuzikBoss]]></dc:creator><pubDate>Thu, 12 Sep 2013 02:07:43 GMT</pubDate></item><item><title><![CDATA[Reply to G35 coupe or e46 330ci on Wed, 11 Sep 2013 23:51:27 GMT]]></title><description><![CDATA[<p dir="auto">Code P0011 is a common issue and is fixed temporarily with a vvt selonid or cam position sensor but always ends up coming back being the front timing cover gasket breaks apart over time and falls in to the oil pan, gasket material then gets sucked up to the heads blocking the passages to the vvt if you have owned the car since 35,000 it more than likely has already been fixed</p>
<p dir="auto">timing chains stretch</p>
<p dir="auto">Weak blocks if oil changes weren't done on time they will throw rods</p>
<p dir="auto">Head gaskets go</p>
<p dir="auto">Front diffs blow up on awd, almost always pinon bearings let loose</p>
<p dir="auto">Rear main seals leak like a GM truck</p>
<p dir="auto">Radiator leaks in to trans fluid ( automatic only) more radiator issue but does happen</p>
<p dir="auto">"Swirl screw" drops in to the combustion camber</p>
<p dir="auto">You have to remember the VQ35 is a motor used in tons of nissan cars so some of these issues are more prone to other models such as a maxima or 3.5 Altima or a murano or quest.</p>
<p dir="auto">Its still a VQ35 engine if its an issue it will happen unless addressed</p>
]]></description><link>https://wibimmers.com/post/27860</link><guid isPermaLink="true">https://wibimmers.com/post/27860</guid><dc:creator><![CDATA[E36M3215]]></dc:creator><pubDate>Wed, 11 Sep 2013 23:51:27 GMT</pubDate></item><item><title><![CDATA[Reply to G35 coupe or e46 330ci on Wed, 11 Sep 2013 14:42:46 GMT]]></title><description><![CDATA[<p dir="auto">I've read the g35 has a very weak chassis.....whatever they changed between it and the 350z was bad.....however they have MUCH nicer door handles.</p>
]]></description><link>https://wibimmers.com/post/27846</link><guid isPermaLink="true">https://wibimmers.com/post/27846</guid><dc:creator><![CDATA[REKIII]]></dc:creator><pubDate>Wed, 11 Sep 2013 14:42:46 GMT</pubDate></item><item><title><![CDATA[Reply to G35 coupe or e46 330ci on Wed, 11 Sep 2013 14:10:51 GMT]]></title><description><![CDATA[<p dir="auto">^^ I'm curious about the drive train issues you've seen, E36M#215.  We own 2 Nissans, a 2005 FX35 and a 2008 EX35.  The FX has 110k miles on it and we've owned it since it had 35k with zero issues.</p>
]]></description><link>https://wibimmers.com/post/27845</link><guid isPermaLink="true">https://wibimmers.com/post/27845</guid><dc:creator><![CDATA[Narcosis]]></dc:creator><pubDate>Wed, 11 Sep 2013 14:10:51 GMT</pubDate></item><item><title><![CDATA[Reply to G35 coupe or e46 330ci on Wed, 11 Sep 2013 01:38:31 GMT]]></title><description><![CDATA[<p dir="auto">E46 M3, faster than a G more driver oriented car than a G oh and not an over priced nissan 350/370z with the same cheap crappy drive train, before I worked at Kummrow I was a nissan tech at amato, they are junk</p>
]]></description><link>https://wibimmers.com/post/27830</link><guid isPermaLink="true">https://wibimmers.com/post/27830</guid><dc:creator><![CDATA[E36M3215]]></dc:creator><pubDate>Wed, 11 Sep 2013 01:38:31 GMT</pubDate></item><item><title><![CDATA[Reply to G35 coupe or e46 330ci on Tue, 10 Sep 2013 22:04:00 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/27820">SubmuzikBoss said:</a></strong></p>
<p dir="auto">Lmao I ain't gonna do the wheels or camber like that lmao that's Asian still shits right there</p>
<p dir="auto">I have no clue what your last half of that sentence even means. Lol The car is VIP inspired</p>
]]></description><link>https://wibimmers.com/post/27821</link><guid isPermaLink="true">https://wibimmers.com/post/27821</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Tue, 10 Sep 2013 22:04:00 GMT</pubDate></item><item><title><![CDATA[Reply to G35 coupe or e46 330ci on Tue, 10 Sep 2013 21:53:33 GMT]]></title><description><![CDATA[<p dir="auto">Lmao I ain't gonna do the wheels or camber like that lmao that's Asian still shits right there</p>
]]></description><link>https://wibimmers.com/post/27820</link><guid isPermaLink="true">https://wibimmers.com/post/27820</guid><dc:creator><![CDATA[SubmuzikBoss]]></dc:creator><pubDate>Tue, 10 Sep 2013 21:53:33 GMT</pubDate></item><item><title><![CDATA[Reply to G35 coupe or e46 330ci on Mon, 09 Sep 2013 14:56:25 GMT]]></title><description><![CDATA[<p dir="auto">I mean if you're set on a G35, it needs to be low=)</p>
<p dir="auto"><img src="http://www.stancenation.com/wp-content/uploads/2013/01/Untitled-31.jpg" alt="Untitled-31.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/post/27745</link><guid isPermaLink="true">https://wibimmers.com/post/27745</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Mon, 09 Sep 2013 14:56:25 GMT</pubDate></item><item><title><![CDATA[Reply to G35 coupe or e46 330ci on Mon, 09 Sep 2013 14:26:25 GMT]]></title><description><![CDATA[<p dir="auto">i would take the 2 door e46 but if it was a manual g coupe vs 4dr automatic e46.... Would end up selling the g coupe after a while anyway.</p>
]]></description><link>https://wibimmers.com/post/27743</link><guid isPermaLink="true">https://wibimmers.com/post/27743</guid><dc:creator><![CDATA[M318]]></dc:creator><pubDate>Mon, 09 Sep 2013 14:26:25 GMT</pubDate></item><item><title><![CDATA[Reply to G35 coupe or e46 330ci on Mon, 09 Sep 2013 03:02:52 GMT]]></title><description><![CDATA[<p dir="auto">That's the plan man</p>
]]></description><link>https://wibimmers.com/post/27739</link><guid isPermaLink="true">https://wibimmers.com/post/27739</guid><dc:creator><![CDATA[SubmuzikBoss]]></dc:creator><pubDate>Mon, 09 Sep 2013 03:02:52 GMT</pubDate></item><item><title><![CDATA[Reply to G35 coupe or e46 330ci on Mon, 09 Sep 2013 01:22:26 GMT]]></title><description><![CDATA[<p dir="auto">They are completely and utterly different. Apples to oranges. Drive both, buy the one you prefer.</p>
]]></description><link>https://wibimmers.com/post/27734</link><guid isPermaLink="true">https://wibimmers.com/post/27734</guid><dc:creator><![CDATA[240sxguy]]></dc:creator><pubDate>Mon, 09 Sep 2013 01:22:26 GMT</pubDate></item><item><title><![CDATA[Reply to G35 coupe or e46 330ci on Mon, 09 Sep 2013 00:56:32 GMT]]></title><description><![CDATA[<p dir="auto">Lmao yeah I know it ain't</p>
<p dir="auto">I'd get that and keeps bmw now</p>
]]></description><link>https://wibimmers.com/post/27733</link><guid isPermaLink="true">https://wibimmers.com/post/27733</guid><dc:creator><![CDATA[SubmuzikBoss]]></dc:creator><pubDate>Mon, 09 Sep 2013 00:56:32 GMT</pubDate></item><item><title><![CDATA[Reply to G35 coupe or e46 330ci on Mon, 09 Sep 2013 00:54:27 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/27715">CYoung said:</a></strong></p>
<p dir="auto">I like the newer G35's, drive nicely, comfortable and sound good but its still not a bimmer!</p>
<p dir="auto">+1. It sure isn't!!</p>
]]></description><link>https://wibimmers.com/post/27732</link><guid isPermaLink="true">https://wibimmers.com/post/27732</guid><dc:creator><![CDATA[michael1972]]></dc:creator><pubDate>Mon, 09 Sep 2013 00:54:27 GMT</pubDate></item><item><title><![CDATA[Reply to G35 coupe or e46 330ci on Sun, 08 Sep 2013 17:34:24 GMT]]></title><description><![CDATA[<p dir="auto">I like the newer G35's, drive nicely, comfortable and sound good but its still not a bimmer!</p>
]]></description><link>https://wibimmers.com/post/27715</link><guid isPermaLink="true">https://wibimmers.com/post/27715</guid><dc:creator><![CDATA[YoungCR]]></dc:creator><pubDate>Sun, 08 Sep 2013 17:34:24 GMT</pubDate></item><item><title><![CDATA[Reply to G35 coupe or e46 330ci on Sun, 08 Sep 2013 17:24:52 GMT]]></title><description><![CDATA[<p dir="auto">barf @ the cadillac and the impala</p>
]]></description><link>https://wibimmers.com/post/27713</link><guid isPermaLink="true">https://wibimmers.com/post/27713</guid><dc:creator><![CDATA[jockhater2]]></dc:creator><pubDate>Sun, 08 Sep 2013 17:24:52 GMT</pubDate></item><item><title><![CDATA[Reply to G35 coupe or e46 330ci on Sun, 08 Sep 2013 15:53:00 GMT]]></title><description><![CDATA[<p dir="auto">I say get a nice e36 and use the money saved to make it how you want=)</p>
]]></description><link>https://wibimmers.com/post/27712</link><guid isPermaLink="true">https://wibimmers.com/post/27712</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Sun, 08 Sep 2013 15:53:00 GMT</pubDate></item><item><title><![CDATA[Reply to G35 coupe or e46 330ci on Sun, 08 Sep 2013 12:06:40 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/27710">Narcosis said:</a></strong></p>
<p dir="auto">Which one do YOU want to drive?</p>
<p dir="auto">Excellent question.</p>
]]></description><link>https://wibimmers.com/post/27711</link><guid isPermaLink="true">https://wibimmers.com/post/27711</guid><dc:creator><![CDATA[michael1972]]></dc:creator><pubDate>Sun, 08 Sep 2013 12:06:40 GMT</pubDate></item><item><title><![CDATA[Reply to G35 coupe or e46 330ci on Sun, 08 Sep 2013 11:55:39 GMT]]></title><description><![CDATA[<p dir="auto">Which one do YOU want to drive?</p>
]]></description><link>https://wibimmers.com/post/27710</link><guid isPermaLink="true">https://wibimmers.com/post/27710</guid><dc:creator><![CDATA[Narcosis]]></dc:creator><pubDate>Sun, 08 Sep 2013 11:55:39 GMT</pubDate></item><item><title><![CDATA[Reply to G35 coupe or e46 330ci on Sun, 08 Sep 2013 11:39:43 GMT]]></title><description><![CDATA[<p dir="auto">Caddy CTS or Impala</p>
]]></description><link>https://wibimmers.com/post/27709</link><guid isPermaLink="true">https://wibimmers.com/post/27709</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Sun, 08 Sep 2013 11:39:43 GMT</pubDate></item><item><title><![CDATA[Reply to G35 coupe or e46 330ci on Sun, 08 Sep 2013 04:16:05 GMT]]></title><description><![CDATA[<p dir="auto">based on looks. the e46</p>
]]></description><link>https://wibimmers.com/post/27707</link><guid isPermaLink="true">https://wibimmers.com/post/27707</guid><dc:creator><![CDATA[jockhater2]]></dc:creator><pubDate>Sun, 08 Sep 2013 04:16:05 GMT</pubDate></item><item><title><![CDATA[Reply to G35 coupe or e46 330ci on Sun, 08 Sep 2013 02:19:58 GMT]]></title><description><![CDATA[<p dir="auto">Lmao slim shady looking fuck</p>
]]></description><link>https://wibimmers.com/post/27706</link><guid isPermaLink="true">https://wibimmers.com/post/27706</guid><dc:creator><![CDATA[SubmuzikBoss]]></dc:creator><pubDate>Sun, 08 Sep 2013 02:19:58 GMT</pubDate></item><item><title><![CDATA[Reply to G35 coupe or e46 330ci on Sun, 08 Sep 2013 02:11:41 GMT]]></title><description><![CDATA[<p dir="auto">Maaannnn.....you the BIGGEST HATER EVER. Big HUNGRY!!</p>
]]></description><link>https://wibimmers.com/post/27702</link><guid isPermaLink="true">https://wibimmers.com/post/27702</guid><dc:creator><![CDATA[michael1972]]></dc:creator><pubDate>Sun, 08 Sep 2013 02:11:41 GMT</pubDate></item></channel></rss>
