  4. G35 coupe or e46 330ci
27 Posts 12 Posters 397 Views 1 Watching
  • M
    M
    michael1972
    Narcosis said:
    Which one do YOU want to drive?
    Excellent question.
      I say get a nice e36 and use the money saved to make it how you want=)
      • jockhater2J
        jockhater2J
        jockhater2
        barf @ the cadillac and the impala
          I like the newer G35's, drive nicely, comfortable and sound good but its still not a bimmer!
          • M
            M
            michael1972
            +1. It sure isn't!!
            • S
              S
              SubmuzikBoss
              Lmao yeah I know it ain't
              I'd get that and keeps bmw now
              • 240sxguy2
                240sxguy2
                240sxguy
                They are completely and utterly different. Apples to oranges. Drive both, buy the one you prefer.
                • S
                  S
                  SubmuzikBoss
                  That's the plan man
                  • M318M
                    M318M
                    M318
                    i would take the 2 door e46 but if it was a manual g coupe vs 4dr automatic e46.... Would end up selling the g coupe after a while anyway.
                      I mean if you're set on a G35, it needs to be low=)
                      • S
                        S
                        SubmuzikBoss
                        Lmao I ain't gonna do the wheels or camber like that lmao that's Asian still shits right there
                          I have no clue what your last half of that sentence even means. Lol The car is VIP inspired
                          • E36M3215E
                            E36M3215E
                            E36M3215
                            E46 M3, faster than a G more driver oriented car than a G oh and not an over priced nissan 350/370z with the same cheap crappy drive train, before I worked at Kummrow I was a nissan tech at amato, they are junk
                            • NarcosisN
                              NarcosisN
                              Narcosis
                              ^^ I'm curious about the drive train issues you've seen, E36M#215.  We own 2 Nissans, a 2005 FX35 and a 2008 EX35.  The FX has 110k miles on it and we've owned it since it had 35k with zero issues.
                                I've read the g35 has a very weak chassis.....whatever they changed between it and the 350z was bad.....however they have MUCH nicer door handles.
                                • E36M3215E
                                  E36M3215E
                                  E36M3215
                                  Code P0011 is a common issue and is fixed temporarily with a vvt selonid or cam position sensor but always ends up coming back being the front timing cover gasket breaks apart over time and falls in to the oil pan, gasket material then gets sucked up to the heads blocking the passages to the vvt if you have owned the car since 35,000 it more than likely has already been fixed
                                  timing chains stretch
                                  Weak blocks if oil changes weren't done on time they will throw rods
                                  Head gaskets go
                                  Front diffs blow up on awd, almost always pinon bearings let loose
                                  Rear main seals leak like a GM truck
                                  Radiator leaks in to trans fluid ( automatic only) more radiator issue but does happen
                                  "Swirl screw" drops in to the combustion camber
                                  You have to remember the VQ35 is a motor used in tons of nissan cars so some of these issues are more prone to other models such as a maxima or 3.5 Altima or a murano or quest.
                                  Its still a VQ35 engine if its an issue it will happen unless addressed
                                  • S
                                    S
                                    SubmuzikBoss
                                    I might just say screw both and just do the 04-06 Pontiac gto 6.0 lol
                                    • Ryan...R
                                      Ryan...R
                                      Ryan...
                                      The GTO I drove was badass, and they aren't all that bad looking either.
                                      • S
                                        S
                                        SubmuzikBoss
                                        Really thinkn bout it Ryan
