  4. my E30 story
my E30 story
205 Posts 14 Posters 3.5k Views 1 Watching
    whoa, nice work! what were you doing when that happened?
    Aluminum does not have an endurance limit so any force being applied to it will fatigue it. So either, those arms had a very stressful life, or perhaps your engine wasnt quite sitting straight in the engine bay and the arms saw some forces they dont normally see.
    Either way, that pic needs a "Thanks Obama" caption.
    • JeffJ
      JeffJ
      Jeff
      Make some steel ones
      1976 530i e12
      1990 325ix e30
      1992 325i e36
      1995 740il e38
      2001 330xi e46
      ^More to come :)
      • johnprusinskiJ
        johnprusinskiJ
        johnprusinski
        Got an update, I got the new brackets in, but after about 20 miles the clutch master cylinder broke. I'm now stranded in a parking lot. I'm starting to get frustrated with this thing.
          nooooooooooooooooooooooooooooo
            That motor is cursed
            Lol
            Caused Dans car to crash on the highway, ate Jakes fuel pump, and now snapped your mounts and then the master cylinder died
              Double post ftw!
                Lol
                bat signal.
                im here.
                • johnprusinskiJ
                  johnprusinskiJ
                  johnprusinski
                  i ordered a new clutch master cylinder tonight. ive been thinking about just tearing the car down and replacing the majority of it. i want to make it reliable so i can actually learn how to drift, because as of right now i cant really drive it down the road, how is it going to handle going sideways?
                    what are your reliability concerns besides the clutch hydraulics
                      John, tuck your bumpers and paint them black like my friend Rob=D
                      Untitled by robertnesvanulica, on Flickr
                      • johnprusinskiJ
                        johnprusinskiJ
                        johnprusinski
                        im not sure to be honest. i cant think of anything else that is on the car that i need to run. i am thinking of just replacing all of the bushings in the rear subframe. i plan on replacing the suspension soon if that counts. im just sick of it breaking.
                        and earl i will tuck the bumpers soon.
                          Paint them black too=) And get hella fogs
                            Dont die when you drill holes in the pressurized dampers to tuck ze bumpers,  late model front end is a simple swap too
                            • johnprusinskiJ
                              johnprusinskiJ
                              johnprusinski
                              I ALREADY DRILLED THE HOLES IN THE SHOCKS A LONG TIME AGO. I COULDNT GET THEM TO PUSH IN WITH A HAMMER OR ANYTHING ELSE SO I HAVE TO DRIVE IT UP TO A WALL OR WHATEVER.
                                caps lock [ENGAGED]
                                • johnprusinskiJ
                                  johnprusinskiJ
                                  johnprusinski
                                  haha sorry i need it for work. too lazy to turn it off.
                                  • johnprusinskiJ
                                    johnprusinskiJ
                                    johnprusinski
                                    here are some pictures.
                                      Is it common for pedal boxes to break on E30s too? I know that people reinforce the E28 ones, wonder if its all the same hardware.
                                      • johnprusinskiJ
                                        johnprusinskiJ
                                        johnprusinski
                                        I'm not sure if they are a common problem. I'm amazed that the rod broke though.
                                          does your firewall have any accident damage causing the clutch masta to be mounted off on an angle from where BMW intended it to be?
