  4. A note to all E46 owners.
24 Posts 11 Posters 474 Views 2 Watching
  • AvusHatesConesA
    AvusHatesConesA
    AvusHatesCones
    REKIII said:
    Remember, the three seris is the most basic BMW.  It's designed to be a 318 all the way up to an M3.  The M3 USUALLY gets different subframes, but the attachment points are the same.  The additional forces that the M's put on themselves is much more than a 318.  These extra forces work on paper, but not after lots and lots of cycles.
    The guys running HPF kits and whatnot much be tearing their cars apart.
    It's my understanding that this is just as common on 323/325/330's as well. It just snow balls once you get a little extra movement
    Silver Grey E46 M3
    • M
      M
      michael1972
      What year is your M? It's was my understanding that by the 2003, BMW had strengthed the subframes because of all the problems with the earlier years.
      • AvusHatesConesA
        AvusHatesConesA
        AvusHatesCones
        Unfortunately, that's not the case at all. And mine is an 04. There are plenty of people with 06's that have the same issues.
        Silver Grey E46 M3
        • T
          T
          ten2doyle102
          Wow....  I had only heard of that happening, but nothing that bad.  I had my 330i looked at and luckily never looked that bad!
          E30 by ten2doyle102, on Flickr
          2000 Audi S4 2.7TT, 1991 318is 1.8L
          Represntin' da A-Town foo's
          • JeffJ
            JeffJ
            Jeff
            so all e46? i have an 01 330xi. this happened to my e36
            1976 530i e12
            1990 325ix e30
            1992 325i e36
            1995 740il e38
            2001 330xi e46
            ^More to come :)
            • AvusHatesConesA
              AvusHatesConesA
              AvusHatesCones
              ^ Yep, some worse than others, but the worst one ever I saw (other than 800+hp M3's) was a stock 323i so it can happen to any E46.
              Silver Grey E46 M3
              • M
                M
                m3clubbmw
                my guys does this kind of job he only charges 650$ and he works at a shop, so if anything goes bad you will get warranty but that will not happend they do it correctly to few other cars..
                • W
                  W
                  Whammy
                  OP, not all E46s are affected by this change.   Pre-facelift BMWs 99-01 were mostly affected by the change, in early 2002 (not sure exactly when), BMW corrected the design flaw in the body/subframe.
                  It is definitely a concern for all e46s but truth be told, not all have been affected.  I have yet to see one facelifted E46 affected by the subframe cracking issue the pre-facelifted E46s have.
                  Edit:  If you want more details on this, pop over to forum.e46fanatics.com
                  • AvusHatesConesA
                    AvusHatesConesA
                    AvusHatesCones
                    BMW also "corrected" the the M3 in 05 and 06, and those fail just as often as well. They never actually fixed anything.
                    Silver Grey E46 M3
                    • M
                      M
                      michael1972
                      What kind of symptoms did your car have when it started coming apart?
                      • AvusHatesConesA
                        AvusHatesConesA
                        AvusHatesCones
                        Just a click sound off the line and when entering very hard left hand turns. As well as slight mid corner tracking from the rear, but only enough that only I'd notice occasionally.
                        Silver Grey E46 M3
                          bigjae1976
                          The subframe failure is the result of bad subframe bushings. The rear subframe is secured to the floor pan with 4 studs which are screwed in. What happens is the 4 subframe bushings go bad (typically the fronts) and then allows the rear subframe to twist everytime you accelerate and decelerate. This twisting loads and unloads the force of the subframe onto those studs which in turns leads to the metal fatiguing and cracking. Then continued use will result in your rear floor basically tearing itself out of the car.
                          First, address your driveline bushings. Typically motor and diff mounts fail quickly and are the first to go. Keeping the engine, tranny, and diff mounts, guibo, and center bearing in good shape will reduce the stress on your rear subframe bushings.
                          2004 BMW started using structural foam in the rear floor which helped.
                          The problem is there's no way to really see if the rear subframe bushings (that I know of) have failed. Most won't do preventive replacement due to the cost.
                          IMO, the fix is preventively reinforcing the 6 mounting points and installing solid rear subframe bushings. The solids won't add much NHV and will last a lot longer.
                          • AvusHatesConesA
                            AvusHatesConesA
                            AvusHatesCones
                            That's not true, my subframe bushings were replaced at 65,000 as preventative maintenance and again now. They never went bad nor did they have enough time to do so. Also BMW never added the structural foam from the factory. The structural foam was only used as a fix for cars with 2cm or smaller cracks, the rest had the entire rear floor pan removed. There are only theories on what causes these floor pans to crack, no true facts on what it is.
                            Silver Grey E46 M3
                              bigjae1976
                              So wait...you already had a crack then replaced the bushings and then didn't fix the crack at that time? Then you let the crack go for another 20k miles until this happened?
                              • AvusHatesConesA
                                AvusHatesConesA
                                AvusHatesCones
                                No racks at 65,000 miles, bushings replaced anyway. Subframe inspected again 40,000 miles later, crack city, bushings replaced again, subframe fixed and reinforced.
                                Silver Grey E46 M3
                                  bigjae1976
                                  Yes, bushings can fail in 40k miles. Not unheard of. Especially if the diff mounts were on their way out. Usually if your subframe bushings are bad then your driveline mounts will be suspect.
                                  I've went through motor mounts in my E46 330 (s/c'd) in a year. I had the powerflex rear subframe bushings which seemed to be fine after about 35k miles and 40 hours of track time.
