<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[A note to all E46 owners.]]></title><description><![CDATA[<p dir="auto">GET YOUR DAMN SUBFRAME INSPECTED!</p>
<p dir="auto">My subframe went from one small crack to complete hell in 20,000 miles. Also when my car was checked at 60,000 miles it was completely fine so BMW did nothing to it.  I know among E46 owners this issue has been beaten to death, but it really is a serious issue and it has to be reinforced, there is no way around it. If you don't have any cracks right now, great! <strong>Now go get it reinforced today!</strong> If I would have done even 1 track day as my car was before the repair, the floor pans more than likely would have been a total loss. And I dont know about you, but spending 6-7K on new floor plans sounds like one really shitty idea, versus less than a thousand on the reinforcement/repair. <strong>Your car will crack at some point!</strong>  Just get this out of the way before it gets bad. The worst part is the lack of side effects, I only noticed a very minor cick on/off throttle in 1st gear, and the car still felt very confident at 8k rpm in 5th gear. (probably was not the brightest thing to do). All I'm saying is at least get it inspected, this will happen to every E46 (except possibly a very easily driven wagon, they had the strongest floor pans by quite a bit). </p>
<p dir="auto">Now on to some pictures to scare the fear of god into you to get your car reinforced.</p>
<p dir="auto"><img src="http://farm3.staticflickr.com/2834/9346894512_02315c7a4d.jpg" alt="934689451202315c7a4d.jpg" class=" img-fluid img-markdown" /><img src="http://farm4.staticflickr.com/3686/9344086755_a78ce0247e.jpg" alt="9344086755a78ce0247e.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://farm8.staticflickr.com/7433/9346867524_934efb901a.jpg" alt="9346867524934efb901a.jpg" class=" img-fluid img-markdown" /><img src="http://farm3.staticflickr.com/2848/9346890236_f9254c0636.jpg" alt="9346890236f9254c0636.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://farm6.staticflickr.com/5334/9346884828_e48509c151.jpg" alt="9346884828e48509c151.jpg" class=" img-fluid img-markdown" /><img src="http://farm6.staticflickr.com/5347/9347023450_893f2dd21e.jpg" alt="9347023450893f2dd21e.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">If anyone one is interested, I had the reinforcement/repair done by Jake at Rawsomotion. <a href="http://www.rawsomotion.com/" rel="nofollow ugc">http://www.rawsomotion.com/</a></p>
<p dir="auto">I have known Jake for a few years and referred many people his way , he does great work and will not let anything be done improperly. And he won't rip you off.</p>
<p dir="auto">You may be a DIY person like myself, I almost never take my cars to a shop, but do not kid yourself. You're not going to do this repair without a lift and without being a talented in place welder, and you sure as hell are not doing that on your back under the car.</p>
]]></description><link>https://wibimmers.com/topic/1696/a-note-to-all-e46-owners.</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 06:36:45 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/1696.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 22 Jul 2013 21:18:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to A note to all E46 owners. on Tue, 01 Oct 2013 04:18:24 GMT]]></title><description><![CDATA[<p dir="auto">Yes, bushings can fail in 40k miles. Not unheard of. Especially if the diff mounts were on their way out. Usually if your subframe bushings are bad then your driveline mounts will be suspect.</p>
<p dir="auto">I've went through motor mounts in my E46 330 (s/c'd) in a year. I had the powerflex rear subframe bushings which seemed to be fine after about 35k miles and 40 hours of track time.</p>
]]></description><link>https://wibimmers.com/post/28816</link><guid isPermaLink="true">https://wibimmers.com/post/28816</guid><dc:creator><![CDATA[bigjae1976]]></dc:creator><pubDate>Tue, 01 Oct 2013 04:18:24 GMT</pubDate></item><item><title><![CDATA[Reply to A note to all E46 owners. on Mon, 30 Sep 2013 13:13:00 GMT]]></title><description><![CDATA[<p dir="auto">No racks at 65,000 miles, bushings replaced anyway. Subframe inspected again 40,000 miles later, crack city, bushings replaced again, subframe fixed and reinforced.</p>
]]></description><link>https://wibimmers.com/post/28777</link><guid isPermaLink="true">https://wibimmers.com/post/28777</guid><dc:creator><![CDATA[AvusHatesCones]]></dc:creator><pubDate>Mon, 30 Sep 2013 13:13:00 GMT</pubDate></item><item><title><![CDATA[Reply to A note to all E46 owners. on Sun, 29 Sep 2013 02:20:09 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/28569">AvusHatesCones said:</a></strong></p>
<p dir="auto">That's not true, my subframe bushings were replaced at 65,000 as preventative maintenance and again now. They never went bad nor did they have enough time to do so. Also BMW never added the structural foam from the factory. The structural foam was only used as a fix for cars with 2cm or smaller cracks, the rest had the entire rear floor pan removed. There are only theories on what causes these floor pans to crack, no true facts on what it is.  </p>
<p dir="auto">So wait...you already had a crack then replaced the bushings and then didn't fix the crack at that time? Then you let the crack go for another 20k miles until this happened?</p>
]]></description><link>https://wibimmers.com/post/28724</link><guid isPermaLink="true">https://wibimmers.com/post/28724</guid><dc:creator><![CDATA[bigjae1976]]></dc:creator><pubDate>Sun, 29 Sep 2013 02:20:09 GMT</pubDate></item><item><title><![CDATA[Reply to A note to all E46 owners. on Wed, 25 Sep 2013 20:39:46 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/28527">bigjae1976 said:</a></strong></p>
<p dir="auto">The subframe failure is the result of bad subframe bushings. The rear subframe is secured to the floor pan with 4 studs which are screwed in. What happens is the 4 subframe bushings go bad (typically the fronts) and then allows the rear subframe to twist everytime you accelerate and decelerate. This twisting loads and unloads the force of the subframe onto those studs which in turns leads to the metal fatiguing and cracking. Then continued use will result in your rear floor basically tearing itself out of the car.</p>
<p dir="auto">First, address your driveline bushings. Typically motor and diff mounts fail quickly and are the first to go. Keeping the engine, tranny, and diff mounts, guibo, and center bearing in good shape will reduce the stress on your rear subframe bushings.</p>
<p dir="auto">2004 BMW started using structural foam in the rear floor which helped.</p>
<p dir="auto">The problem is there's no way to really see if the rear subframe bushings (that I know of) have failed. Most won't do preventive replacement due to the cost.</p>
<p dir="auto">IMO, the fix is preventively reinforcing the 6 mounting points and installing solid rear subframe bushings. The solids won't add much NHV and will last a lot longer.</p>
<p dir="auto">That's not true, my subframe bushings were replaced at 65,000 as preventative maintenance and again now. They never went bad nor did they have enough time to do so. Also BMW never added the structural foam from the factory. The structural foam was only used as a fix for cars with 2cm or smaller cracks, the rest had the entire rear floor pan removed. There are only theories on what causes these floor pans to crack, no true facts on what it is.</p>
]]></description><link>https://wibimmers.com/post/28569</link><guid isPermaLink="true">https://wibimmers.com/post/28569</guid><dc:creator><![CDATA[AvusHatesCones]]></dc:creator><pubDate>Wed, 25 Sep 2013 20:39:46 GMT</pubDate></item><item><title><![CDATA[Reply to A note to all E46 owners. on Wed, 25 Sep 2013 04:14:51 GMT]]></title><description><![CDATA[<p dir="auto">The subframe failure is the result of bad subframe bushings. The rear subframe is secured to the floor pan with 4 studs which are screwed in. What happens is the 4 subframe bushings go bad (typically the fronts) and then allows the rear subframe to twist everytime you accelerate and decelerate. This twisting loads and unloads the force of the subframe onto those studs which in turns leads to the metal fatiguing and cracking. Then continued use will result in your rear floor basically tearing itself out of the car.</p>
]]></description><link>https://wibimmers.com/post/28527</link><guid isPermaLink="true">https://wibimmers.com/post/28527</guid><dc:creator><![CDATA[bigjae1976]]></dc:creator><pubDate>Wed, 25 Sep 2013 04:14:51 GMT</pubDate></item><item><title><![CDATA[Reply to A note to all E46 owners. on Mon, 26 Aug 2013 16:02:42 GMT]]></title><description><![CDATA[<p dir="auto">Just a click sound off the line and when entering very hard left hand turns. As well as slight mid corner tracking from the rear, but only enough that only I'd notice occasionally.</p>
]]></description><link>https://wibimmers.com/post/27162</link><guid isPermaLink="true">https://wibimmers.com/post/27162</guid><dc:creator><![CDATA[AvusHatesCones]]></dc:creator><pubDate>Mon, 26 Aug 2013 16:02:42 GMT</pubDate></item><item><title><![CDATA[Reply to A note to all E46 owners. on Wed, 21 Aug 2013 15:44:41 GMT]]></title><description><![CDATA[<p dir="auto">What kind of symptoms did your car have when it started coming apart?</p>
]]></description><link>https://wibimmers.com/post/26974</link><guid isPermaLink="true">https://wibimmers.com/post/26974</guid><dc:creator><![CDATA[michael1972]]></dc:creator><pubDate>Wed, 21 Aug 2013 15:44:41 GMT</pubDate></item><item><title><![CDATA[Reply to A note to all E46 owners. on Tue, 20 Aug 2013 15:25:27 GMT]]></title><description><![CDATA[<p dir="auto">BMW also "corrected" the the M3 in 05 and 06, and those fail just as often as well. They never actually fixed anything.</p>
]]></description><link>https://wibimmers.com/post/26915</link><guid isPermaLink="true">https://wibimmers.com/post/26915</guid><dc:creator><![CDATA[AvusHatesCones]]></dc:creator><pubDate>Tue, 20 Aug 2013 15:25:27 GMT</pubDate></item><item><title><![CDATA[Reply to A note to all E46 owners. on Tue, 20 Aug 2013 00:52:05 GMT]]></title><description><![CDATA[<p dir="auto">OP, not all E46s are affected by this change.   Pre-facelift BMWs 99-01 were mostly affected by the change, in early 2002 (not sure exactly when), BMW corrected the design flaw in the body/subframe.</p>
<p dir="auto">It is definitely a concern for all e46s but truth be told, not all have been affected.  I have yet to see one facelifted E46 affected by the subframe cracking issue the pre-facelifted E46s have.</p>
<p dir="auto">Edit:  If you want more details on this, pop over to <a href="http://forum.e46fanatics.com" rel="nofollow ugc">forum.e46fanatics.com</a></p>
]]></description><link>https://wibimmers.com/post/26886</link><guid isPermaLink="true">https://wibimmers.com/post/26886</guid><dc:creator><![CDATA[Whammy]]></dc:creator><pubDate>Tue, 20 Aug 2013 00:52:05 GMT</pubDate></item><item><title><![CDATA[Reply to A note to all E46 owners. on Mon, 19 Aug 2013 21:40:14 GMT]]></title><description><![CDATA[<p dir="auto">my guys does this kind of job he only charges 650$ and he works at a shop, so if anything goes bad you will get warranty but that will not happend they do it correctly to few other cars..</p>
]]></description><link>https://wibimmers.com/post/26865</link><guid isPermaLink="true">https://wibimmers.com/post/26865</guid><dc:creator><![CDATA[m3clubbmw]]></dc:creator><pubDate>Mon, 19 Aug 2013 21:40:14 GMT</pubDate></item><item><title><![CDATA[Reply to A note to all E46 owners. on Mon, 19 Aug 2013 20:32:09 GMT]]></title><description><![CDATA[<p dir="auto">^ Yep, some worse than others, but the worst one ever I saw (other than 800+hp M3's) was a stock 323i so it can happen to any E46.</p>
]]></description><link>https://wibimmers.com/post/26851</link><guid isPermaLink="true">https://wibimmers.com/post/26851</guid><dc:creator><![CDATA[AvusHatesCones]]></dc:creator><pubDate>Mon, 19 Aug 2013 20:32:09 GMT</pubDate></item><item><title><![CDATA[Reply to A note to all E46 owners. on Mon, 19 Aug 2013 20:06:17 GMT]]></title><description><![CDATA[<p dir="auto">so all e46? i have an 01 330xi. this happened to my e36</p>
]]></description><link>https://wibimmers.com/post/26847</link><guid isPermaLink="true">https://wibimmers.com/post/26847</guid><dc:creator><![CDATA[Jeff]]></dc:creator><pubDate>Mon, 19 Aug 2013 20:06:17 GMT</pubDate></item><item><title><![CDATA[Reply to A note to all E46 owners. on Tue, 30 Jul 2013 19:23:15 GMT]]></title><description><![CDATA[<p dir="auto">Wow....  I had only heard of that happening, but nothing that bad.  I had my 330i looked at and luckily never looked that bad!</p>
]]></description><link>https://wibimmers.com/post/26092</link><guid isPermaLink="true">https://wibimmers.com/post/26092</guid><dc:creator><![CDATA[ten2doyle102]]></dc:creator><pubDate>Tue, 30 Jul 2013 19:23:15 GMT</pubDate></item><item><title><![CDATA[Reply to A note to all E46 owners. on Fri, 26 Jul 2013 14:47:54 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/25947">michael1972 said:</a></strong></p>
<p dir="auto">What year is your M? It's was my understanding that by the 2003, BMW had strengthed the subframes because of all the problems with the earlier years.</p>
<p dir="auto">Unfortunately, that's not the case at all. And mine is an 04. There are plenty of people with 06's that have the same issues.</p>
]]></description><link>https://wibimmers.com/post/25950</link><guid isPermaLink="true">https://wibimmers.com/post/25950</guid><dc:creator><![CDATA[AvusHatesCones]]></dc:creator><pubDate>Fri, 26 Jul 2013 14:47:54 GMT</pubDate></item><item><title><![CDATA[Reply to A note to all E46 owners. on Fri, 26 Jul 2013 13:38:23 GMT]]></title><description><![CDATA[<p dir="auto">What year is your M? It's was my understanding that by the 2003, BMW had strengthed the subframes because of all the problems with the earlier years.</p>
]]></description><link>https://wibimmers.com/post/25947</link><guid isPermaLink="true">https://wibimmers.com/post/25947</guid><dc:creator><![CDATA[michael1972]]></dc:creator><pubDate>Fri, 26 Jul 2013 13:38:23 GMT</pubDate></item><item><title><![CDATA[Reply to A note to all E46 owners. on Wed, 24 Jul 2013 13:41:50 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/25856">REKIII said:</a></strong></p>
<p dir="auto">Remember, the three seris is the most basic BMW.  It's designed to be a 318 all the way up to an M3.  The M3 USUALLY gets different subframes, but the attachment points are the same.  The additional forces that the M's put on themselves is much more than a 318.  These extra forces work on paper, but not after lots and lots of cycles.</p>
<p dir="auto">The guys running HPF kits and whatnot much be tearing their cars apart.</p>
<p dir="auto">It's my understanding that this is just as common on 323/325/330's as well. It just snow balls once you get a little extra movement</p>
]]></description><link>https://wibimmers.com/post/25867</link><guid isPermaLink="true">https://wibimmers.com/post/25867</guid><dc:creator><![CDATA[AvusHatesCones]]></dc:creator><pubDate>Wed, 24 Jul 2013 13:41:50 GMT</pubDate></item><item><title><![CDATA[Reply to A note to all E46 owners. on Wed, 24 Jul 2013 01:29:13 GMT]]></title><description><![CDATA[<p dir="auto">Remember, the three seris is the most basic BMW.  It's designed to be a 318 all the way up to an M3.  The M3 USUALLY gets different subframes, but the attachment points are the same.  The additional forces that the M's put on themselves is much more than a 318.  These extra forces work on paper, but not after lots and lots of cycles.</p>
]]></description><link>https://wibimmers.com/post/25856</link><guid isPermaLink="true">https://wibimmers.com/post/25856</guid><dc:creator><![CDATA[REKIII]]></dc:creator><pubDate>Wed, 24 Jul 2013 01:29:13 GMT</pubDate></item><item><title><![CDATA[Reply to A note to all E46 owners. on Tue, 23 Jul 2013 22:34:06 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/25841">AvusHatesCones said:</a></strong></p>
<p dir="auto">Yep, Jake has become quite the fabricator. There are a few theories on what causes these cracks, I'm assuming its simply bad/too small of load points for the subframe mounts. This is know to happen on E36's also, just not to the same extent.</p>
<p dir="auto">He started out working for my Dad when he was 19. I used to use jake ALL THE TIME. But now I do mostly everything on my own. Not the transmission though. F that.</p>
<p dir="auto">Jake is actually really good at what he does guys. And his prices are very fair. Especially for those jobs that you look at and say...I can do that...but i don't want to.</p>
<p dir="auto">Do you think that happened as a result of BMW trying to keep the weight down or something?</p>
]]></description><link>https://wibimmers.com/post/25847</link><guid isPermaLink="true">https://wibimmers.com/post/25847</guid><dc:creator><![CDATA[jockhater2]]></dc:creator><pubDate>Tue, 23 Jul 2013 22:34:06 GMT</pubDate></item><item><title><![CDATA[Reply to A note to all E46 owners. on Tue, 23 Jul 2013 18:47:49 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/25824">jockhater2 said:</a></strong></p>
<p dir="auto">Really? Jake does this work? That's pretty cool! Hopefully he gets to my transmission soon.</p>
<p dir="auto">I'm sorry to hear about this. I had no idea the E46 body can crack. How is that possible?</p>
]]></description><link>https://wibimmers.com/post/25841</link><guid isPermaLink="true">https://wibimmers.com/post/25841</guid><dc:creator><![CDATA[AvusHatesCones]]></dc:creator><pubDate>Tue, 23 Jul 2013 18:47:49 GMT</pubDate></item><item><title><![CDATA[Reply to A note to all E46 owners. on Tue, 23 Jul 2013 18:45:02 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/25819">StewCrew said:</a></strong></p>
<p dir="auto">Wow, that got real bad real quick! Out of curiosity, how much did it cost to get it welded? That's quite a crack.</p>
<p dir="auto">Typically its right around 1k to have it all done. That includes tearing apart the whole rear end of the car, chasing cracks, welding, and installing the reinforcement kit. Which in all honesty, isn't all that bad considering most shops charge near that just to swap out a clutch.</p>
]]></description><link>https://wibimmers.com/post/25840</link><guid isPermaLink="true">https://wibimmers.com/post/25840</guid><dc:creator><![CDATA[AvusHatesCones]]></dc:creator><pubDate>Tue, 23 Jul 2013 18:45:02 GMT</pubDate></item><item><title><![CDATA[Reply to A note to all E46 owners. on Tue, 23 Jul 2013 08:39:19 GMT]]></title><description><![CDATA[<p dir="auto">Really? Jake does this work? That's pretty cool! Hopefully he gets to my transmission soon.</p>
]]></description><link>https://wibimmers.com/post/25824</link><guid isPermaLink="true">https://wibimmers.com/post/25824</guid><dc:creator><![CDATA[jockhater2]]></dc:creator><pubDate>Tue, 23 Jul 2013 08:39:19 GMT</pubDate></item><item><title><![CDATA[Reply to A note to all E46 owners. on Tue, 23 Jul 2013 05:40:50 GMT]]></title><description><![CDATA[<p dir="auto">Wow, that got real bad real quick! Out of curiosity, how much did it cost to get it welded? That's quite a crack.</p>
]]></description><link>https://wibimmers.com/post/25819</link><guid isPermaLink="true">https://wibimmers.com/post/25819</guid><dc:creator><![CDATA[StewCrew]]></dc:creator><pubDate>Tue, 23 Jul 2013 05:40:50 GMT</pubDate></item><item><title><![CDATA[Reply to A note to all E46 owners. on Tue, 23 Jul 2013 04:44:28 GMT]]></title><description><![CDATA[<p dir="auto">Sorry to see this happen. I sure am glad I have a very easily driven wagon <img src="/assets/uploads/files/emoticons_default_smile.png" alt=":)" class=" img-fluid img-markdown" width="20" height="20" /></p>
]]></description><link>https://wibimmers.com/post/25817</link><guid isPermaLink="true">https://wibimmers.com/post/25817</guid><dc:creator><![CDATA[wasnt m3]]></dc:creator><pubDate>Tue, 23 Jul 2013 04:44:28 GMT</pubDate></item></channel></rss>
