  4. sounds like a semi truck
14 Posts 4 Posters 160 Views 1 Watching
    clutch in your clutch fan is seized, so it's constantly engaged. Not a huge issue. my 76C10 had a constant fan (just ran off the engine RPM's) it's annoying, but it'll be fine. Just get a new clutch assembly for the fan, if it bothers you that much.
    • e36mpwrE
      e36mpwrE
      e36mpwr
      I just did my whole cooling system though, new fan clutch and everything though. Why would it make that noise if its new?
        no idea then.
        • e36mpwrE
          e36mpwrE
          e36mpwr
          Anyone
          • JeffJ
            JeffJ
            Jeff
            does not meant it is good
            1976 530i e12
            1990 325ix e30
            1992 325i e36
            1995 740il e38
            2001 330xi e46
            ^More to come :)
            • JeffJ
              JeffJ
              Jeff
              is it oem? the clutch fas should engage when first started then release. it shouldn't engage until it reaches a temperature. does it feel like it is binding up? should have a little tension when its cold but not too much.
              1976 530i e12
              1990 325ix e30
              1992 325i e36
              1995 740il e38
              2001 330xi e46
              ^More to come :)
              • C
                C
                Chadley
                Have we thought it could be the VANOS....
                • e36mpwrE
                  e36mpwrE
                  e36mpwr
                  It's not vanos I otta adjust them because they are ticking or it could be low on oil but ever since I did my cooling system it started making that noise it gets annoying.
                  • JeffJ
                    JeffJ
                    Jeff
                    Vanos rattles when its bad. If vanos made that noise i would run its going to blow!
                    1976 530i e12
                    1990 325ix e30
                    1992 325i e36
                    1995 740il e38
                    2001 330xi e46
                    ^More to come :)
                    • e36mpwrE
                      e36mpwrE
                      e36mpwr
                      Shop said vanos or you may be low on oil and my check coolant came on so that's probably it.
