<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[sounds like a semi truck]]></title><description><![CDATA[<p dir="auto">Just did my cooling system a month ago, and I noticed before the fan wouldn't make alot of noise and now ever since I did it it sounds like a truck. What's the problem here lol its annoying I can never hear my nice swooooooooooooosh sound intake haha</p>
]]></description><link>https://wibimmers.com/topic/1342/sounds-like-a-semi-truck</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:57:34 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/1342.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 06 Apr 2013 06:04:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to sounds like a semi truck on Mon, 08 Apr 2013 05:32:43 GMT]]></title><description><![CDATA[<p dir="auto">Shop said vanos or you may be low on oil and my check coolant came on so that's probably it.</p>
]]></description><link>https://wibimmers.com/post/20279</link><guid isPermaLink="true">https://wibimmers.com/post/20279</guid><dc:creator><![CDATA[e36mpwr]]></dc:creator><pubDate>Mon, 08 Apr 2013 05:32:43 GMT</pubDate></item><item><title><![CDATA[Reply to sounds like a semi truck on Mon, 08 Apr 2013 05:11:41 GMT]]></title><description><![CDATA[<p dir="auto">Vanos rattles when its bad. If vanos made that noise i would run its going to blow!</p>
]]></description><link>https://wibimmers.com/post/20270</link><guid isPermaLink="true">https://wibimmers.com/post/20270</guid><dc:creator><![CDATA[Jeff]]></dc:creator><pubDate>Mon, 08 Apr 2013 05:11:41 GMT</pubDate></item><item><title><![CDATA[Reply to sounds like a semi truck on Mon, 08 Apr 2013 05:11:25 GMT]]></title><description><![CDATA[<p dir="auto">It's not vanos I otta adjust them because they are ticking or it could be low on oil but ever since I did my cooling system it started making that noise it gets annoying.</p>
]]></description><link>https://wibimmers.com/post/20269</link><guid isPermaLink="true">https://wibimmers.com/post/20269</guid><dc:creator><![CDATA[e36mpwr]]></dc:creator><pubDate>Mon, 08 Apr 2013 05:11:25 GMT</pubDate></item><item><title><![CDATA[Reply to sounds like a semi truck on Mon, 08 Apr 2013 04:56:43 GMT]]></title><description><![CDATA[<p dir="auto">Have we thought it could be the VANOS....</p>
<p dir="auto">?</p>
]]></description><link>https://wibimmers.com/post/20265</link><guid isPermaLink="true">https://wibimmers.com/post/20265</guid><dc:creator><![CDATA[Chadley]]></dc:creator><pubDate>Mon, 08 Apr 2013 04:56:43 GMT</pubDate></item><item><title><![CDATA[Reply to sounds like a semi truck on Mon, 08 Apr 2013 03:55:48 GMT]]></title><description><![CDATA[<p dir="auto">is it oem? the clutch fas should engage when first started then release. it shouldn't engage until it reaches a temperature. does it feel like it is binding up? should have a little tension when its cold but not too much.</p>
]]></description><link>https://wibimmers.com/post/20255</link><guid isPermaLink="true">https://wibimmers.com/post/20255</guid><dc:creator><![CDATA[Jeff]]></dc:creator><pubDate>Mon, 08 Apr 2013 03:55:48 GMT</pubDate></item><item><title><![CDATA[Reply to sounds like a semi truck on Mon, 08 Apr 2013 03:52:05 GMT]]></title><description><![CDATA[<p dir="auto">does not meant it is good</p>
]]></description><link>https://wibimmers.com/post/20254</link><guid isPermaLink="true">https://wibimmers.com/post/20254</guid><dc:creator><![CDATA[Jeff]]></dc:creator><pubDate>Mon, 08 Apr 2013 03:52:05 GMT</pubDate></item><item><title><![CDATA[Reply to sounds like a semi truck on Sun, 07 Apr 2013 18:51:09 GMT]]></title><description><![CDATA[<p dir="auto">Anyone</p>
]]></description><link>https://wibimmers.com/post/20210</link><guid isPermaLink="true">https://wibimmers.com/post/20210</guid><dc:creator><![CDATA[e36mpwr]]></dc:creator><pubDate>Sun, 07 Apr 2013 18:51:09 GMT</pubDate></item><item><title><![CDATA[Reply to sounds like a semi truck on Sun, 07 Apr 2013 01:40:21 GMT]]></title><description><![CDATA[<p dir="auto">no idea then.</p>
]]></description><link>https://wibimmers.com/post/20133</link><guid isPermaLink="true">https://wibimmers.com/post/20133</guid><dc:creator><![CDATA[Brian.]]></dc:creator><pubDate>Sun, 07 Apr 2013 01:40:21 GMT</pubDate></item><item><title><![CDATA[Reply to sounds like a semi truck on Sun, 07 Apr 2013 00:08:01 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/20123">Brian said:</a></strong></p>
<p dir="auto">clutch in your clutch fan is seized, so it's constantly engaged. Not a huge issue. my 76C10 had a constant fan (just ran off the engine RPM's) it's annoying, but it'll be fine. Just get a new clutch assembly for the fan, if it bothers you that much.</p>
<p dir="auto">I just did my whole cooling system though, new fan clutch and everything though. Why would it make that noise if its new?</p>
]]></description><link>https://wibimmers.com/post/20127</link><guid isPermaLink="true">https://wibimmers.com/post/20127</guid><dc:creator><![CDATA[e36mpwr]]></dc:creator><pubDate>Sun, 07 Apr 2013 00:08:01 GMT</pubDate></item><item><title><![CDATA[Reply to sounds like a semi truck on Sat, 06 Apr 2013 23:49:58 GMT]]></title><description><![CDATA[<p dir="auto">clutch in your clutch fan is seized, so it's constantly engaged. Not a huge issue. my 76C10 had a constant fan (just ran off the engine RPM's) it's annoying, but it'll be fine. Just get a new clutch assembly for the fan, if it bothers you that much.</p>
]]></description><link>https://wibimmers.com/post/20123</link><guid isPermaLink="true">https://wibimmers.com/post/20123</guid><dc:creator><![CDATA[Brian.]]></dc:creator><pubDate>Sat, 06 Apr 2013 23:49:58 GMT</pubDate></item><item><title><![CDATA[Reply to sounds like a semi truck on Sat, 06 Apr 2013 21:28:39 GMT]]></title><description><![CDATA[<p dir="auto">Exactly like this<br />
<a href="http://youtu.be/peOfU3inmho" rel="nofollow ugc">http://youtu.be/peOfU3inmho</a></p>
]]></description><link>https://wibimmers.com/post/20117</link><guid isPermaLink="true">https://wibimmers.com/post/20117</guid><dc:creator><![CDATA[e36mpwr]]></dc:creator><pubDate>Sat, 06 Apr 2013 21:28:39 GMT</pubDate></item><item><title><![CDATA[Reply to sounds like a semi truck on Sat, 06 Apr 2013 21:24:53 GMT]]></title><description><![CDATA[<p dir="auto">Ill find a video some what to the sound.</p>
]]></description><link>https://wibimmers.com/post/20116</link><guid isPermaLink="true">https://wibimmers.com/post/20116</guid><dc:creator><![CDATA[e36mpwr]]></dc:creator><pubDate>Sat, 06 Apr 2013 21:24:53 GMT</pubDate></item><item><title><![CDATA[Reply to sounds like a semi truck on Sat, 06 Apr 2013 06:38:55 GMT]]></title><description><![CDATA[<p dir="auto">Define semi truck. Semi's sound like diesels. can't imagine a fan sounding like a semi. at idle or WOT</p>
]]></description><link>https://wibimmers.com/post/20073</link><guid isPermaLink="true">https://wibimmers.com/post/20073</guid><dc:creator><![CDATA[Brian.]]></dc:creator><pubDate>Sat, 06 Apr 2013 06:38:55 GMT</pubDate></item></channel></rss>
