    I just hate the bottom halfs 3 different patterns, and the yellow turn signal kills it for me.
      Here you go e28ers.
      http://www.mye28.com/viewtopic.php?t=88388
        All those tail lights look like shit. Especially the cleared turn signals. Those are such botch job's its appalling.
          There is a picture of all reds you Dork. Lol
          • StewCrewS
            StewCrewS
            StewCrew
            Those all red e28 lights look sweet! Theres so much red tail light tinting going on around here, I love it! You're are lookin top-notch sir.
              Thanks good buddy. Hopefully more so after Saturday.
              I didn't go out to the shop yesterday because I couldn't figure out what I would do. I instead went home and finished the headlights. I also got the tail lights almost finished. They just need to be wet sanded and buffed=) I didn't get any pictures of the other head light finished, but I did get a picture of the tail lights.
              Updates will follow Saturday.
                Waiting for Jake to wake so that we can do some painting:P I'm going to nap in my car until he comes.
                  Are you going to paint anything that differentiates power, white?
                    Bahaha no
                      I got a little done Saturday.
                      I started the day by tearing into my motor a little more. I removed the upper timing cover and water pump. I tried extracting the water pump using two bolts to push it out, but ended up braking the ears off. Then I just shook the crap out of it until it popped out.
                      Then I got working on my rear subframe yet again.
                      The hardest thing was getting the handbrake cable ends out of the trailing arms. They were basically fused together. I used a pneumatic chisel on one, and had to drill the other one out. I didn't get any pictures. I then degreased everything, washed it, and dried it with an air nozzle. I then threw down a coat of Rust Reformer to try and prevent rust in the future. (These pictures turned out horrible)
                      Then shenanigans ensued and come skating was done. I managed to snap the tail off of my board and continued to rid it until I snapped the nose off. Then I focused it.
                      I then finally got actual paint on the parts. The diff, hubs, and dust shield will be black. I did not have any black at the time. I will also be clear coating it all. The color is a champagne tinted silver. The picture of the subframe is the most accurate portrayal of the color.
                      Wednesday I will be pulling the head off of the motor and taking it to get resurfaced. The flywheel will be getting done too. I need to start ording a lot of parts. I need a ton of little things for the motor, as well as brake lines for the rear.
                      • johnprusinskiJ
                        johnprusinskiJ
                        johnprusinski
                        i like how that subframe turned out. it looks really good.
                          Me too. It needs clear this Saturday=)
                            Tiny update this morning=) My Hankook HR2's arrived yesterday morning. I went with a 205/40 up front and a 215/40 for the rear. I definitely shouldn't run into any clearance issues.
                            Today I'm heading to the shop after work to get the head off. Plan on seeing pictures of it off tomorrow. I'm really hoping that the gasket just blew out somewhat on cylinder 4. That would explain my very infrequent white smoke I was getting last year. It only did it when I would really be getting on it. The head might be able to go without resurfacing. It should only have about 20,000 miles on it. I got a hold of the owner that was parting it out, and he claimed to put a new head on at 140,000 miles. If it does end up needing resurfacing, it will only be around $30 anyways. Win win situation for me.
                            Updates tomorrow=)
                              Wait a minute. How wide are those rims?
                                I don't have rims...My wheels are 9.5's and 10's.
                                  I have some mad tyte Veee-DUBBB rimz.  Dey fo-teenz.
                                  Also, you got me high with that paint.  Uncool bro.
                                    You know you liked it;)
                                      LOL. Sorry about that. Accident on my part. But that shall be quite a stretch. Does your local tire guy do it for you or what? the place i get tires mounted won't really do much stretch.
                                        Friends;)
                                          Friends;)
                                           I call BS. Friends don't let friends run stretched tires.
