    Purple would look crazy. Aren't you going with a silver flake?
      Yes. lol No flashy colors for me.
      http://www.powderbuythepound.com/SPARKLE_SILVER/
      I just want everything to look nice and simple. The lips will speak for themselves. I just want a car that looks nice and cleanly done.
        Should look damn good man! =]
          I did some small things yesterday.
          First, I ordered my tires. I opted for Hankook HR2's. I see that they have a pretty soft sidewall so they should stretch easily. I'm going for 205/40's in the front and 215/40's out back. I got them for $350 shipped to my door.
          I also found out that the lips are in stock and I am placing my order asap. These wheels will be together way faster than I had thought.
          I've been contemplating making a set of all red tails. I then remembered that I am getting a NOS set of amber tails. I figured since my current tails have some minor spider cracking, why not hit them with some model paint? So I did. I used Testors 1605 Candy Apple Red paint with Testors clear. They turned out really well. I just need to wetsand and buff them.
          Started off by masking them off:
          I then layed a nice even coat of red. Somehow it only took me one coat to achieve the color that I needed, and I had no runs.
          I removed the tape on this one to ensure that it matched well. I also wanted to compare a before and after.
          It looks slightly off in the pictures due to it being a more matte finish at the moment, and I couldn't get a heads on shot.
          I then taped up the second light to be able to shoot color and clear right after one another.
          Then I just buried them in clear with a heavy coat. I wanted to put enough on to make a nice thick layer, but have no runs. It worked out really well.
          I'm going to let them dry for a day or two, and then do the wet sanding and buffing.
          Hopefully I'll get something done at the shop tonight too. I can't think of much to do without a wire wheels for the bay, and any of my rear subframe or paint. haha I'll update again tomorrow.
            should have left the reverse light panel white. Looks 10x cleaner. :)  But they look good man. I wanna do this to the E28 eventually.
              Not a fan of leaving the reverse light white. Looks like a Turd in a punch bowl to me. Sticks out too much. I'm going to make another set all amber on the top too.
              • merlM
                merlM
                merl
                No  :mad:  ....
                I kid ... I really like the factory tails on the e28 though... .
                  merl said:
                  No  :mad:  ....
                  E28 tails do look good. I've never seen them all red.
                    I just hate the bottom halfs 3 different patterns, and the yellow turn signal kills it for me.
                      Here you go e28ers.
                      http://www.mye28.com/viewtopic.php?t=88388
                        All those tail lights look like shit. Especially the cleared turn signals. Those are such botch job's its appalling.
                          There is a picture of all reds you Dork. Lol
                          • StewCrewS
                            StewCrewS
                            StewCrew
                            Those all red e28 lights look sweet! Theres so much red tail light tinting going on around here, I love it! You're are lookin top-notch sir.
                              Thanks good buddy. Hopefully more so after Saturday.
                              I didn't go out to the shop yesterday because I couldn't figure out what I would do. I instead went home and finished the headlights. I also got the tail lights almost finished. They just need to be wet sanded and buffed=) I didn't get any pictures of the other head light finished, but I did get a picture of the tail lights.
                              Updates will follow Saturday.
                                Waiting for Jake to wake so that we can do some painting:P I'm going to nap in my car until he comes.
                                  Are you going to paint anything that differentiates power, white?
                                    Bahaha no
                                      I got a little done Saturday.
                                      I started the day by tearing into my motor a little more. I removed the upper timing cover and water pump. I tried extracting the water pump using two bolts to push it out, but ended up braking the ears off. Then I just shook the crap out of it until it popped out.
                                      Then I got working on my rear subframe yet again.
                                      The hardest thing was getting the handbrake cable ends out of the trailing arms. They were basically fused together. I used a pneumatic chisel on one, and had to drill the other one out. I didn't get any pictures. I then degreased everything, washed it, and dried it with an air nozzle. I then threw down a coat of Rust Reformer to try and prevent rust in the future. (These pictures turned out horrible)
                                      Then shenanigans ensued and come skating was done. I managed to snap the tail off of my board and continued to rid it until I snapped the nose off. Then I focused it.
                                      I then finally got actual paint on the parts. The diff, hubs, and dust shield will be black. I did not have any black at the time. I will also be clear coating it all. The color is a champagne tinted silver. The picture of the subframe is the most accurate portrayal of the color.
                                      Wednesday I will be pulling the head off of the motor and taking it to get resurfaced. The flywheel will be getting done too. I need to start ording a lot of parts. I need a ton of little things for the motor, as well as brake lines for the rear.
                                      • johnprusinskiJ
                                        johnprusinskiJ
                                        johnprusinski
                                        i like how that subframe turned out. it looks really good.
                                          Me too. It needs clear this Saturday=)
