  4. my E30 story
my E30 story
205 Posts 14 Posters 0 Views 1 Watching
  • johnprusinskiJ
    johnprusinskiJ
    johnprusinski
    i think im going to buy some metal from work tomorrow. ill try one door and if i like it ill do the other one.
      Make a cardboard cut out, and give it to me when you are done ;)
        http://www.trackhq.com/forums/f337/bmw-325i-e30-track-race-car-build-hx40-4719/
        look at this guys center thing. I think that is what im going to make.
          Rowley, you're forgetting you drive a 4 door E30, not a 2 door.
            yes? There is no difference.
              nevermind. I see what you are saying. I thought you were talking about my center dash thing, Not the doors. Good point.
              • johnprusinskiJ
                johnprusinskiJ
                johnprusinski
                ill see what i come up with tomorrow for the template.
                • johnprusinskiJ
                  johnprusinskiJ
                  johnprusinski
                  I got my spark plug wires today. The only problem is, that i don't know where which wire goes to which on the distributer cap.
                  • StewCrewS
                    StewCrewS
                    StewCrew
                    Google the firing order. If I was at the shop I could tell you 😕
                    • johnprusinskiJ
                      johnprusinskiJ
                      johnprusinski
                      Searching right now.
                        the firing order is 1-5-3-6-2-4 and the distributor rotor rotates clockwise. Cylinder 1 is nearest to the drive belts. If you aren't able to get the wires figured out between now and noon tomorrow I can take a picture/jot down what it is on my car.
                        • johnprusinskiJ
                          johnprusinskiJ
                          johnprusinski
                          I still don't get it. Everything says the cap is numbered. I think I got the only one that does have numbers.
                            The numbers would be here
                            ________5__3_6__2
                            _________1__C_ 4__
                            Based off the image with the cap numbers. I will make a guess and say the wires go in this order ^^^^
                            (Sorry if the formatting is screwed up and it doesnt make sense)
                            • johnprusinskiJ
                              johnprusinskiJ
                              johnprusinski
                              I found a picture. There were no numbers on it I swear. I got it to work and the car seems back to normal.
                                yay, so it runs?!
                                • johnprusinskiJ
                                  johnprusinskiJ
                                  johnprusinski
                                  Yeah, it runs pretty well
                                  • johnprusinskiJ
                                    johnprusinskiJ
                                    johnprusinski
                                    Update, I tried getting the diff out today, but I don't feel like taking out the driveshaft right now, and my heat is running out. I'll try and tackle it tomorrow if I feel like it.
                                    • StewCrewS
                                      StewCrewS
                                      StewCrew
                                      And so it starts ;)
                                      • johnprusinskiJ
                                        johnprusinskiJ
                                        johnprusinski
                                        Hahaha jake you need to come motivate me with beer now.
                                        • StewCrewS
                                          StewCrewS
                                          StewCrew
                                          If only I could tag Joe somehow...
