  4. 06 325i Rear Wheel Bearing???
17 Posts 5 Posters 195 Views 1 Watching
    If it is a wheel bearing it should get quieter when weight is off that wheel. For example if the left bearing is bad, the sound will get less prominent when turning left. Unevenly worn tires can make noise like you are describing as well, especially if your running snow tires.
      Also, with it getting warmer out, the snow tires will make more of a whurring noise...  Didn't even think of that till you mentioned it TJ, good call!
      • SnyperxS
        SnyperxS
        Snyperx
        Well when I went to pick the kiddos up from school today I kinda weaved back and forth on the road at about 55. You could really hear the "whrrr" sound when I would turn the wheel to the right. I was going to put the Summer tires back on and see if their is a difference. It is just odd that it seemed to start in the last week. I had not noticed the sound up until then.
          Check tires first. you might have screwed up tires, with crazy wear pattern.
          • SnyperxS
            SnyperxS
            Snyperx
            I am curious, how long to the bearings last on BMW's on average?
              It's a toss up. I've heard the ones in the rear go faster, due to the camber.. But who knows. I guarantee my E28 still has the original bearings in it!
              • SnyperxS
                SnyperxS
                Snyperx
                I suppose I should add this as well. I run spacers. I have 18mm in the rear and 12mm in the front. Can that be an issue for pre-mature bearing failure? I have since taken them off however.
                • 9
                  9
                  92e36
                  Another way to check the wheel bearing is if you Jack the one side up off the ground grab the tire and if you can move it up and down or side to side that's a good way to make sure that it is the wheel bearing.
                  • 9
                    9
                    92e36
                    And I have the wheel bearing tool also I had to reduce both my wheel bearings last summer so I went out and bought it.
                    • SnyperxS
                      SnyperxS
                      Snyperx
                      UPDATE: Well I swapped my Winter tires for the Summer tires. During that process before taking the wheel off I grabbed each wheel at 12/6 and 9/3 and push/pulled at each position. The rear passenger wheel had a bit of play in it. Specifically it had play if I push/pulled from the 12 o'clock position.
                      Would it be safe to assume that I have found my bad wheel bearing in the rear passenger side??
                        Yeah if it moves in any direction then the bearing is bad or going.
                        • SnyperxS
                          SnyperxS
                          Snyperx
                          Would it be best to replace both bearings?
                          • 9
                            9
                            92e36
                            I would based on experience they seem to go at about the same time just like headlights they are usually changed at the same time.
                              If you're gunna do both, prepare for a day or two (pending on how hardcore you wanna be) of the car to be down. I normally take awhile on my own car, cause I'm a pussy. But when it comes to working on other peoples cars, I can fly through stuff. But doing 2 wheel bearings, (depending on your mechanical/hands on level) can take a while.. So if you have a back up vehicle for DD/grabbing parts. That'd be super helpful!
                              • SnyperxS
                                SnyperxS
                                Snyperx
                                I am planning on 6 -8 hours for both bearings. I do have access to a full hoist and tools, so that will be helpful. I will have all the parts pre-ordered and available. I am ordering 2 bearings, collar nuts, and clips. I may buy a couple of extra bolts for the half shafts just in case.
