<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[06 325i Rear Wheel Bearing???]]></title><description><![CDATA[<p dir="auto">Hi all!! Its been awhile. So I was driving home the other day and heard a "whrrrrr" sound coming from the back end of my car. It seemed to change pitch with speed and was most noticeable at around 40 mph. My initial diagnosis is a rear wheel bearing. The rear diff should be good considering I just did the fluid in that back in October using Redline. The car is about to click to 85k miles. If it is a bearing, does anyone on here happen to have the BMW tool for working on the rear bearings? Would be willing to pay to rent it for a weekend.  Thanks gang!!</p>
]]></description><link>https://wibimmers.com/topic/1241/06-325i-rear-wheel-bearing</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 05:46:59 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/1241.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 08 Mar 2013 14:54:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 06 325i Rear Wheel Bearing??? on Mon, 18 Mar 2013 17:16:17 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/18334">Brian said:</a></strong></p>
<p dir="auto">If you're gunna do both, prepare for a day or two (pending on how hardcore you wanna be) of the car to be down. I normally take awhile on my own car, cause I'm a pussy. But when it comes to working on other peoples cars, I can fly through stuff. But doing 2 wheel bearings, (depending on your mechanical/hands on level) can take a while.. So if you have a back up vehicle for DD/grabbing parts. That'd be super helpful!</p>
<p dir="auto">=]</p>
<p dir="auto">I am planning on 6 -8 hours for both bearings. I do have access to a full hoist and tools, so that will be helpful. I will have all the parts pre-ordered and available. I am ordering 2 bearings, collar nuts, and clips. I may buy a couple of extra bolts for the half shafts just in case.</p>
]]></description><link>https://wibimmers.com/post/18386</link><guid isPermaLink="true">https://wibimmers.com/post/18386</guid><dc:creator><![CDATA[Snyperx]]></dc:creator><pubDate>Mon, 18 Mar 2013 17:16:17 GMT</pubDate></item><item><title><![CDATA[Reply to 06 325i Rear Wheel Bearing??? on Sun, 17 Mar 2013 02:48:30 GMT]]></title><description><![CDATA[<p dir="auto">If you're gunna do both, prepare for a day or two (pending on how hardcore you wanna be) of the car to be down. I normally take awhile on my own car, cause I'm a pussy. But when it comes to working on other peoples cars, I can fly through stuff. But doing 2 wheel bearings, (depending on your mechanical/hands on level) can take a while.. So if you have a back up vehicle for DD/grabbing parts. That'd be super helpful!</p>
]]></description><link>https://wibimmers.com/post/18334</link><guid isPermaLink="true">https://wibimmers.com/post/18334</guid><dc:creator><![CDATA[Brian.]]></dc:creator><pubDate>Sun, 17 Mar 2013 02:48:30 GMT</pubDate></item><item><title><![CDATA[Reply to 06 325i Rear Wheel Bearing??? on Sat, 16 Mar 2013 07:02:51 GMT]]></title><description><![CDATA[<p dir="auto">I would based on experience they seem to go at about the same time just like headlights they are usually changed at the same time.</p>
]]></description><link>https://wibimmers.com/post/18317</link><guid isPermaLink="true">https://wibimmers.com/post/18317</guid><dc:creator><![CDATA[92e36]]></dc:creator><pubDate>Sat, 16 Mar 2013 07:02:51 GMT</pubDate></item><item><title><![CDATA[Reply to 06 325i Rear Wheel Bearing??? on Fri, 15 Mar 2013 01:44:11 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/18243">CYoung said:</a></strong></p>
<p dir="auto">Yeah if it moves in any direction then the bearing is bad or going. </p>
<p dir="auto">Would it be best to replace both bearings?</p>
]]></description><link>https://wibimmers.com/post/18245</link><guid isPermaLink="true">https://wibimmers.com/post/18245</guid><dc:creator><![CDATA[Snyperx]]></dc:creator><pubDate>Fri, 15 Mar 2013 01:44:11 GMT</pubDate></item><item><title><![CDATA[Reply to 06 325i Rear Wheel Bearing??? on Fri, 15 Mar 2013 01:37:51 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/18234">Snyperx said:</a></strong></p>
<p dir="auto">Would it be safe to assume that I have found my bad wheel bearing in the rear passenger side??</p>
<p dir="auto">Yeah if it moves in any direction then the bearing is bad or going.</p>
]]></description><link>https://wibimmers.com/post/18243</link><guid isPermaLink="true">https://wibimmers.com/post/18243</guid><dc:creator><![CDATA[YoungCR]]></dc:creator><pubDate>Fri, 15 Mar 2013 01:37:51 GMT</pubDate></item><item><title><![CDATA[Reply to 06 325i Rear Wheel Bearing??? on Thu, 14 Mar 2013 22:06:03 GMT]]></title><description><![CDATA[<p dir="auto">UPDATE: Well I swapped my Winter tires for the Summer tires. During that process before taking the wheel off I grabbed each wheel at 12/6 and 9/3 and push/pulled at each position. The rear passenger wheel had a bit of play in it. Specifically it had play if I push/pulled from the 12 o'clock position.</p>
]]></description><link>https://wibimmers.com/post/18234</link><guid isPermaLink="true">https://wibimmers.com/post/18234</guid><dc:creator><![CDATA[Snyperx]]></dc:creator><pubDate>Thu, 14 Mar 2013 22:06:03 GMT</pubDate></item><item><title><![CDATA[Reply to 06 325i Rear Wheel Bearing??? on Sat, 09 Mar 2013 19:18:43 GMT]]></title><description><![CDATA[<p dir="auto">And I have the wheel bearing tool also I had to reduce both my wheel bearings last summer so I went out and bought it.</p>
]]></description><link>https://wibimmers.com/post/17995</link><guid isPermaLink="true">https://wibimmers.com/post/17995</guid><dc:creator><![CDATA[92e36]]></dc:creator><pubDate>Sat, 09 Mar 2013 19:18:43 GMT</pubDate></item><item><title><![CDATA[Reply to 06 325i Rear Wheel Bearing??? on Sat, 09 Mar 2013 19:15:17 GMT]]></title><description><![CDATA[<p dir="auto">Another way to check the wheel bearing is if you Jack the one side up off the ground grab the tire and if you can move it up and down or side to side that's a good way to make sure that it is the wheel bearing.</p>
]]></description><link>https://wibimmers.com/post/17994</link><guid isPermaLink="true">https://wibimmers.com/post/17994</guid><dc:creator><![CDATA[92e36]]></dc:creator><pubDate>Sat, 09 Mar 2013 19:15:17 GMT</pubDate></item><item><title><![CDATA[Reply to 06 325i Rear Wheel Bearing??? on Sat, 09 Mar 2013 17:08:41 GMT]]></title><description><![CDATA[<p dir="auto">I suppose I should add this as well. I run spacers. I have 18mm in the rear and 12mm in the front. Can that be an issue for pre-mature bearing failure? I have since taken them off however.</p>
]]></description><link>https://wibimmers.com/post/17991</link><guid isPermaLink="true">https://wibimmers.com/post/17991</guid><dc:creator><![CDATA[Snyperx]]></dc:creator><pubDate>Sat, 09 Mar 2013 17:08:41 GMT</pubDate></item><item><title><![CDATA[Reply to 06 325i Rear Wheel Bearing??? on Sat, 09 Mar 2013 15:11:59 GMT]]></title><description><![CDATA[<p dir="auto">It's a toss up. I've heard the ones in the rear go faster, due to the camber.. But who knows. I guarantee my E28 still has the original bearings in it!</p>
]]></description><link>https://wibimmers.com/post/17989</link><guid isPermaLink="true">https://wibimmers.com/post/17989</guid><dc:creator><![CDATA[Brian.]]></dc:creator><pubDate>Sat, 09 Mar 2013 15:11:59 GMT</pubDate></item><item><title><![CDATA[Reply to 06 325i Rear Wheel Bearing??? on Sat, 09 Mar 2013 04:10:37 GMT]]></title><description><![CDATA[<p dir="auto">I am curious, how long to the bearings last on BMW's on average?</p>
]]></description><link>https://wibimmers.com/post/17985</link><guid isPermaLink="true">https://wibimmers.com/post/17985</guid><dc:creator><![CDATA[Snyperx]]></dc:creator><pubDate>Sat, 09 Mar 2013 04:10:37 GMT</pubDate></item><item><title><![CDATA[Reply to 06 325i Rear Wheel Bearing??? on Sat, 09 Mar 2013 03:09:13 GMT]]></title><description><![CDATA[<p dir="auto">Check tires first. you might have screwed up tires, with crazy wear pattern.</p>
]]></description><link>https://wibimmers.com/post/17983</link><guid isPermaLink="true">https://wibimmers.com/post/17983</guid><dc:creator><![CDATA[Brian.]]></dc:creator><pubDate>Sat, 09 Mar 2013 03:09:13 GMT</pubDate></item><item><title><![CDATA[Reply to 06 325i Rear Wheel Bearing??? on Fri, 08 Mar 2013 23:27:10 GMT]]></title><description><![CDATA[<p dir="auto">Well when I went to pick the kiddos up from school today I kinda weaved back and forth on the road at about 55. You could really hear the "whrrr" sound when I would turn the wheel to the right. I was going to put the Summer tires back on and see if their is a difference. It is just odd that it seemed to start in the last week. I had not noticed the sound up until then.</p>
]]></description><link>https://wibimmers.com/post/17977</link><guid isPermaLink="true">https://wibimmers.com/post/17977</guid><dc:creator><![CDATA[Snyperx]]></dc:creator><pubDate>Fri, 08 Mar 2013 23:27:10 GMT</pubDate></item><item><title><![CDATA[Reply to 06 325i Rear Wheel Bearing??? on Fri, 08 Mar 2013 22:26:26 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/17959">wasnt m3 said:</a></strong></p>
<p dir="auto">If it is a wheel bearing it should get quieter when weight is off that wheel. For example if the left bearing is bad, the sound will get less prominent when turning left. Unevenly worn tires can make noise like you are describing as well, especially if your running snow tires.</p>
<p dir="auto">Also, with it getting warmer out, the snow tires will make more of a whurring noise...  Didn't even think of that till you mentioned it TJ, good call!</p>
]]></description><link>https://wibimmers.com/post/17974</link><guid isPermaLink="true">https://wibimmers.com/post/17974</guid><dc:creator><![CDATA[Brian.]]></dc:creator><pubDate>Fri, 08 Mar 2013 22:26:26 GMT</pubDate></item><item><title><![CDATA[Reply to 06 325i Rear Wheel Bearing??? on Fri, 08 Mar 2013 17:11:53 GMT]]></title><description><![CDATA[<p dir="auto">If it is a wheel bearing it should get quieter when weight is off that wheel. For example if the left bearing is bad, the sound will get less prominent when turning left. Unevenly worn tires can make noise like you are describing as well, especially if your running snow tires.</p>
]]></description><link>https://wibimmers.com/post/17959</link><guid isPermaLink="true">https://wibimmers.com/post/17959</guid><dc:creator><![CDATA[wasnt m3]]></dc:creator><pubDate>Fri, 08 Mar 2013 17:11:53 GMT</pubDate></item><item><title><![CDATA[Reply to 06 325i Rear Wheel Bearing??? on Fri, 08 Mar 2013 16:41:35 GMT]]></title><description><![CDATA[<p dir="auto">Buy this: <a href="http://www.harborfreight.com/46-piece-bolt-puller-set-37824.html" rel="nofollow ugc">http://www.harborfreight.com/46-piece-bolt-puller-set-37824.html</a></p>
<p dir="auto">And appropriate sized washers, and pull it yourself.  I can find a 2 part how to video of how to do it if you'd like.</p>
<p dir="auto">The bearing tool is stupid expensive. And I know of only one person that has it, and his name is Kevin Schmitz.</p>
]]></description><link>https://wibimmers.com/post/17954</link><guid isPermaLink="true">https://wibimmers.com/post/17954</guid><dc:creator><![CDATA[Brian.]]></dc:creator><pubDate>Fri, 08 Mar 2013 16:41:35 GMT</pubDate></item></channel></rss>
