Wrench day?
sounds good! if anyone wants to swing by, please just let me know so I can be around when you do
Commencing diff swap and sway bar fix!
Best of luck!
success! new sway bar reinforcements installed and lower ratio diff!
no one came by, but heres what got done:
\ said:
Did some work today. Swapped to a lower lsd and finished up the sway bar fix. had Pat at Kummrow weld up a new tab the other day, so when I had the LSD out, it was the perfect time to get the sway bar bolted back in.
Bolt up new bracket and drill holes accordingly.
Bolt on. It is a tight squeeze, especially with this particular sway bar which is too short before it turns 90deg at the ends. Lots of cursing here.
The diff swap:
Jack car up (look at those tonka trunk sized tires!)
PB Blaster is your friend. Coat EVERYTHING.
From left, and the order which they get removed: 12 axle bolts, 4 driveshaft bolts, 2 upper rear subframe bolts, 2 upper front subframe bolts, bushing bolt.
be a man and drop the diff without the jack! (sandbag works great to catch it)
replacement LSD ready to go in.
Installation is the opposite of removal, only faster!
a 3.73 came out, but its going back to the guy i got the new one from. he might have a spare or two, i'm pretty sure he has a 2.93
nah those are Ireland engineering ones. probably would have chose another company's, but a local guy had these for sale with the correct bushing size.
