<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Wrench day?]]></title><description><![CDATA[<p dir="auto">Guys-</p>
<p dir="auto">Going to be tacking my LSD swap tomorrow (June 25th, Saturday) in my driveway. If anyone has a project they want to work on or need help with, you should come on by for a wrenching day! Its supposed to be warm and sunny. Will be working from 10am-? and could throw some brats on the grill for lunch. Let me know (you might have my number) by posting or PMing me.</p>
<p dir="auto">Dan</p>
]]></description><link>https://wibimmers.com/topic/161/wrench-day</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 05:32:57 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/161.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 24 Jun 2011 13:26:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Wrench day? on Tue, 28 Jun 2011 00:07:57 GMT]]></title><description><![CDATA[<p dir="auto">nah those are Ireland engineering ones. probably would have chose another company's, but a local guy had these for sale with the correct bushing size.</p>
]]></description><link>https://wibimmers.com/post/1757</link><guid isPermaLink="true">https://wibimmers.com/post/1757</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Tue, 28 Jun 2011 00:07:57 GMT</pubDate></item><item><title><![CDATA[Reply to Wrench day? on Mon, 27 Jun 2011 23:20:29 GMT]]></title><description><![CDATA[<p dir="auto">Groovy, I like your sway bar reinforcements. Custom-made? I haven't seen them before. I'd rather bolt something in like that than weld.</p>
]]></description><link>https://wibimmers.com/post/1756</link><guid isPermaLink="true">https://wibimmers.com/post/1756</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Mon, 27 Jun 2011 23:20:29 GMT</pubDate></item><item><title><![CDATA[Reply to Wrench day? on Mon, 27 Jun 2011 22:16:57 GMT]]></title><description><![CDATA[<p dir="auto">a 3.73 came out, but its going back to the guy i got the new one from. he might have a spare or two, i'm pretty sure he has a 2.93</p>
]]></description><link>https://wibimmers.com/post/1755</link><guid isPermaLink="true">https://wibimmers.com/post/1755</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Mon, 27 Jun 2011 22:16:57 GMT</pubDate></item><item><title><![CDATA[Reply to Wrench day? on Mon, 27 Jun 2011 19:21:01 GMT]]></title><description><![CDATA[<p dir="auto">What diff went in? and what came out? My diff is just a wheelspin away from pooping the bed and I need to have my eye out for a replacement.</p>
]]></description><link>https://wibimmers.com/post/1753</link><guid isPermaLink="true">https://wibimmers.com/post/1753</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Mon, 27 Jun 2011 19:21:01 GMT</pubDate></item><item><title><![CDATA[Reply to Wrench day? on Mon, 27 Jun 2011 08:03:56 GMT]]></title><description><![CDATA[<p dir="auto">Damn if I wouldve seen this I wouldve swung by...</p>
]]></description><link>https://wibimmers.com/post/1744</link><guid isPermaLink="true">https://wibimmers.com/post/1744</guid><dc:creator><![CDATA[MikoPR]]></dc:creator><pubDate>Mon, 27 Jun 2011 08:03:56 GMT</pubDate></item><item><title><![CDATA[Reply to Wrench day? on Sat, 25 Jun 2011 23:14:53 GMT]]></title><description><![CDATA[<p dir="auto">no one came by, but heres what got done:</p>
<p dir="auto"><strong>\ said:</strong></p>
<p dir="auto">Did some work today. Swapped to a lower lsd and finished up the sway bar fix. had Pat at Kummrow weld up a new tab the other day, so when I had the LSD out, it was the perfect time to get the sway bar bolted back in.</p>
<p dir="auto">Bolt up new bracket and drill holes accordingly.</p>
<p dir="auto"><img src="http://img845.imageshack.us/img845/3559/sway1.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto">Bolt on. It is a tight squeeze, especially with this particular sway bar which is too short before it turns 90deg at the ends. Lots of cursing here.</p>
<p dir="auto"><img src="http://img33.imageshack.us/img33/1129/sway2g.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://img97.imageshack.us/img97/4816/sway3.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto">The diff swap:</p>
<p dir="auto">Jack car up (look at those tonka trunk sized tires!)</p>
<p dir="auto"><img src="http://img20.imageshack.us/img20/1183/lsd1a.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto">PB Blaster is your friend. Coat EVERYTHING.</p>
<p dir="auto"><img src="http://img860.imageshack.us/img860/710/lsd2.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto">From left, and the order which they get removed: 12 axle bolts, 4 driveshaft bolts, 2 upper rear subframe bolts, 2 upper front subframe bolts, bushing bolt.</p>
<p dir="auto"><img src="http://img863.imageshack.us/img863/5691/lsd3.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto">be a man and drop the diff without the jack! (sandbag works great to catch it)</p>
<p dir="auto"><img src="http://img818.imageshack.us/img818/6378/lsd4.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto">replacement LSD ready to go in.</p>
<p dir="auto"><img src="http://img534.imageshack.us/img534/6066/lsd5.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto">Installation is the opposite of removal, only faster!</p>
]]></description><link>https://wibimmers.com/post/1726</link><guid isPermaLink="true">https://wibimmers.com/post/1726</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Sat, 25 Jun 2011 23:14:53 GMT</pubDate></item><item><title><![CDATA[Reply to Wrench day? on Sat, 25 Jun 2011 20:16:20 GMT]]></title><description><![CDATA[<p dir="auto">success! new sway bar reinforcements installed and lower ratio diff!</p>
]]></description><link>https://wibimmers.com/post/1725</link><guid isPermaLink="true">https://wibimmers.com/post/1725</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Sat, 25 Jun 2011 20:16:20 GMT</pubDate></item><item><title><![CDATA[Reply to Wrench day? on Sat, 25 Jun 2011 15:24:56 GMT]]></title><description><![CDATA[<p dir="auto">Best of luck!</p>
]]></description><link>https://wibimmers.com/post/1722</link><guid isPermaLink="true">https://wibimmers.com/post/1722</guid><dc:creator><![CDATA[Celina325is]]></dc:creator><pubDate>Sat, 25 Jun 2011 15:24:56 GMT</pubDate></item><item><title><![CDATA[Reply to Wrench day? on Sat, 25 Jun 2011 15:10:32 GMT]]></title><description><![CDATA[<p dir="auto">Commencing diff swap and sway bar fix!</p>
]]></description><link>https://wibimmers.com/post/1721</link><guid isPermaLink="true">https://wibimmers.com/post/1721</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Sat, 25 Jun 2011 15:10:32 GMT</pubDate></item><item><title><![CDATA[Reply to Wrench day? on Sat, 25 Jun 2011 04:23:16 GMT]]></title><description><![CDATA[<p dir="auto">sounds good! if anyone wants to swing by, please just let me know so I can be around when you do</p>
]]></description><link>https://wibimmers.com/post/1714</link><guid isPermaLink="true">https://wibimmers.com/post/1714</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Sat, 25 Jun 2011 04:23:16 GMT</pubDate></item><item><title><![CDATA[Reply to Wrench day? on Sat, 25 Jun 2011 03:40:20 GMT]]></title><description><![CDATA[<p dir="auto">alrighty. Id love to come. except I found out I has to work tomorrow... So now I cant... sucks when you owe money lol</p>
]]></description><link>https://wibimmers.com/post/1712</link><guid isPermaLink="true">https://wibimmers.com/post/1712</guid><dc:creator><![CDATA[Chadley]]></dc:creator><pubDate>Sat, 25 Jun 2011 03:40:20 GMT</pubDate></item><item><title><![CDATA[Reply to Wrench day? on Sat, 25 Jun 2011 02:17:25 GMT]]></title><description><![CDATA[<p dir="auto">7mm allen should suffice? have star sockets, but not hex. i have plenty of tools, i have maintained my e30s for 8 or so years now mostly on my own. calipers/brakes are not a problem.</p>
]]></description><link>https://wibimmers.com/post/1707</link><guid isPermaLink="true">https://wibimmers.com/post/1707</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Sat, 25 Jun 2011 02:17:25 GMT</pubDate></item><item><title><![CDATA[Reply to Wrench day? on Fri, 24 Jun 2011 23:06:03 GMT]]></title><description><![CDATA[<p dir="auto">Just wondering how well you were on tools. I may/may not be putting new calipers on the front soon, which requires a 7mm hex socket for me. Not a complicated job but I much prefer wrenching with pals over wrenching alone</p>
]]></description><link>https://wibimmers.com/post/1699</link><guid isPermaLink="true">https://wibimmers.com/post/1699</guid><dc:creator><![CDATA[Chadley]]></dc:creator><pubDate>Fri, 24 Jun 2011 23:06:03 GMT</pubDate></item><item><title><![CDATA[Reply to Wrench day? on Fri, 24 Jun 2011 18:33:28 GMT]]></title><description><![CDATA[<p dir="auto">Next on my list is to fix my AC/Blower motor. Add freon, replace blower motor, replace resistor, cross fingers. I just rolled over 200k miles and am still looking for things to replace. Also in the mail right now is a Fuel filter, hood supports, and I want to flush/replace the coolant, transfluid, diff fluid, brake fluid. Any other suggestions?</p>
]]></description><link>https://wibimmers.com/post/1688</link><guid isPermaLink="true">https://wibimmers.com/post/1688</guid><dc:creator><![CDATA[Celina325is]]></dc:creator><pubDate>Fri, 24 Jun 2011 18:33:28 GMT</pubDate></item><item><title><![CDATA[Reply to Wrench day? on Fri, 24 Jun 2011 15:17:36 GMT]]></title><description><![CDATA[<p dir="auto">yup. i dont have specialized tools like timing, diagnostics, fancy pullers, etc but there is a parts store a few minutes from my house where additional tools can be rented. what did you have in mind?</p>
]]></description><link>https://wibimmers.com/post/1686</link><guid isPermaLink="true">https://wibimmers.com/post/1686</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Fri, 24 Jun 2011 15:17:36 GMT</pubDate></item><item><title><![CDATA[Reply to Wrench day? on Fri, 24 Jun 2011 14:41:28 GMT]]></title><description><![CDATA[<p dir="auto">How well acquainted with tools are you? IE, you have more than just the 59pc kit, right?</p>
]]></description><link>https://wibimmers.com/post/1685</link><guid isPermaLink="true">https://wibimmers.com/post/1685</guid><dc:creator><![CDATA[Chadley]]></dc:creator><pubDate>Fri, 24 Jun 2011 14:41:28 GMT</pubDate></item></channel></rss>
