  4. Build thread/running log of my E28? Guess I can do eet.
553 Posts 22 Posters 7.0k Views 2 Watching
    Basically. I wouldn't be ordering BRAND NEW OEM fenders for my car, if they were everywhere. That's the complete opposite with E30's. Abundance of them
    • StewCrewS
      StewCrewS
      StewCrew
      Yeah, go to Gibsons. Last time I was there, there was at least 5 e30's.
      Where is this "Gibsons" you speak of? Im could also go for some parts
        Neenah
          Neenah/Appleton area. 3 hour drive for you mang.
          ALSO, found out what the problem was on the E28 finally. WHEEL BEARING :(
          $100 in parts. And of course, a super special tool ($400 tool) is needed to do the replacement... Awesome. Fuck me right.
          • StewCrewS
            StewCrewS
            StewCrew
            Neenah
            Worth it.
              $100 in parts? Do you know what Rock Auto is? Special tool? You mean a bearing press?
                If its a front bearing buy it pre-pressed into the hub, rent a 3-jaw puller to remove it and use the axle nut to drive it back on.
                If its a rear, then Auto Zone has Timken bearings for ~$54 each for BMWs. I spent about $9 worth of nuts, washers, and threaded rod to make my own tool to press the new bearing in.
                  I need you to write a book for me sir.
                    Rear bearing. An Earl, it's alot easier with the special tool. We'll see. I gotta talk to J-design, see if I can snag a spot in his shop this weekend, and snag a few hours at his work..
                      Also Earl, rock auto's prices are the same/little more for alot of stuff... sadly.
                        I've never encountered that issue. Everything I have ever needed was about half or less than what it costs anywhere else.
                          Me too. That place is the shit.
                            Rock Auto must dislike e28's:P lol
                              Maybe, because E28's are rarer then E30's.. Possibility yeah.
                                Most of my e21 parts are less than other places offer them. I'm sure they are just as rare, no? :P
                                  Who the hell knows. Either way, their prices aren't a big difference.
                                    Holy shit, found basically the best how to on this wheel bearing, with no special tools. EPIC.
                                    (removal)
                                    (Installation)
                                      the internet is a majestic place.
                                        Yeah, I'm also being told that the reason my half shaft is sticking out a bit from the diff, is a snap ring, that's causing my entire problem.. I'm fucking LOST.
                                          Posted Image
                                          Diff is on the leftside, pass side half shaft is on the right. gap is between the half shaft and the diff.
