  4. My Bixenon retrofit (E30)
32 Posts 8 Posters 506 Views 1 Watching
  • M
    M
    merton 0
    looks good man!
    Now go and clear out your inbox. I can't reply to your PM because your inbox is full...
    • alexwA
      alexwA
      alexw
      Nice! I may have to get you to hook me up with a set ;)
      alexw
      332ti - Work in Progress
        merton said:
        looks good man!
        all clear, sorry about that.
        alex- this is a long procedure. it was about 5 hours to do that one projector.
        • T
          T
          tsweers89
          Did this retrofit to my e34. I first had tsx porjectors, 35W Ballasts and wiring from TRS then got Philips 85122 D2S bulbs off ebay. But after having that for 3 years, I wanted a little whiter output so I went with 55w 5000K. Which is as bright as the 35W and the Philips, just a tad whiter. Now went to s2000 ap2 projectors with the color mod. Def can see the diffrence between the 2 projectors outputs. You should of went with s2000 projectors for best output but fx-r is still night and day difference compared to just an aftermarket hid set-up.
            yeah i know there are a couple of options out there which are slightly brighter or a bit smoother, but thats why i went with the 50w 4300k setup to compensate. value and the bi-xenon were important.
            • T
              T
              tsweers89
              35w to 55w set up is hardly noticeable as far as better output goes. But to each there own. Good work none the less.
                thanks. got the other projector done today:
                copy the first projector cuts with tape:
                Posted Image
                done:
                Posted Image
                splice plugs for solenoids to plug straight into high beam plugs:
                Posted Image
                Posted Image
                here is the wiring harness the kit comes with. works great, but the main power and ground wires are too short.
                Posted Image
                here the power and ground wires have been lengthened to run up the passenger fender and connect directly to the chassis power/ground.
                Posted Image
                going out to test fire them in a few minutes.
                  lights fired up great except one ballast is flickering (will call to get it replaced) but they are going to level out just fine, so next step is permanently sealing them. i love the color, it is a true 4300k it is white but more toward yellow than blue from up close so its not a big attention getter. cut off is super sharp, the solenoids fired up the high beam function really well.
                  lows: (note these have not been aimed yet)
                  Posted Image
                  highs:
                  Posted Image
                    decided how i was going to seal it up today. i wanted to use a fiberglass kit and glass it in, but the two negatives of that are 1)fiberglass resin doesnt stick to plastic very well and 2)its a fairly permanent cover so if I ever needed to take them apart, i would be heavily cursing. also, after researching aluminum foil tape, i'm quite impressed with the stuff. i'd call it 'duct tape on crack'.
                    depending on which version you get, it has a heat range from -25deg to 325deg, is 100% waterproof, has 'aggressive' adhesive, and can even be applied under water. good enough for me.
                    so i bought the tape ($18/roll) and the silicone sealant (good to 400deg or something) and applied the sealant today. it will have to dry 24hrs before i apply the tape.
                    Posted Image
                    Posted Image
                    • M
                      M
                      MikoPR
                      I beg to differ the 55w over power the bulb making a crisper white and leaving out some of the blue. Much better in my opinion.
                      • T
                        T
                        tsweers89
                        Very true, i do not diasagree. Im saying output differences are slim to none.
                          headlights are installed! heres what all was finished:
                          Finished sealing up the projectors with aluminum foil tape:
                          Posted Image
                          The headlight bucket had to be slightly trimmed to fit one of the brackets I added to secure the projector.
                          Posted Image
                          Install into the bucket:
                          Posted Image
                          Installing the lights into the car
                          Take out your headlights and the plastic sheilds on the back:
                          Posted Image
                          Get your harness and your beer ready:
                          Posted Image
                          Installed the ballasts behind the headlights. There are big ass ballasts, but they fit along side just fine
                          Posted Image
                          Posted Image
                          Heres where I attached the harness for the main power (13V constant as shown with voltmeter):
                          Posted Image
                          And the ground:
                          Posted Image
                          Neatly run the harness down the engine bay:
                          Posted Image
                          Seal up the relay to keep water out of it as it ends up by the ballasts/headlights:
                          http://img32.imageshack.us/img32/7735/relay1.jpg
                          Run the plug for the drivers side across the body with the other factory wires which cross behind the front valance right under the grill:
                          http://img851.imageshack.us/img851/7692/harness1b.jpg
                          Heres all the plugs youll end up with for the lights. This is everything except the city light (if you have euro-spec lights)
                          http://img684.imageshack.us/img684/5628/wiring1.jpg
                          Headlights installed:
                          http://img818.imageshack.us/img818/6475/installed1.jpg
                          Aiming the headlights:
                          Draw your diagram (or use tape if you dont want to deface someones property) according to http://www.danielsternlighting.com/tech/aim/aim.html
                          The cross is the exact location of the lights on the car, the bottom line is 2.1 inches below and is where the cuttoff should land.
                          http://img189.imageshack.us/img189/7734/aiming1.jpg
                          Back the car up 25ft
                          http://img854.imageshack.us/img854/3596/aiming2.jpg
                          http://img696.imageshack.us/img696/5274/aiming3.jpg
                          Where the lights landed before aiming
                          http://img268.imageshack.us/img268/6023/aiming4.jpg
                          Headlights aimed properly.
                          http://img15.imageshack.us/img15/4184/aiming5.jpg
                          Very happy with how bright they are. Whatever flickering that was happening when first tested is gone. Will post some output pictures when I get the chance.
                            Clean install and nice write up! This is on the to do list for sure. I just need to do some more research.
                              Thanks. this is the #1 mod to do to old cars with old headlights. the beam pattern is wide enough to span across all 3 lanes on the freeway plus onto the shoulders
                              • T
                                T
                                tsweers89
                                Just finished my new retrofit. Hella euro ellipsoids w/ s2000 projectors. Have yet to put them in but fired one up in the house yesterday just to see the output.
                                Posted Image
                                • mystere30M
                                  mystere30M
                                  mystere30
                                  winnnnnnnnnnnnnnnnnnnnnnnnnn
                                    Which projectors are better? s2000 or fx-r's?
                                    /this is me not doing research...
                                    • T
                                      T
                                      tsweers89
                                      Moliter you need to bring your car over by Scott sometime so i can check it out. Hopefully it is better than your m3 was.
                                      s2000 are better but are harder to fit due to their size. Here is a link to all you need to know:
                                      http://theeshadow.com/carmod/JVXdriver/beam_comparison.htm
                                        was going to say, most OEM HID projectors are going to be better, but that comes with a little more $ and more trouble installing versus the fx-r
                                        keep in mind also, the fx-r is a bixenon light, which means it has the low beam function plus a high beam in one unit. that is not the case with s2000
                                        • T
                                          T
                                          tsweers89
                                          This is true, but i have yet to say i wish i had bi-xenon when my low beam output is so good. Even with my tsx projectors i didn't have a problem.
