  4. My Bixenon retrofit (E30)
32 Posts 8 Posters 506 Views 1 Watching
  • T
    T
    tsweers89
    MikoPR said:
    I beg to differ the 55w over power the bulb making a crisper white and leaving out some of the blue. Much better in my opinion.
    Very true, i do not diasagree. Im saying output differences are slim to none.
      headlights are installed! heres what all was finished:
      Finished sealing up the projectors with aluminum foil tape:
      Posted Image
      The headlight bucket had to be slightly trimmed to fit one of the brackets I added to secure the projector.
      Posted Image
      Install into the bucket:
      Posted Image
      Installing the lights into the car
      Take out your headlights and the plastic sheilds on the back:
      Posted Image
      Get your harness and your beer ready:
      Posted Image
      Installed the ballasts behind the headlights. There are big ass ballasts, but they fit along side just fine
      Posted Image
      Posted Image
      Heres where I attached the harness for the main power (13V constant as shown with voltmeter):
      Posted Image
      And the ground:
      Posted Image
      Neatly run the harness down the engine bay:
      Posted Image
      Seal up the relay to keep water out of it as it ends up by the ballasts/headlights:
      http://img32.imageshack.us/img32/7735/relay1.jpg
      Run the plug for the drivers side across the body with the other factory wires which cross behind the front valance right under the grill:
      http://img851.imageshack.us/img851/7692/harness1b.jpg
      Heres all the plugs youll end up with for the lights. This is everything except the city light (if you have euro-spec lights)
      http://img684.imageshack.us/img684/5628/wiring1.jpg
      Headlights installed:
      http://img818.imageshack.us/img818/6475/installed1.jpg
      Aiming the headlights:
      Draw your diagram (or use tape if you dont want to deface someones property) according to http://www.danielsternlighting.com/tech/aim/aim.html
      The cross is the exact location of the lights on the car, the bottom line is 2.1 inches below and is where the cuttoff should land.
      http://img189.imageshack.us/img189/7734/aiming1.jpg
      Back the car up 25ft
      http://img854.imageshack.us/img854/3596/aiming2.jpg
      http://img696.imageshack.us/img696/5274/aiming3.jpg
      Where the lights landed before aiming
      http://img268.imageshack.us/img268/6023/aiming4.jpg
      Headlights aimed properly.
      http://img15.imageshack.us/img15/4184/aiming5.jpg
      Very happy with how bright they are. Whatever flickering that was happening when first tested is gone. Will post some output pictures when I get the chance.
        Clean install and nice write up! This is on the to do list for sure. I just need to do some more research.
          Thanks. this is the #1 mod to do to old cars with old headlights. the beam pattern is wide enough to span across all 3 lanes on the freeway plus onto the shoulders
          • T
            T
            tsweers89
            Just finished my new retrofit. Hella euro ellipsoids w/ s2000 projectors. Have yet to put them in but fired one up in the house yesterday just to see the output.
            Posted Image
            • mystere30M
              mystere30M
              mystere30
              winnnnnnnnnnnnnnnnnnnnnnnnnn
                Which projectors are better? s2000 or fx-r's?
                /this is me not doing research...
                • T
                  T
                  tsweers89
                  Moliter you need to bring your car over by Scott sometime so i can check it out. Hopefully it is better than your m3 was.
                  s2000 are better but are harder to fit due to their size. Here is a link to all you need to know:
                  http://theeshadow.com/carmod/JVXdriver/beam_comparison.htm
                    was going to say, most OEM HID projectors are going to be better, but that comes with a little more $ and more trouble installing versus the fx-r
                    keep in mind also, the fx-r is a bixenon light, which means it has the low beam function plus a high beam in one unit. that is not the case with s2000
                    • T
                      T
                      tsweers89
                      This is true, but i have yet to say i wish i had bi-xenon when my low beam output is so good. Even with my tsx projectors i didn't have a problem.
                        Good link Timmy. I think I'd go with the FX-R's just because of the $$ and bixenon feature. And I've read a couple of build threads with them being used. With my lack of research I'm following the crowd not blazing a new trail.
                        Better than the M3 was!?! Always hatin'. The paint on this one isn't anything to write home about but it's what's on the inside that counts!:D I just need to clean it up and clean up the engine bay a bit and bam!
                          putting a true HID retrofit on the e30 is pretty uncommon, and is pretty new ground as it is, no matter which kit you use.
                            It does look pretty invasive but I'm pretty handy. Is there enough room to retain the plastic covers in the engine bay behind the lights?
                              yes plenty. the fx-rs are actually smaller than the stock projectors.
                              • T
                                T
                                tsweers89
                                This is my finished product using s2000 projectors. This is in a e34 platform
                                http://farm6.static.flickr.com/5048/5361472547_3d0c428351_z.jpg
                                Why is it a link and not posting right here. wtf
                                • mystere30M
                                  mystere30M
                                  mystere30
                                  moar win ^^
                                    T.Sweererers, that photo is awesome, is that just low beams, or high beams?
                                    Do tell a bit about your setup on your E34, as I'm looking into upgrading the E28's with a ste of E34 projectors I have laying here.
                                      e34 projectors and e30 projectors are the same thing. (mounting tab locations are different due to platform, but its the same retro)
                                        I knew that much Dan, I was just asking about his, since his shot out in the country seems very bright, which is what I'm going for. I like the functionality of them
                                        • T
                                          T
                                          tsweers89
                                          Pic was with just the low beams on correct. Just used s2000 ap1 projectors in euro smiley projectors. Bulbs make all the difference to. All in all i have about $875invested in my set up because i bought new euro smileys direct from hella. Getting the projectors level in housings was the most pain. Thinking of selling them and going with some better projectors though.
