<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[My Bixenon retrofit (E30)]]></title><description><![CDATA[<p dir="auto">Hey guys thought I'd share this build with you all. I am putting some FX-R bixenon projectors into my e30. It will give the most possible light without going to some $2k military grade LED kit or some such thing. The light output is quite simply amazing. I went from standard halogen in my e30 to HID, and it was a huge jump, this will be a jump similar in scale from the HIDs.</p>
<p dir="auto">Parts:</p>
<p dir="auto">Depo smoked Euro Headlights (ordered from DTM Fiberwerkz)</p>
<p dir="auto">Bi-xenon Retrofit Kit Stage III (ordered from The Retrofit Source)</p>
<p dir="auto">-upgraded to Philips 85122+ DS2 bulbs with 50w ballasts</p>
<p dir="auto">Depo Smoked Euro Headlights (started dissasembly before I remembered to take photos)</p>
<p dir="auto"><img src="http://img263.imageshack.us/img263/4988/depos1.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://img848.imageshack.us/img848/8573/depos2.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://img853.imageshack.us/img853/8507/depos3.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://img534.imageshack.us/img534/2674/depos4.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto">The reason I got the Depos vs. real euro lights are 1)Gauranteed new condition 2)The glass in front of the projector is perfectly clear, no fresnel to botch up the perfect cutoff!</p>
<p dir="auto"><img src="http://img840.imageshack.us/img840/2637/whyiboughtdepos.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto">The FX-R projectors, harness, ballasts, etc</p>
<p dir="auto"><img src="http://img819.imageshack.us/img819/6825/bixenon1.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto">I will be converting these H1 HID bulbs to a marker type light for the high beams</p>
<p dir="auto"><img src="http://img542.imageshack.us/img542/6779/h1highmarker.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto">I took some time and modeled the parts in 3D so I could see how they would fit before I just started randomly hacking away. It gave me a better idea of what larger portions I could leave intact to add some support</p>
<p dir="auto"><img src="http://img810.imageshack.us/img810/7872/3dfit3.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://img846.imageshack.us/img846/6853/3dfit1.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://img848.imageshack.us/img848/2030/3dfit2.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto">Cutting away at the housing to make the projectors fit:</p>
<p dir="auto"><a href="http://img220.imageshack.us/img220/4047/fit1e.jpg" rel="nofollow ugc">http://img220.imageshack.us/img220/4047/fit1e.jpg</a></p>
<p dir="auto"><a href="http://img90.imageshack.us/img90/8004/fit2.jpg" rel="nofollow ugc">http://img90.imageshack.us/img90/8004/fit2.jpg</a></p>
<p dir="auto"><a href="http://img571.imageshack.us/img571/2113/fit3.jpg" rel="nofollow ugc">http://img571.imageshack.us/img571/2113/fit3.jpg</a></p>
<p dir="auto"><a href="http://img4.imageshack.us/img4/5601/fit4a.jpg" rel="nofollow ugc">http://img4.imageshack.us/img4/5601/fit4a.jpg</a></p>
<p dir="auto">Also did a quick attachment of the harness to car, and it worked like a charm! It comes with a relay which enables you to plug it into any main body power source, then plug one of the normal low beam plugs into the harness to act only as the switch instead of the power source. It was definately needed as the power getting to the low beam plug was not enough juice to fire the 50W ballast. Also plugged the high beam into the actuator on the bi-xenon and it flipped the cutoff up and down no prob.</p>
<p dir="auto">Next step is to seal up the projector then repeat on the other side. More to come as I get to it!</p>
]]></description><link>https://wibimmers.com/topic/142/my-bixenon-retrofit-e30</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 05:35:43 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/142.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 06 Jun 2011 22:44:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to My Bixenon retrofit (E30) on Sun, 09 Jun 2013 00:45:16 GMT]]></title><description><![CDATA[<p dir="auto">Pic was with just the low beams on correct. Just used s2000 ap1 projectors in euro smiley projectors. Bulbs make all the difference to. All in all i have about $875invested in my set up because i bought new euro smileys direct from hella. Getting the projectors level in housings was the most pain. Thinking of selling them and going with some better projectors though.</p>
]]></description><link>https://wibimmers.com/post/23935</link><guid isPermaLink="true">https://wibimmers.com/post/23935</guid><dc:creator><![CDATA[tsweers89]]></dc:creator><pubDate>Sun, 09 Jun 2013 00:45:16 GMT</pubDate></item><item><title><![CDATA[Reply to My Bixenon retrofit (E30) on Wed, 05 Jun 2013 14:41:12 GMT]]></title><description><![CDATA[<p dir="auto">I knew that much Dan, I was just asking about his, since his shot out in the country seems very bright, which is what I'm going for. I like the functionality of them</p>
]]></description><link>https://wibimmers.com/post/23796</link><guid isPermaLink="true">https://wibimmers.com/post/23796</guid><dc:creator><![CDATA[Brian.]]></dc:creator><pubDate>Wed, 05 Jun 2013 14:41:12 GMT</pubDate></item><item><title><![CDATA[Reply to My Bixenon retrofit (E30) on Wed, 05 Jun 2013 12:47:31 GMT]]></title><description><![CDATA[<p dir="auto">e34 projectors and e30 projectors are the same thing. (mounting tab locations are different due to platform, but its the same retro)</p>
]]></description><link>https://wibimmers.com/post/23789</link><guid isPermaLink="true">https://wibimmers.com/post/23789</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Wed, 05 Jun 2013 12:47:31 GMT</pubDate></item><item><title><![CDATA[Reply to My Bixenon retrofit (E30) on Tue, 04 Jun 2013 19:45:27 GMT]]></title><description><![CDATA[<p dir="auto">T.Sweererers, that photo is awesome, is that just low beams, or high beams?</p>
<p dir="auto">Do tell a bit about your setup on your E34, as I'm looking into upgrading the E28's with a ste of E34 projectors I have laying here.</p>
]]></description><link>https://wibimmers.com/post/23753</link><guid isPermaLink="true">https://wibimmers.com/post/23753</guid><dc:creator><![CDATA[Brian.]]></dc:creator><pubDate>Tue, 04 Jun 2013 19:45:27 GMT</pubDate></item><item><title><![CDATA[Reply to My Bixenon retrofit (E30) on Fri, 02 Dec 2011 05:59:21 GMT]]></title><description><![CDATA[<p dir="auto">moar win ^^</p>
]]></description><link>https://wibimmers.com/post/4081</link><guid isPermaLink="true">https://wibimmers.com/post/4081</guid><dc:creator><![CDATA[mystere30]]></dc:creator><pubDate>Fri, 02 Dec 2011 05:59:21 GMT</pubDate></item><item><title><![CDATA[Reply to My Bixenon retrofit (E30) on Fri, 02 Dec 2011 04:51:00 GMT]]></title><description><![CDATA[<p dir="auto">This is my finished product using s2000 projectors. This is in a e34 platform</p>
<p dir="auto"><a href="http://farm6.static.flickr.com/5048/5361472547_3d0c428351_z.jpg" rel="nofollow ugc">http://farm6.static.flickr.com/5048/5361472547_3d0c428351_z.jpg</a></p>
<p dir="auto">Why is it a link and not posting right here. wtf</p>
]]></description><link>https://wibimmers.com/post/4080</link><guid isPermaLink="true">https://wibimmers.com/post/4080</guid><dc:creator><![CDATA[tsweers89]]></dc:creator><pubDate>Fri, 02 Dec 2011 04:51:00 GMT</pubDate></item><item><title><![CDATA[Reply to My Bixenon retrofit (E30) on Sat, 26 Nov 2011 23:22:35 GMT]]></title><description><![CDATA[<p dir="auto">yes plenty. the fx-rs are actually smaller than the stock projectors.</p>
]]></description><link>https://wibimmers.com/post/4028</link><guid isPermaLink="true">https://wibimmers.com/post/4028</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Sat, 26 Nov 2011 23:22:35 GMT</pubDate></item><item><title><![CDATA[Reply to My Bixenon retrofit (E30) on Sat, 26 Nov 2011 16:48:16 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong>straight6pwr said:</strong></p>
<p dir="auto">putting a true HID retrofit on the e30 is pretty uncommon, and is pretty new ground as it is, no matter which kit you use.</p>
<p dir="auto">It does look pretty invasive but I'm pretty handy. Is there enough room to retain the plastic covers in the engine bay behind the lights?</p>
]]></description><link>https://wibimmers.com/post/4026</link><guid isPermaLink="true">https://wibimmers.com/post/4026</guid><dc:creator><![CDATA[DrLeadFoot]]></dc:creator><pubDate>Sat, 26 Nov 2011 16:48:16 GMT</pubDate></item><item><title><![CDATA[Reply to My Bixenon retrofit (E30) on Sat, 26 Nov 2011 16:32:18 GMT]]></title><description><![CDATA[<p dir="auto">putting a true HID retrofit on the e30 is pretty uncommon, and is pretty new ground as it is, no matter which kit you use.</p>
]]></description><link>https://wibimmers.com/post/4025</link><guid isPermaLink="true">https://wibimmers.com/post/4025</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Sat, 26 Nov 2011 16:32:18 GMT</pubDate></item><item><title><![CDATA[Reply to My Bixenon retrofit (E30) on Sat, 26 Nov 2011 16:25:22 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong>tsweers89 said:</strong></p>
<p dir="auto">Moliter you need to bring your car over by Scott sometime so i can check it out. Hopefully it is better than your m3 was.</p>
<p dir="auto">s2000 are better but are harder to fit due to their size. Here is a link to all you need to know:</p>
<p dir="auto"><a href="http://theeshadow.com/carmod/JVXdriver/beam_comparison.htm" rel="nofollow ugc">http://theeshadow.com/carmod/JVXdriver/beam_comparison.htm</a></p>
<p dir="auto">Good link Timmy. I think I'd go with the FX-R's just because of the $$ and bixenon feature. And I've read a couple of build threads with them being used. With my lack of research I'm following the crowd not blazing a new trail.</p>
<p dir="auto">Better than the M3 was!?! Always hatin'. The paint on this one isn't anything to write home about but it's what's on the inside that counts!<img src="/assets/uploads/files/emoticons_default_biggrin.png" alt=":D" class=" img-fluid img-markdown" width="20" height="20" /> I just need to clean it up and clean up the engine bay a bit and bam!</p>
]]></description><link>https://wibimmers.com/post/4024</link><guid isPermaLink="true">https://wibimmers.com/post/4024</guid><dc:creator><![CDATA[DrLeadFoot]]></dc:creator><pubDate>Sat, 26 Nov 2011 16:25:22 GMT</pubDate></item><item><title><![CDATA[Reply to My Bixenon retrofit (E30) on Sat, 26 Nov 2011 03:39:08 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">was going to say, most OEM HID projectors are going to be better, but that comes with a little more $ and more trouble installing versus the fx-r</p>
<p dir="auto">keep in mind also, the fx-r is a bixenon light, which means it has the low beam function plus a high beam in one unit. that is not the case with s2000</p>
<p dir="auto">This is true, but i have yet to say i wish i had bi-xenon when my low beam output is so good. Even with my tsx projectors i didn't have a problem.</p>
]]></description><link>https://wibimmers.com/post/4023</link><guid isPermaLink="true">https://wibimmers.com/post/4023</guid><dc:creator><![CDATA[tsweers89]]></dc:creator><pubDate>Sat, 26 Nov 2011 03:39:08 GMT</pubDate></item><item><title><![CDATA[Reply to My Bixenon retrofit (E30) on Sat, 26 Nov 2011 02:42:05 GMT]]></title><description><![CDATA[<blockquote>
]]></description><link>https://wibimmers.com/post/4022</link><guid isPermaLink="true">https://wibimmers.com/post/4022</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Sat, 26 Nov 2011 02:42:05 GMT</pubDate></item><item><title><![CDATA[Reply to My Bixenon retrofit (E30) on Sat, 26 Nov 2011 02:12:28 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong>DrLeadFoot said:</strong></p>
<p dir="auto">Which projectors are better? s2000 or fx-r's?</p>
<p dir="auto">/this is me not doing research...</p>
]]></description><link>https://wibimmers.com/post/4021</link><guid isPermaLink="true">https://wibimmers.com/post/4021</guid><dc:creator><![CDATA[tsweers89]]></dc:creator><pubDate>Sat, 26 Nov 2011 02:12:28 GMT</pubDate></item><item><title><![CDATA[Reply to My Bixenon retrofit (E30) on Fri, 25 Nov 2011 20:40:47 GMT]]></title><description><![CDATA[<p dir="auto">Which projectors are better? s2000 or fx-r's?</p>
]]></description><link>https://wibimmers.com/post/4019</link><guid isPermaLink="true">https://wibimmers.com/post/4019</guid><dc:creator><![CDATA[DrLeadFoot]]></dc:creator><pubDate>Fri, 25 Nov 2011 20:40:47 GMT</pubDate></item><item><title><![CDATA[Reply to My Bixenon retrofit (E30) on Thu, 24 Nov 2011 19:24:06 GMT]]></title><description><![CDATA[<p dir="auto">winnnnnnnnnnnnnnnnnnnnnnnnnn</p>
]]></description><link>https://wibimmers.com/post/4014</link><guid isPermaLink="true">https://wibimmers.com/post/4014</guid><dc:creator><![CDATA[mystere30]]></dc:creator><pubDate>Thu, 24 Nov 2011 19:24:06 GMT</pubDate></item><item><title><![CDATA[Reply to My Bixenon retrofit (E30) on Thu, 24 Nov 2011 01:11:52 GMT]]></title><description><![CDATA[<p dir="auto">Just finished my new retrofit. Hella euro ellipsoids w/ s2000 projectors. Have yet to put them in but fired one up in the house yesterday just to see the output.</p>
<p dir="auto"><img src="http://i637.photobucket.com/albums/uu93/tsweers89/tsx.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/post/4011</link><guid isPermaLink="true">https://wibimmers.com/post/4011</guid><dc:creator><![CDATA[tsweers89]]></dc:creator><pubDate>Thu, 24 Nov 2011 01:11:52 GMT</pubDate></item><item><title><![CDATA[Reply to My Bixenon retrofit (E30) on Wed, 23 Nov 2011 17:00:25 GMT]]></title><description><![CDATA[<p dir="auto">Thanks. this is the #1 mod to do to old cars with old headlights. the beam pattern is wide enough to span across all 3 lanes on the freeway plus onto the shoulders</p>
]]></description><link>https://wibimmers.com/post/4009</link><guid isPermaLink="true">https://wibimmers.com/post/4009</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Wed, 23 Nov 2011 17:00:25 GMT</pubDate></item><item><title><![CDATA[Reply to My Bixenon retrofit (E30) on Wed, 23 Nov 2011 01:15:58 GMT]]></title><description><![CDATA[<p dir="auto">Clean install and nice write up! This is on the to do list for sure. I just need to do some more research.</p>
]]></description><link>https://wibimmers.com/post/4008</link><guid isPermaLink="true">https://wibimmers.com/post/4008</guid><dc:creator><![CDATA[DrLeadFoot]]></dc:creator><pubDate>Wed, 23 Nov 2011 01:15:58 GMT</pubDate></item><item><title><![CDATA[Reply to My Bixenon retrofit (E30) on Wed, 15 Jun 2011 20:31:44 GMT]]></title><description><![CDATA[<p dir="auto">headlights are installed! heres what all was finished:</p>
<p dir="auto">Finished sealing up the projectors with aluminum foil tape:</p>
<p dir="auto"><img src="http://img713.imageshack.us/img713/1294/sealed1.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto">The headlight bucket had to be slightly trimmed to fit one of the brackets I added to secure the projector.</p>
<p dir="auto"><img src="http://img6.imageshack.us/img6/9718/bucket1.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto">Install into the bucket:</p>
<p dir="auto"><img src="http://img198.imageshack.us/img198/3087/sealed2.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><strong>Installing the lights into the car</strong></p>
<p dir="auto">Take out your headlights and the plastic sheilds on the back:</p>
<p dir="auto"><img src="http://img714.imageshack.us/img714/7379/removed1.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto">Get your harness and your beer ready:</p>
<p dir="auto"><img src="http://img577.imageshack.us/img577/8682/beer1w.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto">Installed the ballasts behind the headlights. There are big ass ballasts, but they fit along side just fine</p>
<p dir="auto"><img src="http://img814.imageshack.us/img814/4509/ballasts1.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://img714.imageshack.us/img714/3314/ballasts2.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto">Heres where I attached the harness for the main power (13V constant as shown with voltmeter):</p>
<p dir="auto"><img src="http://img155.imageshack.us/img155/8799/power1v.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto">And the ground:</p>
<p dir="auto"><img src="http://img545.imageshack.us/img545/2554/ground1.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto">Neatly run the harness down the engine bay:</p>
<p dir="auto"><img src="http://img683.imageshack.us/img683/2359/harness2l.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto">Seal up the relay to keep water out of it as it ends up by the ballasts/headlights:</p>
<p dir="auto"><a href="http://img32.imageshack.us/img32/7735/relay1.jpg" rel="nofollow ugc">http://img32.imageshack.us/img32/7735/relay1.jpg</a></p>
<p dir="auto">Run the plug for the drivers side across the body with the other factory wires which cross behind the front valance right under the grill:</p>
<p dir="auto"><a href="http://img851.imageshack.us/img851/7692/harness1b.jpg" rel="nofollow ugc">http://img851.imageshack.us/img851/7692/harness1b.jpg</a></p>
<p dir="auto">Heres all the plugs youll end up with for the lights. This is everything except the city light (if you have euro-spec lights)</p>
<p dir="auto"><a href="http://img684.imageshack.us/img684/5628/wiring1.jpg" rel="nofollow ugc">http://img684.imageshack.us/img684/5628/wiring1.jpg</a></p>
<p dir="auto">Headlights installed:</p>
<p dir="auto"><a href="http://img818.imageshack.us/img818/6475/installed1.jpg" rel="nofollow ugc">http://img818.imageshack.us/img818/6475/installed1.jpg</a></p>
<p dir="auto"><strong>Aiming the headlights:</strong></p>
<p dir="auto">Draw your diagram (or use tape if you dont want to deface someones property) according to <a href="http://www.danielsternlighting.com/tech/aim/aim.html" rel="nofollow ugc">http://www.danielsternlighting.com/tech/aim/aim.html</a></p>
<p dir="auto">The cross is the exact location of the lights on the car, the bottom line is 2.1 inches below and is where the cuttoff should land.</p>
<p dir="auto"><a href="http://img189.imageshack.us/img189/7734/aiming1.jpg" rel="nofollow ugc">http://img189.imageshack.us/img189/7734/aiming1.jpg</a></p>
<p dir="auto">Back the car up 25ft</p>
<p dir="auto"><a href="http://img854.imageshack.us/img854/3596/aiming2.jpg" rel="nofollow ugc">http://img854.imageshack.us/img854/3596/aiming2.jpg</a></p>
<p dir="auto"><a href="http://img696.imageshack.us/img696/5274/aiming3.jpg" rel="nofollow ugc">http://img696.imageshack.us/img696/5274/aiming3.jpg</a></p>
<p dir="auto">Where the lights landed before aiming</p>
<p dir="auto"><a href="http://img268.imageshack.us/img268/6023/aiming4.jpg" rel="nofollow ugc">http://img268.imageshack.us/img268/6023/aiming4.jpg</a></p>
<p dir="auto">Headlights aimed properly.</p>
<p dir="auto"><a href="http://img15.imageshack.us/img15/4184/aiming5.jpg" rel="nofollow ugc">http://img15.imageshack.us/img15/4184/aiming5.jpg</a></p>
<p dir="auto">Very happy with how bright they are. Whatever flickering that was happening when first tested is gone. Will post some output pictures when I get the chance.</p>
]]></description><link>https://wibimmers.com/post/1589</link><guid isPermaLink="true">https://wibimmers.com/post/1589</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Wed, 15 Jun 2011 20:31:44 GMT</pubDate></item><item><title><![CDATA[Reply to My Bixenon retrofit (E30) on Wed, 15 Jun 2011 15:31:11 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong>MikoPR said:</strong></p>
<p dir="auto">I beg to differ the 55w over power the bulb making a crisper white and leaving out some of the blue. Much better in my opinion.</p>
<p dir="auto">Very true, i do not diasagree. Im saying output differences are slim to none.</p>
]]></description><link>https://wibimmers.com/post/1586</link><guid isPermaLink="true">https://wibimmers.com/post/1586</guid><dc:creator><![CDATA[tsweers89]]></dc:creator><pubDate>Wed, 15 Jun 2011 15:31:11 GMT</pubDate></item><item><title><![CDATA[Reply to My Bixenon retrofit (E30) on Tue, 14 Jun 2011 01:56:40 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">35w to 55w set up is hardly noticeable as far as better output goes. But to each there own. Good work none the less.</p>
]]></description><link>https://wibimmers.com/post/1571</link><guid isPermaLink="true">https://wibimmers.com/post/1571</guid><dc:creator><![CDATA[MikoPR]]></dc:creator><pubDate>Tue, 14 Jun 2011 01:56:40 GMT</pubDate></item><item><title><![CDATA[Reply to My Bixenon retrofit (E30) on Mon, 13 Jun 2011 20:36:01 GMT]]></title><description><![CDATA[<p dir="auto">decided how i was going to seal it up today. i wanted to use a fiberglass kit and glass it in, but the two negatives of that are 1)fiberglass resin doesnt stick to plastic very well and 2)its a fairly permanent cover so if I ever needed to take them apart, i would be heavily cursing. also, after researching aluminum foil tape, i'm quite impressed with the stuff. i'd call it 'duct tape on crack'.</p>
<p dir="auto">depending on which version you get, it has a heat range from -25deg to 325deg, is 100% waterproof, has 'aggressive' adhesive, and can even be applied under water. good enough for me.</p>
<p dir="auto">so i bought the tape ($18/roll) and the silicone sealant (good to 400deg or something) and applied the sealant today. it will have to dry 24hrs before i apply the tape.</p>
<p dir="auto"><img src="http://img64.imageshack.us/img64/6059/sealant2.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://img137.imageshack.us/img137/8307/sealant1.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/post/1568</link><guid isPermaLink="true">https://wibimmers.com/post/1568</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Mon, 13 Jun 2011 20:36:01 GMT</pubDate></item><item><title><![CDATA[Reply to My Bixenon retrofit (E30) on Mon, 13 Jun 2011 01:47:02 GMT]]></title><description><![CDATA[<p dir="auto">lights fired up great except one ballast is flickering (will call to get it replaced) but they are going to level out just fine, so next step is permanently sealing them. i love the color, it is a true 4300k it is white but more toward yellow than blue from up close so its not a big attention getter. cut off is super sharp, the solenoids fired up the high beam function really well.</p>
<p dir="auto">lows: (note these have not been aimed yet)</p>
<p dir="auto"><img src="http://img219.imageshack.us/img219/1624/lights1w.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto">highs:</p>
<p dir="auto"><img src="http://img577.imageshack.us/img577/9593/lights2.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/post/1564</link><guid isPermaLink="true">https://wibimmers.com/post/1564</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Mon, 13 Jun 2011 01:47:02 GMT</pubDate></item><item><title><![CDATA[Reply to My Bixenon retrofit (E30) on Mon, 13 Jun 2011 01:11:16 GMT]]></title><description><![CDATA[<p dir="auto">thanks. got the other projector done today:</p>
<p dir="auto">copy the first projector cuts with tape:</p>
<p dir="auto"><img src="http://img705.imageshack.us/img705/8192/dscn5665p.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto">done:</p>
<p dir="auto"><img src="http://img856.imageshack.us/img856/2752/dscn5666.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto">splice plugs for solenoids to plug straight into high beam plugs:</p>
<p dir="auto"><img src="http://img402.imageshack.us/img402/9265/dscn5667v.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://img684.imageshack.us/img684/3594/dscn5668c.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto">here is the wiring harness the kit comes with. works great, but the main power and ground wires are too short.</p>
<p dir="auto"><img src="http://img821.imageshack.us/img821/2328/dscn5669n.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto">here the power and ground wires have been lengthened to run up the passenger fender and connect directly to the chassis power/ground.</p>
<p dir="auto"><img src="http://img834.imageshack.us/img834/6450/dscn5671.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto">going out to test fire them in a few minutes.</p>
]]></description><link>https://wibimmers.com/post/1563</link><guid isPermaLink="true">https://wibimmers.com/post/1563</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Mon, 13 Jun 2011 01:11:16 GMT</pubDate></item></channel></rss>
