87' E30 vert build thread! Now with M50 Swap!!!
cleaned up the car a bit today. put the headlights in. will eventually upgrade to ellipsoids / euro grille because it looks pretty derpy like this IMO.
also i vacuumed out theinterior and trunk. going to do sanding and rust control tomorrow.
Im thinking i may go with an electric radiator fan. does anyone have any suggestions?
I want the rear seats!!!!
im not parting it out!
but once i upgrade to black leather ill let you know lol
Dont care!!!!
Lol iight son.
Looks like a fun project.
When was the timing belt done last? Might be a good idea to replace.
Spal electric fans are a common choice. http://store.bimmerworld.com/spal-electric-fans-p1160.aspx
ill have to check it out. and yes i plan on doing the timing belt
needs a little love, but its a good place to start! PM returned
anyone else absolutely hate waiting for parts in the mail?
maybe i can work on my e34 sound system.
today i got exhaust manifolds, gaskets, nuts, rods, a shift linkage kit, and a z3 short shifter!
this will be my first time doing shift linkage so wish me luck. i have lots to do tomorrow!
got the new exhaust manifolds on, sounds like a truck now. much upgraded from sounding like a tractor or a jet engine.
tomorrow ill do all the hoses and put coolant in and it should be drivable. then i can find out of the headgasket is blown or not.
Another update since i know you guys care oh so much. got the radiator fan installed today, i had to remove the radiator to get it on which i thought was odd.. i put the radiator fan back in and theres a little less than a half inch of clearance between the fan and the radiator!? is this normal?
also, ive noticed that if i rock the car really hard when it stops i hear something rattle inside the engine, im kinda scared to find out what it is, is this a symptom to anything? thanks!
update. got the carpet today. fiddled with the dash and found out i gotta remove it and the heat blower in order to get it in, some people say you should cut around the console to get it in easy, but i dont want to do a half ass job. oh well, gives me time to look for a new dash anyways and get the carpet steam cleaned before i put it in.
tits. got most of the interior in. some of it is just sitting there cause of me missing nuts bolts ect, so i gotta order some or pick some up somewhere.
New shift linkage is in, it shifts like a dream (i dont see why anyone would want a shorter shift than a 1.9 z3) but it still doesnt go into 2nd, just grinds. probably a synchro. oh well ill replace the tranny when i do an engine swap
been wanting to do my headlights for a couple days now, but the humidity kept me from being able to paint anything.
finished today though! heres the process
What i started with
Teardown:
Finished!:
Close up:
its hard to see how good they look with my crappy phone camera. maybe ill post better pics eventually.
blew the engine today!!! swap time.
nope. if im gonna spend that much on a swap id rather do ls1 or 2jz
Well, had an issue awhile back, car sputtered and died while getting loud at the same time, though tit might be crank positioning sensor, so while i was waiting for that i got a valve job done and painted intake manifold and valve cover.
Turned it over with the new crank positioning sensor and nothing. but i did happen to hear the fuel pump dumping gas onto the ground at the fuel filter... shit.
Dont know if the fuel filters clogged yet or if i have another issue, im HOPING thats whats keeping it from starting... if not i have no idea?
