<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[87' E30 vert build thread! Now with M50 Swap!!!]]></title><description><![CDATA[<p dir="auto">Money spent so far:<br />
55 - fan and clutch from forum member<br />
15 - new odometer gears from Garagistic<br />
250 - Carpet and Ellipsoids from forum member<br />
162 - hood shock and clips, entire hose and clamp kit grille clips from Bavauto<br />
115 - Reconditioned exhaust manifolds. New nuts, studs and gaskets.<br />
100 - New lower shift boot and shift linkages from autohausaz.<br />
80 - z3 shifter</p>
<p dir="auto">(sic)</p>
<p dir="auto">too much</p>
<p dir="auto">Hey guys, new to the e30 . mostly an e34 person so far, but i saw a deal i couldnt pass by and figured i could use a project <img src="/assets/uploads/files/emoticons_default_smile.png" alt=":)" class=" img-fluid img-markdown" width="20" height="20" /></p>
<p dir="auto">as it stands right now<br />
<img src="http://imgur.com/9ArBF.jpg" alt="9ArBF.jpg" class=" img-fluid img-markdown" /><br />
paint is PERFECT. car is dirty because its been sitting under a tarp for a couple months due to it lacking a rear window. paint was redone about 4-5 years ago by bmw and the car is from texas.. so no body rust!<br />
<img src="http://i.imgur.com/hf9Bf.jpg" alt="hf9Bf.jpg" class=" img-fluid img-markdown" /><br />
yes, these are e46 fender ducts. no I dont know why.<br />
<img src="http://i.imgur.com/YPAjc.jpg" alt="YPAjc.jpg" class=" img-fluid img-markdown" /><br />
guy i bought it from said he was stripping interior out to restore the car. he threw out the carpet because it was shitty.... i cant find another carpet! anyone have one for sale? <img src="/assets/uploads/files/emoticons_default_smile.png" alt=":)" class=" img-fluid img-markdown" width="20" height="20" /><br />
<img src="http://i.imgur.com/fnl1Z.jpg" alt="fnl1Z.jpg" class=" img-fluid img-markdown" /><br />
no floorboard rust<br />
<img src="http://i.imgur.com/cU3Zv.jpg" alt="cU3Zv.jpg" class=" img-fluid img-markdown" /><br />
trunk full o parts<br />
<img src="http://i.imgur.com/uu3Id.jpg" alt="uu3Id.jpg" class=" img-fluid img-markdown" /><br />
exhaust off a ford lightning. no mufflers. dont ask.<br />
<img src="http://i.imgur.com/mkuoR.jpg" alt="mkuoR.jpg" class=" img-fluid img-markdown" /><br />
parts that were in the back seat. none of the seats have holes. minor cracks.. could use some TLC<br />
<img src="http://i.imgur.com/pIIdQ.jpg" alt="pIIdQ.jpg" class=" img-fluid img-markdown" /><br />
minor corrosion on the rear floorboard. i imagine this will just wash out.<br />
<img src="http://i.imgur.com/YaInL.jpg" alt="YaInL.jpg" class=" img-fluid img-markdown" /><br />
checkin out my current car<br />
<img src="http://i.imgur.com/i0aFX.jpg" alt="i0aFX.jpg" class=" img-fluid img-markdown" /><br />
bay shot... its really dirty but the engine started up fine when i replace the battery. 'fine' is defined as loud as fck due to one of the exhaust manifolds not being bolted to the cats. I get a check engine light but im hoping its either due to no pressure on the exhaust or due to there being no sensor on the coolant resivoir<br />
<a href="http://i.imgur.com/fSnsC.jpg" rel="nofollow ugc">http://i.imgur.com/fSnsC.jpg</a><br />
worst part of the car. ill probably take as much of it off with a sander as i can then coat it with anti-rust paint.<br />
<a href="http://i.imgur.com/Jhs5a.jpg" rel="nofollow ugc">http://i.imgur.com/Jhs5a.jpg</a></p>
<p dir="auto">Hoping i can find some parts on these boards and get it running and looking good with your guys' help!</p>
]]></description><link>https://wibimmers.com/topic/139/87-e30-vert-build-thread-now-with-m50-swap</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 05:36:31 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/139.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 04 Jun 2011 07:25:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 87' E30 vert build thread! Now with M50 Swap!!! on Thu, 15 Jan 2015 08:09:45 GMT]]></title><description><![CDATA[<p dir="auto">May have sourced an mtech 1 kit. will let you know <img src="/assets/uploads/files/emoticons_default_smile.png" alt=":)" class=" img-fluid img-markdown" width="20" height="20" /></p>
]]></description><link>https://wibimmers.com/post/52665</link><guid isPermaLink="true">https://wibimmers.com/post/52665</guid><dc:creator><![CDATA[Blaine0002]]></dc:creator><pubDate>Thu, 15 Jan 2015 08:09:45 GMT</pubDate></item><item><title><![CDATA[Reply to 87' E30 vert build thread! Now with M50 Swap!!! on Sat, 07 Sep 2013 00:12:17 GMT]]></title><description><![CDATA[<p dir="auto">Wire from starter solenoid to starter itself was lose.</p>
]]></description><link>https://wibimmers.com/post/27677</link><guid isPermaLink="true">https://wibimmers.com/post/27677</guid><dc:creator><![CDATA[Blaine0002]]></dc:creator><pubDate>Sat, 07 Sep 2013 00:12:17 GMT</pubDate></item><item><title><![CDATA[Reply to 87' E30 vert build thread! Now with M50 Swap!!! on Fri, 06 Sep 2013 21:38:08 GMT]]></title><description><![CDATA[<p dir="auto">what was the crank issue</p>
]]></description><link>https://wibimmers.com/post/27674</link><guid isPermaLink="true">https://wibimmers.com/post/27674</guid><dc:creator><![CDATA[M318]]></dc:creator><pubDate>Fri, 06 Sep 2013 21:38:08 GMT</pubDate></item><item><title><![CDATA[Reply to 87' E30 vert build thread! Now with M50 Swap!!! on Fri, 06 Sep 2013 06:11:57 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/23811">Blaine0002 said:</a></strong></p>
<p dir="auto"><img src="http://i.imgur.com/6KEp9X4.jpg" alt="6KEp9X4.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i.imgur.com/nr4ZluY.jpg" alt="nr4ZluY.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">u gonna tuck that rear bumper?</p>
]]></description><link>https://wibimmers.com/post/27661</link><guid isPermaLink="true">https://wibimmers.com/post/27661</guid><dc:creator><![CDATA[RamRod E28]]></dc:creator><pubDate>Fri, 06 Sep 2013 06:11:57 GMT</pubDate></item><item><title><![CDATA[Reply to 87' E30 vert build thread! Now with M50 Swap!!! on Fri, 06 Sep 2013 06:10:19 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/27646">CYoung said:</a></strong></p>
<p dir="auto">Cool. That has been on my list of colors to own, looks awesome on E28s.</p>
<p dir="auto">I may have found the color to do my e28!!!</p>
]]></description><link>https://wibimmers.com/post/27660</link><guid isPermaLink="true">https://wibimmers.com/post/27660</guid><dc:creator><![CDATA[RamRod E28]]></dc:creator><pubDate>Fri, 06 Sep 2013 06:10:19 GMT</pubDate></item><item><title><![CDATA[Reply to 87' E30 vert build thread! Now with M50 Swap!!! on Thu, 05 Sep 2013 22:36:50 GMT]]></title><description><![CDATA[<p dir="auto">Cool. That has been on my list of colors to own, looks awesome on E28s.</p>
]]></description><link>https://wibimmers.com/post/27646</link><guid isPermaLink="true">https://wibimmers.com/post/27646</guid><dc:creator><![CDATA[YoungCR]]></dc:creator><pubDate>Thu, 05 Sep 2013 22:36:50 GMT</pubDate></item><item><title><![CDATA[Reply to 87' E30 vert build thread! Now with M50 Swap!!! on Thu, 05 Sep 2013 21:10:19 GMT]]></title><description><![CDATA[<p dir="auto">Just kidding. Royalblau</p>
]]></description><link>https://wibimmers.com/post/27637</link><guid isPermaLink="true">https://wibimmers.com/post/27637</guid><dc:creator><![CDATA[Blaine0002]]></dc:creator><pubDate>Thu, 05 Sep 2013 21:10:19 GMT</pubDate></item><item><title><![CDATA[Reply to 87' E30 vert build thread! Now with M50 Swap!!! on Thu, 05 Sep 2013 19:32:07 GMT]]></title><description><![CDATA[<p dir="auto">pretty sure its orientblau. ill check it once i get home <img src="/assets/uploads/files/emoticons_default_smile.png" alt=":)" class=" img-fluid img-markdown" width="20" height="20" /></p>
]]></description><link>https://wibimmers.com/post/27633</link><guid isPermaLink="true">https://wibimmers.com/post/27633</guid><dc:creator><![CDATA[Blaine0002]]></dc:creator><pubDate>Thu, 05 Sep 2013 19:32:07 GMT</pubDate></item><item><title><![CDATA[Reply to 87' E30 vert build thread! Now with M50 Swap!!! on Wed, 04 Sep 2013 02:52:29 GMT]]></title><description><![CDATA[<p dir="auto">What color is your car again? Looks great</p>
]]></description><link>https://wibimmers.com/post/27513</link><guid isPermaLink="true">https://wibimmers.com/post/27513</guid><dc:creator><![CDATA[YoungCR]]></dc:creator><pubDate>Wed, 04 Sep 2013 02:52:29 GMT</pubDate></item><item><title><![CDATA[Reply to 87' E30 vert build thread! Now with M50 Swap!!! on Tue, 03 Sep 2013 10:53:29 GMT]]></title><description><![CDATA[<p dir="auto">What suspension did you go with?</p>
]]></description><link>https://wibimmers.com/post/27458</link><guid isPermaLink="true">https://wibimmers.com/post/27458</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Tue, 03 Sep 2013 10:53:29 GMT</pubDate></item><item><title><![CDATA[Reply to 87' E30 vert build thread! Now with M50 Swap!!! on Tue, 03 Sep 2013 04:28:11 GMT]]></title><description><![CDATA[<p dir="auto">love having new suspension</p>
<p dir="auto"><img src="http://i.imgur.com/O6G62tr.jpg" alt="O6G62tr.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i.imgur.com/jHJCXSr.jpg" alt="jHJCXSr.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">menomonie roads meet my skidplate</p>
]]></description><link>https://wibimmers.com/post/27450</link><guid isPermaLink="true">https://wibimmers.com/post/27450</guid><dc:creator><![CDATA[Blaine0002]]></dc:creator><pubDate>Tue, 03 Sep 2013 04:28:11 GMT</pubDate></item><item><title><![CDATA[Reply to 87' E30 vert build thread! Now with M50 Swap!!! on Wed, 05 Jun 2013 19:45:59 GMT]]></title><description><![CDATA[<p dir="auto"><img src="http://i.imgur.com/6KEp9X4.jpg" alt="6KEp9X4.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/post/23811</link><guid isPermaLink="true">https://wibimmers.com/post/23811</guid><dc:creator><![CDATA[Blaine0002]]></dc:creator><pubDate>Wed, 05 Jun 2013 19:45:59 GMT</pubDate></item><item><title><![CDATA[Reply to 87' E30 vert build thread! Now with M50 Swap!!! on Wed, 01 May 2013 17:22:22 GMT]]></title><description><![CDATA[<p dir="auto">wo0t i can finally change thread titles.</p>
]]></description><link>https://wibimmers.com/post/22331</link><guid isPermaLink="true">https://wibimmers.com/post/22331</guid><dc:creator><![CDATA[Blaine0002]]></dc:creator><pubDate>Wed, 01 May 2013 17:22:22 GMT</pubDate></item><item><title><![CDATA[Reply to 87' E30 vert build thread! Now with M50 Swap!!! on Tue, 30 Apr 2013 20:59:15 GMT]]></title><description><![CDATA[<p dir="auto">asdfasdf</p>
]]></description><link>https://wibimmers.com/post/22288</link><guid isPermaLink="true">https://wibimmers.com/post/22288</guid><dc:creator><![CDATA[Blaine0002]]></dc:creator><pubDate>Tue, 30 Apr 2013 20:59:15 GMT</pubDate></item><item><title><![CDATA[Reply to 87' E30 vert build thread! Now with M50 Swap!!! on Tue, 30 Apr 2013 06:33:21 GMT]]></title><description><![CDATA[<p dir="auto">i see lots of good work done, yet those fenders are still lingering....</p>
]]></description><link>https://wibimmers.com/post/22268</link><guid isPermaLink="true">https://wibimmers.com/post/22268</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Tue, 30 Apr 2013 06:33:21 GMT</pubDate></item><item><title><![CDATA[Reply to 87' E30 vert build thread! Now with M50 Swap!!! on Tue, 30 Apr 2013 03:28:00 GMT]]></title><description><![CDATA[<p dir="auto">Neat valve cover!</p>
]]></description><link>https://wibimmers.com/post/22258</link><guid isPermaLink="true">https://wibimmers.com/post/22258</guid><dc:creator><![CDATA[YoungCR]]></dc:creator><pubDate>Tue, 30 Apr 2013 03:28:00 GMT</pubDate></item><item><title><![CDATA[Reply to 87' E30 vert build thread! Now with M50 Swap!!! on Mon, 29 Apr 2013 21:13:34 GMT]]></title><description><![CDATA[<p dir="auto">Your lack of battery may cause no crank <img src="/assets/uploads/files/emoticons_default_wink.png" alt=";)" class=" img-fluid img-markdown" width="20" height="20" /></p>
]]></description><link>https://wibimmers.com/post/22238</link><guid isPermaLink="true">https://wibimmers.com/post/22238</guid><dc:creator><![CDATA[GunMetalGrey]]></dc:creator><pubDate>Mon, 29 Apr 2013 21:13:34 GMT</pubDate></item><item><title><![CDATA[Reply to 87' E30 vert build thread! Now with M50 Swap!!! on Mon, 29 Apr 2013 20:59:55 GMT]]></title><description><![CDATA[<p dir="auto"><img src="https://sphotos-b.xx.fbcdn.net/hphotos-frc1/377208_10151364078767411_1747072412_n.jpg" alt="377208101513640787674111747072412n.jp" class=" img-fluid img-markdown" /></p>
<p dir="auto">Everythings together, but no crank.</p>
]]></description><link>https://wibimmers.com/post/22237</link><guid isPermaLink="true">https://wibimmers.com/post/22237</guid><dc:creator><![CDATA[Blaine0002]]></dc:creator><pubDate>Mon, 29 Apr 2013 20:59:55 GMT</pubDate></item><item><title><![CDATA[Reply to 87' E30 vert build thread! Now with M50 Swap!!! on Wed, 03 Oct 2012 14:22:17 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Do you still have the parts car? I havent heard back from you about snagging the parts I need=\</p>
<p dir="auto">Naw man, the police were on my ass awhile back about it sitting in my yard for so long, and so I had to get rid of it. Luckily, i dont think I had any parts you needed, definately none in good shape.</p>
]]></description><link>https://wibimmers.com/post/10009</link><guid isPermaLink="true">https://wibimmers.com/post/10009</guid><dc:creator><![CDATA[Blaine0002]]></dc:creator><pubDate>Wed, 03 Oct 2012 14:22:17 GMT</pubDate></item><item><title><![CDATA[Reply to 87' E30 vert build thread! Now with M50 Swap!!! on Wed, 03 Oct 2012 07:51:42 GMT]]></title><description><![CDATA[<p dir="auto">Do you still have the parts car? I havent heard back from you about snagging the parts I need=\</p>
]]></description><link>https://wibimmers.com/post/10007</link><guid isPermaLink="true">https://wibimmers.com/post/10007</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Wed, 03 Oct 2012 07:51:42 GMT</pubDate></item><item><title><![CDATA[Reply to 87' E30 vert build thread! Now with M50 Swap!!! on Wed, 03 Oct 2012 05:08:22 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong>wsor said:</strong></p>
<p dir="auto">it's in! Did you delete your Facebook? Haven't heard from you in a while!</p>
<p dir="auto">nope i just blocked you <img src="/assets/uploads/files/emoticons_default_wink.png" alt=";)" class=" img-fluid img-markdown" width="20" height="20" /></p>
<p dir="auto">kidding, yeah i deleted it.</p>
]]></description><link>https://wibimmers.com/post/10006</link><guid isPermaLink="true">https://wibimmers.com/post/10006</guid><dc:creator><![CDATA[Blaine0002]]></dc:creator><pubDate>Wed, 03 Oct 2012 05:08:22 GMT</pubDate></item><item><title><![CDATA[Reply to 87' E30 vert build thread! Now with M50 Swap!!! on Wed, 03 Oct 2012 04:25:10 GMT]]></title><description><![CDATA[<p dir="auto">it's in! Did you delete your Facebook? Haven't heard from you in a while!</p>
]]></description><link>https://wibimmers.com/post/10005</link><guid isPermaLink="true">https://wibimmers.com/post/10005</guid><dc:creator><![CDATA[YoungCR]]></dc:creator><pubDate>Wed, 03 Oct 2012 04:25:10 GMT</pubDate></item><item><title><![CDATA[Reply to 87' E30 vert build thread! Now with M50 Swap!!! on Wed, 03 Oct 2012 03:55:44 GMT]]></title><description><![CDATA[<p dir="auto">Well, after 4 months (what?) of work at the machine shop, i only have one really quick update.</p>
<p dir="auto"><img src="http://i.imgur.com/LphsC.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/post/10003</link><guid isPermaLink="true">https://wibimmers.com/post/10003</guid><dc:creator><![CDATA[Blaine0002]]></dc:creator><pubDate>Wed, 03 Oct 2012 03:55:44 GMT</pubDate></item><item><title><![CDATA[Reply to 87' E30 vert build thread! Now with M50 Swap!!! on Sat, 17 Mar 2012 19:27:09 GMT]]></title><description><![CDATA[<p dir="auto">Weathers been nice, so i did some work.</p>
<p dir="auto">Old:</p>
<p dir="auto"><img src="http://i.imgur.com/mkuoR.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto">new:</p>
<p dir="auto"><img src="http://i.imgur.com/1k9bI.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto">Got the top as a christmas gift from the parents.</p>
<p dir="auto">Top is from topsonline. I did replace the tension straps and cables.</p>
<p dir="auto">Unfortunately the crimped part of the front window seal guide broke off, so i need to order new ones for both sides before i can fit the cables and finish the project.</p>
<p dir="auto">The frame also isnt secured down fully, thats why theres so much gap between the top and the frame.</p>
<p dir="auto">The top quality was pretty good. The instructions suck, but the top actually wasnt a complete #$%^ to replace. If i had to sit down, i could definately point out some imperfections in it, but its the best quality you can get besides overpriced OEM.</p>
]]></description><link>https://wibimmers.com/post/6021</link><guid isPermaLink="true">https://wibimmers.com/post/6021</guid><dc:creator><![CDATA[Blaine0002]]></dc:creator><pubDate>Sat, 17 Mar 2012 19:27:09 GMT</pubDate></item></channel></rss>
