  4. 87' E30 vert build thread! Now with M50 Swap!!!
57 Posts 15 Posters 1.1k Views 1 Watching
    Blaine0002
    got the new exhaust manifolds on, sounds like a truck now. much upgraded from sounding like a tractor or a jet engine.
    tomorrow ill do all the hoses and put coolant in and it should be drivable. then i can find out of the headgasket is blown or not.
      Blaine0002
      Another update since i know you guys care oh so much. got the radiator fan installed today, i had to remove the radiator to get it on which i thought was odd.. i put the radiator fan back in and theres a little less than a half inch of clearance between the fan and the radiator!? is this normal?
      also, ive noticed that if i rock the car really hard when it stops i hear something rattle inside the engine, im kinda scared to find out what it is, is this a symptom to anything? thanks!
        Blaine0002
        update. got the carpet today. fiddled with the dash and found out i gotta remove it and the heat blower in order to get it in, some people say you should cut around the console to get it in easy, but i dont want to do a half ass job. oh well, gives me time to look for a new dash anyways and get the carpet steam cleaned before i put it in.
          Blaine0002
          tits. got most of the interior in. some of it is just sitting there cause of me missing nuts bolts ect, so i gotta order some or pick some up somewhere.
          Posted Image
          Posted Image
          New shift linkage is in, it shifts like a dream (i dont see why anyone would want a shorter shift than a 1.9 z3) but it still doesnt go into 2nd, just grinds. probably a synchro. oh well ill replace the tranny when i do an engine swap :D
            Blaine0002
            been wanting to do my headlights for a couple days now, but the humidity kept me from being able to paint anything.
            finished today though! heres the process
            What i started with
            Posted Image
            Teardown:
            Posted Image
            Finished!:
            Posted Image
            Close up:
            Posted Image
            its hard to see how good they look with my crappy phone camera. maybe ill post better pics eventually.
              Blaine0002
              blew the engine today!!! swap time.
                S50, s52??
                  Blaine0002
                  nope. if im gonna spend that much on a swap id rather do ls1 or 2jz
                    Blaine0002
                    Well, had an issue awhile back, car sputtered and died while getting loud at the same time, though tit might be crank positioning sensor, so while i was waiting for that i got a valve job done and painted intake manifold and valve cover.
                    Posted Image
                    Turned it over with the new crank positioning sensor and nothing. but i did happen to hear the fuel pump dumping gas onto the ground at the fuel filter... shit.
                    Dont know if the fuel filters clogged yet or if i have another issue, im HOPING thats whats keeping it from starting... if not i have no idea?
                      Good job. And BTW......you said tit;)
                        What kind of intake is that? I want that intake. Where did you get it?
                          Blaine0002
                          KA Motors Cold air intake
                          TBH probably not much better than stock airbox, bmw does that stuff right..
                          but i needed a new airbox anyways so i figured what the hell.
                          anyways, thread here
                          http://www.r3vlimited.com/board/showthread.php?t=130323
                            Let me know when you get the swap finished up and if you are ever in the Milwaukee area. I'd like to do compare performance.
                              Blaine0002
                              id be game for that, but id like to warn you, while i have the engine apart im doing a bore and s50 cams.
                                :cool: As long as you can hang with something like this
                                it should be close.
                                  Blaine0002
                                  it should be close.
                                  looks like fun!
                                    Blaine0002
                                    Updates, pulled the engine out of the donor car. Steering column knuckles were corroded, so we just angle grinded it out..
                                    Also, remember to remove your shift linkage before pulling the drivetrain. We were baffled for about an hour trying to figure out what the engine was caught on.
                                    Posted Image
                                    Posted Image
                                    Posted Image
                                    Posted Image
                                    Posted Image
                                    Posted Image
                                    Posted Image
                                    • Ryan...R
                                      Ryan...R
                                      Ryan...
                                      Good to see this progressing!
                                        Blaine0002
                                        Waiting for my check to process so i can send the parts to the machine shop.
                                        Internals look surprisingly good! Now i have to start pulling the e30 apart.
                                        Posted Image
                                          Blaine0002
                                          Weathers been nice, so i did some work.
                                          Old:
                                          Posted Image
                                          new:
                                          Posted Image
                                          Got the top as a christmas gift from the parents.
                                          Top is from topsonline. I did replace the tension straps and cables.
                                          Unfortunately the crimped part of the front window seal guide broke off, so i need to order new ones for both sides before i can fit the cables and finish the project.
                                          The frame also isnt secured down fully, thats why theres so much gap between the top and the frame.
                                          The top quality was pretty good. The instructions suck, but the top actually wasnt a complete #$%^ to replace. If i had to sit down, i could definately point out some imperfections in it, but its the best quality you can get besides overpriced OEM.
