  4. 2002 E46 M3 // Build Thread
167 Posts 17 Posters 3.3k Views 1 Watching
  • pynaclP
    pynaclP
    pynacl
    Didn’t know those were a sticker
    Honestly me neither, another solid tip from @Rekpoint!
    • pynaclP
      pynaclP
      pynacl
      friend thought I was playing a prank saying I have to replace my mirror fluid. Cursed with the infamous dimming mirror delaminating and evaporating/leaking. Decided to take the DIY approach rather than send it off to save a few bucks. Ended up being a super easy 30 min project and looks brand new. Mirror link
        Gotta love the oval mirror! I’d like to retrofit one in my car.
          I have one if you want one. Needs the same mirror fluid repair.
          • pynaclP
            pynaclP
            pynacl
            Found my first moist surprise. Went to go disconnect the battery to start installing my headers, and my flashlight caught a little reflection. Turns out the passenger tail light lens was slightly detached, allowing water in😦 Thank god it didn't rust through the metal and I was able to wire wheel, clean, naval jelly rust dissolve and rust converter it. Finally I tried adding some etching primer to try to match the factory finish best I could. Probably not perfect but helps me sleep at night.
            • pynaclP
              pynaclP
              pynacl
              Found a set of used OEM LED tails. Luckily my LCM was v3.0.1, so I'm able to just code them to the car as-is. Just needed some OEM wiring adapters to make them work.
              • pynaclP
                pynaclP
                pynacl
                Paint matched reflectors wooooo
                • pynaclP
                  pynaclP
                  pynacl
                  @Rekpoint Found me a super good deal on a UUC EVO 3 and DSSR kit off marketplace. Super excited to try this out because it was originally an expense I normally couldn't justify.
                  • pynaclP
                    pynaclP
                    pynacl
                    Picked up a new set of Fabspeed headers. Genuinely haven't had the time to install them yet, but really hoping within the next couple weeks they should be going on. Now just to find a nice section 1 and muffler to compliment them.
                    • pynaclP
                      pynaclP
                      pynacl
                      Did trans fluid change, oil change, cabin air filter and intake filter change and took it out for a quick shakedown this weekend. Of course found more broken stuff. Ordered UUC trans mounts and all new bushings/gaskets for the shifter carrier to go with the UUC EVO 3 when I install it. Rotors seemed a bit warped too with heavy braking, dang.
                      5110788954240cf60c8fek.jpg5110923247096f269295fk.jpg51108176219b1558c1d34k.jpg511084290064da4737b2dk.jpg511092067656ef5e0b9e1k.jpg
                      • pynaclP
                        pynaclP
                        pynacl
                        So jacked I nabbed this plate! "E46 M3" was taken, but this was up for grabs 😁
                          Replace your CPV o-ring while the headers are off.
                          • pynaclP
                            pynaclP
                            pynacl
                            That’s right! I bought a Viton one a few months ago and totally forgot I even had it! I’ll add that to the checklist while I’m in there
                              Exciting updates! Taillights look great, can't wait to hear those headers.
                              • pynaclP
                                pynaclP
                                pynacl
                                Same!! Here's a couple clips of my end goal:
                                https://www.instagram.com/p/B-7AvknDxzI/
                                https://www.instagram.com/p/B-qiBpGj2zJ/
                                The setup is fabspeed headers, stock section 1, resonated x pipe and a top speed muffler. Never even knew the S54 could sound like this, but JEESH
                                  I’m not a huge S54 guy because of the typical sound of them, but that video right there changed my mind.
                                    ^^yup, that's a great sounding goal
                                      All videos with really good sounding S54s are deepfakes of an E36 M3 with a pitch adjustment /s
                                      It is entirely possible to have a great sounding S54 but I have yet to find a quiet setup that sounds good enough to spend money on. Loud enough to actually hear it while driving but quiet enough to hear the induction sound and not be a nuissance.
                                      When you see inside the stock muffler its a bit baffling at how they arrived at such a design.
                                        Most of the nice sounding ones are running catless headers+resonators with an aftermarket muffler and are just stupid loud. It seems that adding back quieter mufflers just seems to cut the noise but maintain the rasp, which is exactly what I would want to get away from. I wonder if going to quad resonators, x-pipe, catless headers, and a moderately quiet muffler would be the solution?
                                        Have any pics of said muffler guts?
                                          note the perforated pipes
                                          Interestingly the Z4M seems to have better luck with muffler options that sound good.
                                          The stock exhaust sound isnt BAD, it is unique if not just a little bit exotic, but it isnt a sound that gives James May a fizzing sensation.
                                          The risk comes with modified exhaust as you can really ruin it, making it worse than stock.
                                          @pynacl  I wish you godspeed, just not a Godspeed exhaust
