  4. E46 Touring Life
E46 Touring Life
87 Posts 11 Posters 0 Views 1 Watching
    So it begins.....
      Those front clips sure make it easier. Do you have heat in the new garage?
        Ya, it's right there in the picture ;)  Attached to a propane tank.
          Haha yes it is. Didnt get around to installing a central heater with thermostat yet, so the ole propane tank mounted heater will do for now. works relatively nice if close by.
            Well, plans have changed and the swap is being pushed off till spring/summer 2021. A lot going on with work and life in general, that adding the stress of finishing a swap in a single week on my winter daily driver would suck. And thats if everything goes extremely smooth, which we all know never happens. Ha!
            To be continued....
              Uno Reverse!
                Good plan 👍
                  And so it begins .... again!
                    Sweet!  We're going rear engine clownshoe like the Renault Clio v6!?  I'm in.
                      Couples hours this morning in the toasty garage. Good start I'd say.
                        Auto shifter out.
                        Pedal assembly out.
                        Car on jack stands. Gotta raise front a hair more.
                          That looks like an X5 from that angle and with that wheel gap.
                            Cover up the right side of the pic, squint real hard, take a sip of floor wax, and you can see an X3.
                            progress is progress! like I say, I did my 24v swap 15 minutes at a time everyday to stay motivated. This already looks way easier than any of the E30/E21 motor extractions we have done.
                            how bad was removing the pedals?
                              It wasn't that bad actually. Put the seat all the way back and knelt on ground leaned in under dash. Hardest part was getting the booster arm off the brake pedal due to the metal loop that surrounds the pin on the brake pedal arm. Running the line to the slave cylinder will be a huge bitch tho as the carpet doesn't want to bend very easily to get to the grommet hole in floor/firewall. Might be a two man job for that one or waiting until old engine/trans is out to have more space.
                                Engine & trans have been removed. Couple snags here and there but came out relatively easily. There always has to be an oil spill in one way shape or form as well. Found a bad inner tierod on driver side and a sheared control arm bushing bolt on passenger side from someone down the line before me. Hopefully drilling and an easy-out will fix that.
                                Next is transferring all the engine accessories over from old engine to new one, buying all new hoses/lines and prepping everything for reinstall.
                                  Scuffing Oil-Dri into the concrete with your foot does an amazing job of removing stains as well as wearing out your shoes.
                                    That's called the oil-dri dance.
                                      Front accessories mounted including the underdrive pulleys that came with the B30 engine. Working on replacing some rusty exhaust flange studs from the headers and slowly marking all electrical plugs before pulling the manifold off the old B25. Trying out some metal rescue rust dissolver. Letting it sit 24-36 hours and seeing what it does.
                                        The metal rescue rust removal bath worked great! The exhaust manifold studs came out looking like new and the broken downpipe studs were cleaned enough to be able to be heated with a torch slightly and air hammered out with ease. I will just use a nut/bolt combo for the downpipe flange connection to make things easier. Exhaust manifolds back on the engine with new gaskets and upstream o2 sensors. Also installed the SAI block off plate on the engine as well as I dont plan on putting that back in.
                                        I started breaking down the passenger front axle due to a torn inner cv boot. Just gotta fill that back up with grease and clamp new boot on, then reassemble.
                                        Also started getting the clutch lines and new slave cylinder squared away.
                                        Replaced driver side engine mount and the old one was squished down pretty good. Surprised there wasn't any cracking in the rubber.
                                        Then moved onto the dreaded intake manifold rats nest. I wanted to move everything that I could over from the B25 engine since I know that stuff worked well. Found a torn intake boot on both engines in same location (this could explain my misfire issue on B25). Will be ordering new boots along with new intake manifold gasket. I took my time marking every hose and electrical connector with different color paint markers while transferring things over to the B30 manifold. Hopefully this makes things a lot easier for reinstall.
                                        And all done.
                                        Anybody looking for an M54B25 to buy? Would be nice to get it out of the garage, so I can pull the Z3 Coupe out to stretch its legs. 😁
                                          Looks like a therapeutic day in the garage. Don’t forget to remove that clutch destroyer valve and incinerate it.
                                          Looking good man!
