  4. E46 Touring Life
E46 Touring Life
87 Posts 11 Posters 1.6k Views 1 Watching
    Good time to tack weld the oil pump nut!
      Yes!
      • i_love_carsI
        i_love_carsI
        i_love_cars
        I remember when I did a manual conversion on my E46 325xi touring. It will definitely be worth it when you're done. It's ridiculous how much more eager the car is to rev with the manual.
        2007 Z4MR
        2003 E39 M5
        2002 E46 M3
        2021 X5 40i
          So it begins.....
            Those front clips sure make it easier. Do you have heat in the new garage?
              Ya, it's right there in the picture ;)  Attached to a propane tank.
                Haha yes it is. Didnt get around to installing a central heater with thermostat yet, so the ole propane tank mounted heater will do for now. works relatively nice if close by.
                  Well, plans have changed and the swap is being pushed off till spring/summer 2021. A lot going on with work and life in general, that adding the stress of finishing a swap in a single week on my winter daily driver would suck. And thats if everything goes extremely smooth, which we all know never happens. Ha!
                  To be continued....
                    Uno Reverse!
                      Good plan 👍
                        And so it begins .... again!
                          Sweet!  We're going rear engine clownshoe like the Renault Clio v6!?  I'm in.
                            Couples hours this morning in the toasty garage. Good start I'd say.
                              Auto shifter out.
                              Pedal assembly out.
                              Car on jack stands. Gotta raise front a hair more.
                                That looks like an X5 from that angle and with that wheel gap.
                                  Cover up the right side of the pic, squint real hard, take a sip of floor wax, and you can see an X3.
                                  progress is progress! like I say, I did my 24v swap 15 minutes at a time everyday to stay motivated. This already looks way easier than any of the E30/E21 motor extractions we have done.
                                  how bad was removing the pedals?
                                    It wasn't that bad actually. Put the seat all the way back and knelt on ground leaned in under dash. Hardest part was getting the booster arm off the brake pedal due to the metal loop that surrounds the pin on the brake pedal arm. Running the line to the slave cylinder will be a huge bitch tho as the carpet doesn't want to bend very easily to get to the grommet hole in floor/firewall. Might be a two man job for that one or waiting until old engine/trans is out to have more space.
                                      Engine & trans have been removed. Couple snags here and there but came out relatively easily. There always has to be an oil spill in one way shape or form as well. Found a bad inner tierod on driver side and a sheared control arm bushing bolt on passenger side from someone down the line before me. Hopefully drilling and an easy-out will fix that.
                                      Next is transferring all the engine accessories over from old engine to new one, buying all new hoses/lines and prepping everything for reinstall.
                                        Scuffing Oil-Dri into the concrete with your foot does an amazing job of removing stains as well as wearing out your shoes.
                                          That's called the oil-dri dance.
