  4. E46 Touring Life
E46 Touring Life
87 Posts 11 Posters 1.6k Views 1 Watching
    Awesome!! That will be an excellent daily (not that it isn't already). I'm happy to help if you need any M54/ms43 assistance!
      YESSSSSSSSSSSSSSSS
        I know what needs to be done, but I have never actually used WinFKP so between the 3 of is im sure some kind of tune file will end up on some module
          Rad, thanks! Yeah that will be the interesting part for sure. I know Brian has been looking this part up a lot too.
            Parts to refresh some things on the B30 have been ordered. Currently prepping the engine/trans while I wait.
              Tear down started. Rear main seal replaced, engine put on stand, ps pump removed, ac compressor removed, intake manifold removed, front diff and axle carrier removed, oil pan removed.
              Next up is crank pulley removal to replace all timing components. Also remove as many brackets, housings, mounts, etc to get blasted and painted.
                Good time to tack weld the oil pump nut!
                  Yes!
                  • i_love_carsI
                    i_love_carsI
                    i_love_cars
                    I remember when I did a manual conversion on my E46 325xi touring. It will definitely be worth it when you're done. It's ridiculous how much more eager the car is to rev with the manual.
                    2007 Z4MR
                    2003 E39 M5
                    2002 E46 M3
                    2021 X5 40i
                      So it begins.....
                        Those front clips sure make it easier. Do you have heat in the new garage?
                          Ya, it's right there in the picture ;)  Attached to a propane tank.
                            Haha yes it is. Didnt get around to installing a central heater with thermostat yet, so the ole propane tank mounted heater will do for now. works relatively nice if close by.
                              Well, plans have changed and the swap is being pushed off till spring/summer 2021. A lot going on with work and life in general, that adding the stress of finishing a swap in a single week on my winter daily driver would suck. And thats if everything goes extremely smooth, which we all know never happens. Ha!
                              To be continued....
                                Uno Reverse!
                                  Good plan 👍
                                    And so it begins .... again!
                                      Sweet!  We're going rear engine clownshoe like the Renault Clio v6!?  I'm in.
                                        Couples hours this morning in the toasty garage. Good start I'd say.
                                          Auto shifter out.
                                          Pedal assembly out.
                                          Car on jack stands. Gotta raise front a hair more.
