  3. Parts Wanted
  4. **CLOSED** e36 M3 front suspension
15 Posts 5 Posters 0 Views 1 Watching
  • N
    N
    Nick_08
    I'm looking for the front suspension from an e36 M3 (strut assemblies & knuckles). Thanks -Nick
      @Rekpoint do you have anything?
        Nope, Had to scrap it 😦
          Was it bent up from the wreck?
            No it was good. But due to circumstances it had to go with the car.
            • N
              N
              Nick_08
              Dang! Thanks for reaching out @KaiserRolls. Still looking if anyone has even just the knuckles and calipers that would suffice. Thanks.
                Doing 5-lug swap? I've heard good things about these kits and am considering switching to this setup: https://www.irp.lt/individual-racing-parts-product/5-lug-kit-to-use-e36-e46-wheel-bearings-and-brakes/
                Lets you retain stock geometry, but can then run e46 330 brakes
                • N
                  N
                  Nick_08
                  Thank for sharing. Yes, 5 lug swap so I can ditch the 18mm adapters and get the benefit of the bigger brake package. Can I ask, are the e46 brakes around the same size as the e36m3? Thanks @m42b32!
                    17yo forum post
                      Hopefully they fit behind your 16s
                        Only thing worth noting with the IRP solution/330 brakes is you may not be able to fit 16" wheels since they are slightly larger than the e36 m3 parts.
                        • N
                          N
                          Nick_08
                          Appreciate the info @KaiserRolls & @m42b32! The IRP kit is 12mm wider than stock which I think might make the (e38) style 5 -et23 flush. I'm looking to verify how much, if any, width the e36 swap will add. I want the tires tucked so I can run bigger tires such as a 225/50r16. Thanks!
                            E36 parts will add at least that much unfortunately, though I couldn't find exact numbers
                              Some 16" wheels will fit and some won't.  I have test fitted 16" Contour reps and they do fit over e46 330 brakes.  Not sure what others do.
                              • N
                                N
                                Nick_08
                                I'm actually researching this right now. My wheel choice is e38 style 5 (16x8 et23).
                                -e46 325 front brake rotors are 300 x 22mm
                                -e46 330 front brake rotors are 325 x 25mm (as Mitch noted^) and there's a really good chance my wheels won't clear these.
                                -e36 m3 front brake rotors are 315 x 28mm (as Mitch noted ^), I don't think these would fit either ( might be close).
                                After much thought all day with the help from @KaiserRolls & @m42b32 I think I will end up going with the IRP 5 lug conversion kit and run the e46 325 calipers/rotors. These will be a decent upgrade from the e30 260 x 22mm rotor and in fact, the e46 325 setup will be 1/10th of the price of a massive BBK which is also only 300 x 22mm!
                                In closing, I'm going to mark this thread as closed and thank you all for the information. Appreciate it...
                                -Nick
