  3. Parts Wanted
  4. **CLOSED** e36 M3 front suspension
15 Posts 5 Posters 186 Views 1 Watching
    Was it bent up from the wreck?
    No it was good. But due to circumstances it had to go with the car.
    • N
      N
      Nick_08
      Dang! Thanks for reaching out @KaiserRolls. Still looking if anyone has even just the knuckles and calipers that would suffice. Thanks.
        Doing 5-lug swap? I've heard good things about these kits and am considering switching to this setup: https://www.irp.lt/individual-racing-parts-product/5-lug-kit-to-use-e36-e46-wheel-bearings-and-brakes/
        Lets you retain stock geometry, but can then run e46 330 brakes
        • N
          N
          Nick_08
          Thank for sharing. Yes, 5 lug swap so I can ditch the 18mm adapters and get the benefit of the bigger brake package. Can I ask, are the e46 brakes around the same size as the e36m3? Thanks @m42b32!
            17yo forum post
              Hopefully they fit behind your 16s
                Only thing worth noting with the IRP solution/330 brakes is you may not be able to fit 16" wheels since they are slightly larger than the e36 m3 parts.
                • N
                  N
                  Nick_08
                  Appreciate the info @KaiserRolls & @m42b32! The IRP kit is 12mm wider than stock which I think might make the (e38) style 5 -et23 flush. I'm looking to verify how much, if any, width the e36 swap will add. I want the tires tucked so I can run bigger tires such as a 225/50r16. Thanks!
                    E36 parts will add at least that much unfortunately, though I couldn't find exact numbers
                      Some 16" wheels will fit and some won't.  I have test fitted 16" Contour reps and they do fit over e46 330 brakes.  Not sure what others do.
                      • N
                        N
                        Nick_08
                        I'm actually researching this right now. My wheel choice is e38 style 5 (16x8 et23).
                        -e46 325 front brake rotors are 300 x 22mm
                        -e46 330 front brake rotors are 325 x 25mm (as Mitch noted^) and there's a really good chance my wheels won't clear these.
                        -e36 m3 front brake rotors are 315 x 28mm (as Mitch noted ^), I don't think these would fit either ( might be close).
                        After much thought all day with the help from @KaiserRolls & @m42b32 I think I will end up going with the IRP 5 lug conversion kit and run the e46 325 calipers/rotors. These will be a decent upgrade from the e30 260 x 22mm rotor and in fact, the e46 325 setup will be 1/10th of the price of a massive BBK which is also only 300 x 22mm!
                        In closing, I'm going to mark this thread as closed and thank you all for the information. Appreciate it...
                        -Nick
