  4. The One That Didn't Get Away [100K Mile E30 325is]
257 Posts 19 Posters 4.4k Views 2 Watching
    I always add fuel stabilizer to the tank and then run the car for a bit to circulate it through the system too
    I second this ^^^^^
    And don't forget the most crucial part of storing your bmw over winter ...... fold in the mirrors.
      An absolute essential!
        First thing I do is thoroughly clean out the interior and get rid of any wrappers, receipts, etc that may have made it through the winter then vacuum every crevice to get rid of any potential mouse food that my kids may have left in there.  Then in no certain order:
        1. I add STA-BIL to a full gas tank and run it through for a bit
        2. Battery maintainer WITH overcharge protection
        3. Check all fluid levels to make sure they're full and winter ready including winter washer fluid.  If it's not rated for winter use it can freeze and could cause some damage to that system
        Something I've never done for winter storage is remove the wheels and tires.  I do make sure the tires are properly inflated but other than that it sit's as is.  I've never had an issue with flat spotting after storage over winter.
        I'll also add that although I've never had a mouse issue with one of my stored cars I have worked on too many cars WITH mouse problems that keeps me paranoid enough to set up about 4 mouse traps and mouse poison in the garage over the winter.  Dryer sheets are bullshit and have no effect on mice.  I've pulled engine covers with the fucking dryer sheets in the mouse nest.
          I see there is a STA-BIL product labeled "storage". Is this the one I should I go with or is there just a standard one I should use?
            I believe that's just the standard STA-BIL and that's the one I use.
              I didn't know there were different ones, the normal one has been fine for me
                Trick for this is park your car on cardboard!
                  Am I the only one that just removes the battery all together??
                  I just toss them on a shelf and then slap them back in when the salts gone.
                  unless your radio station presets are that important
                    Yeah I was going to remove it and leave it on a tender. No electrical outlets at the storage unit.
                      I don't know if you usually use E10 fuel but if you can run it low and fill up with non ethanol fuel it is much better.  It doesn't deteriorate rapidly like ethanol fuel does.
                      • N
                        N
                        Nick_08
                        Same here, always place on a shelf with a tender running.
                          I've only put 91 in this car. I think that's ethanol free or is that 93?
                            My radio stations stay saved when the battery is removed so for me it's more about convenience.
                            Depends on the brand of gas. You can buy both ethanol free.
                              Octane doesn't mean anything.  At the little station in town by me I can get 87 with no ethanol.  Kwik Trip around this area has 91 without ethanol and the pump handle is red.
                                The red handle is the one that I use.
                                Good to know.
                                  I miss driving this car.
                                    I had the center waffles repainted as well to match the wheels. Purchased some eBay red BBS center badges for them as the BMW logos were pretty beat. Really liking the combination.
                                    I also wanted to check on the car and make sure it was still there. Good news is that there wasn’t a lake of fluids underneath, just one small spot that I’m assuming is oil.
                                    Going to charge the battery up and maybe let it run for a little bit next week when it’s warm.
                                      You chose well
                                        Looks perfect
                                          It lives.
                                          Charged the battery up and dropped it last night after work, started right up.
                                          Drove it up and down the street just to stretch it out a little bit. In dire need of a wash and probably a little air in the tires.
                                          Probably need to have a valve adjustment done this spring, sounded a little ticky. Or the oil just hadn't circulated entirely from starting for the first time in 6 months.
                                          Back into the storage until it's nice out full time.
