  4. SCHLEPN | The E39 540itA Story
s626 speedm5t
214 Posts 17 Posters 3.8k Views 1 Watching
    Had a slight shimmy in the brakes so I had Mike replace the rotors and the pads.  Went with Zimmerman rotors and OEM BMW pads.
    Scooped up a used M wheel with the updated airbag! Excited!
    Got a power steering line leak so we'll be replacing that early next week.
    Also replaced the dash lights, added the dimmer wire to my radio so the backlight on the keys works, replaced a bad O2 sensor under warranty, put new rubber mounts on the oil filter, added some leather interior bits: -steering column surround -upper & lower B pillars -center console arm rest.
    Slowly chipping away!
      DrLeadFoot said:
      Primer overspray? Concrete dust? Or some amazing leak detection spray I have never heard of??
        yes I'm also curious about that photo
          It's a leak detection spray.  Drys into a baby powder substance.  Washes off easy.  Pretty sweet!
            https://www.wurthusa.com/Chemical-Product/Leak-Detection/LEAK-TRACING-POWDER-12-fl-oz-aerosol-spray-cannet-content-7-5-oz-(213g)-/p/886102712
            Guessing this is it. I miss having easy access to those great chemicals.
              Chipped away at some things.  Mike got the PS line replaced, m5 A pillars, black leather ebrake cable boot, new high intensity washer fluid container, washer fluid hoses, refurbished abs module, black front seat belts, and new wipers.
                some things never cease to be useful. for example:
                castle door crossbars
                  What exactly makes the container high intensity?  Does it yell motivational slurs at before it sends the fluid?
                    its just a second tank, to hold 'high intensity' fluid, for when the standard stuff just isn't cutting the bug-goo.
                      The E24 had this too. Its full concentrate vs. diluted fluid.
                        How do you control between the two fluids? I've never heard of that before.
                          Summer wheels on!  She has been running great!
                          Need to get it to Mike's to do the rear subframe & diff bushings after we move to our new house on April 24th. Will also get the diff mount welded to reinforce it. Would love to get the rear subframe powder coated as well.
                            Replaced the tailgate brake lights with some new OEM pieces.  Such a huge difference!!
                              New horns!!!  Sounds like a Ferrari now.
                                It's been a while! The wagon has been clocking the miles like a champ all summer. The front diff mount reinforcement has been on the radar for a minute and with the stars aligning with my schedule I pulled the trigger.  Mike has done all of it solo as real estate is booming and my free time is spent with the family.
                                The list:
                                -M5 subframe bushings, dinan front diff reinforcement kit, powder coated subframe gloss black, all new bushings, new lower control arms (left is on back order from Germany), M5 ladder bars powder coated gloss black.
                                  Looks certified for the leadfoot now
                                    Oil & filter change. 10w-60 Liqui Moly & Mann Filter.
                                    Installed: Repaired sunroof with new OEM rebuild kit. Black suede headliner, a, b, & c pillars.  Black Nappa leather m5 front seats, front cards, lower dash and center console. Black carpet.
                                    Still need some grey items swapped to Black but getting there.
                                    Endless Detailing polished the turd up today! I'm loving it!
                                      busmn540
                                      Hey Dr.PbFT,
                                      I have a question about your cluster. How did you get the coolant temp to display like that? Was it some special coding? My coolant temp only displays using the hidden menu.
                                      Thanks,
                                      Buster
                                        busmn540 said:
                                        Hey Dr.PbFT,
                                        Thanks,
                                        Buster
                                        It just started doing that once I installed the Avant head unit. No clue!  Lol
                                          VAC rear sway bar reinforcements installed. Yay!
