  4. SCHLEPN | The E39 540itA Story
214 Posts 17 Posters 0 Views 1 Watching
    DrLeadFoot said:
    Not too much fun.  SCHLEPN tires & wheels back and forth from Stallis and trying to keep up with this crazy Real Estate market!  It's still going strong!
    I agree!
    A birdy said you're the go to guy for a suede headliner.  Let's talk!
    I may have done a few in my time.
      Wheels look great!
        I'll pop some 5mm spacers on the rear to get it a little better stance.
          10mm rear spacers installed.  I think this makes the wheels ET 4 in the rear and ET 9 in the front.
          Structure and Fab sent some pics of the rear passenger jacking point rebuild.  Thank goodness Chris is better at fab work than taking pictures.  🤣
            Merry XMAS!!
            Update: Running strong!  Need an oil change soon and the rear subframe will be coming out to pop in new M5 bushings and weld in the dinan diff reinforcement.
              The only reason I didn’t get a real tree this year was that I didn’t have an S62 swapped E39 wagon to bring it home with. It had absolutely nothing to do with ambition.
                What are the OE M5 rear subframe bushings like?  I got a set of Powerflex yellow ones for my dad's wagon but haven't installed them.  It's parked for the winter so it won't be until spring.
                  Not sure on stiffness but the M5 bushings are a tad shorter and allow for the reinforcement trailing bars to be installed.
                    Oil & filter change at 196,172 miles (M5 cluster).
                    10w-60 Liqui Moly & Mann Filter.
                      Had a slight shimmy in the brakes so I had Mike replace the rotors and the pads.  Went with Zimmerman rotors and OEM BMW pads.
                      Scooped up a used M wheel with the updated airbag! Excited!
                      Got a power steering line leak so we'll be replacing that early next week.
                      Also replaced the dash lights, added the dimmer wire to my radio so the backlight on the keys works, replaced a bad O2 sensor under warranty, put new rubber mounts on the oil filter, added some leather interior bits: -steering column surround -upper & lower B pillars -center console arm rest.
                      Slowly chipping away!
                        DrLeadFoot said:
                        Primer overspray? Concrete dust? Or some amazing leak detection spray I have never heard of??
                          yes I'm also curious about that photo
                            It's a leak detection spray.  Drys into a baby powder substance.  Washes off easy.  Pretty sweet!
                              https://www.wurthusa.com/Chemical-Product/Leak-Detection/LEAK-TRACING-POWDER-12-fl-oz-aerosol-spray-cannet-content-7-5-oz-(213g)-/p/886102712
                              Guessing this is it. I miss having easy access to those great chemicals.
                                Chipped away at some things.  Mike got the PS line replaced, m5 A pillars, black leather ebrake cable boot, new high intensity washer fluid container, washer fluid hoses, refurbished abs module, black front seat belts, and new wipers.
                                  some things never cease to be useful. for example:
                                  castle door crossbars
                                    What exactly makes the container high intensity?  Does it yell motivational slurs at before it sends the fluid?
                                      its just a second tank, to hold 'high intensity' fluid, for when the standard stuff just isn't cutting the bug-goo.
                                        The E24 had this too. Its full concentrate vs. diluted fluid.
                                          How do you control between the two fluids? I've never heard of that before.
