  4. ‘91 E30
‘91 E30
      Still leaks PS fluid, but most of everything else is buttoned up
        It is a BMW so if it didn't it must be empty.
          Sold the corbeaus, need to ditch the tan(?) carpet. Sounds like Dan has a good solution for the carpet part
          pic of vomit colored carpet
          new seats should be here wednesday
            Looking forward to seeing this!
              Did you say that you were going to dye it? Forget what you said in the FB chat.
              I think it took like 4 cans of the duplicolor stuff to do mine. Like others have said, black floor mats will cover the wear parts. I just bought these ones.
              I rented one of the carpet steamers from Home Depot before hand, worked really well, makes a huge difference.
                thanks for info on the mats
                @straight6pwr has offered up his old carpet which looks to be gray/anthracite or whatever. Think I’ll just try cleaning that one up really well. If it doesn’t clean up all that well I’ll try the dye route
                  I had the gray carpet in my car and used a couple cans of black SEM carpet dye and it worked very well - turned out much better than I anticipated it turning out.
                    I assume the SEM stuff is better, but has anyone had experience with using this:
                    Image result for fabric rit dye
                    You can buy it just about anywhere is and is super cheap. I have used red over white in the past and it worked well for the purpose, and it seems there are quite a few guys online that have used it with good results.
                      I believe RIT dye requires full submerging of the carpet. Which probably won’t work with the foam backIng the e30 has
                        You could always just put it in a bucket and stand on it
                        Image result for grape lady gif
                          Foam will probably get ruined was my point
                            Plans:
                            Clean/dye current carpet (if I can’t get dans)
                            purchase brackets/side mounts for different seats
                            install MS3/wire up wbo2
                            I still have a bolt-in 4pt sitting in storage, idk what to do with. Sell/install
                            cleanup/install trunk carpets
                            fix firewall steering shaft boot
                            fix Slow PS leak
                              I bought floor mats
                              I’ll be back in a month with another insignificant update
                                I bought floor mats
                                So now we see that the carpet doesn't match the floor mat...
                                  Epic.  Absolutely epic.  Any detailed instructions on installation?  What other brands did you comp before you chose to go with the OEM floor mat?
                                    I just messaged some motoring life garage place and told the guy there to order me some. He gave me the run around about how I don’t own a 1er but I sent him money anyways
                                      Sounds like a fucking hack.  I'd complain to the bbb.
                                        Just need to cut around the heater core and then it’ll be ready to be removed.
                                          Purchased some bummerworld floor plates for the new seats, new clips for the sill plates, new clips for the doorcards, firewall steering shaft boot and new boot mount from a dude on r3v (needed for making the boot work with the different steering shaft angle associated with the z3 rack), side mounts for seats, vac seat belt receptacle mounts and a manual gas pedal stop as mine was still the auto kickdown switch thing.
                                          hopefully that’s all I need to get the interior finished off
