  4. ‘91 E30
‘91 E30
    I assume the SEM stuff is better, but has anyone had experience with using this:
    Image result for fabric rit dye
    You can buy it just about anywhere is and is super cheap. I have used red over white in the past and it worked well for the purpose, and it seems there are quite a few guys online that have used it with good results.
      I believe RIT dye requires full submerging of the carpet. Which probably won’t work with the foam backIng the e30 has
        You could always just put it in a bucket and stand on it
        Image result for grape lady gif
          Foam will probably get ruined was my point
            Plans:
            Clean/dye current carpet (if I can’t get dans)
            purchase brackets/side mounts for different seats
            install MS3/wire up wbo2
            I still have a bolt-in 4pt sitting in storage, idk what to do with. Sell/install
            cleanup/install trunk carpets
            fix firewall steering shaft boot
            fix Slow PS leak
              I bought floor mats
              I’ll be back in a month with another insignificant update
                I bought floor mats
                So now we see that the carpet doesn't match the floor mat...
                  Epic.  Absolutely epic.  Any detailed instructions on installation?  What other brands did you comp before you chose to go with the OEM floor mat?
                    I just messaged some motoring life garage place and told the guy there to order me some. He gave me the run around about how I don’t own a 1er but I sent him money anyways
                      Sounds like a fucking hack.  I'd complain to the bbb.
                        Just need to cut around the heater core and then it’ll be ready to be removed.
                          Purchased some bummerworld floor plates for the new seats, new clips for the sill plates, new clips for the doorcards, firewall steering shaft boot and new boot mount from a dude on r3v (needed for making the boot work with the different steering shaft angle associated with the z3 rack), side mounts for seats, vac seat belt receptacle mounts and a manual gas pedal stop as mine was still the auto kickdown switch thing.
                          hopefully that’s all I need to get the interior finished off
                            Link for the steering shaft boot mount?
                              https://www.r3vlimited.com/board/forum/e30-classified-forums/for-sale-wanted/parts-for-sale/9872086-z3-e36-steering-rack-plate-for-late-model-e30-s
                                Are these the E46 floor mats? I haven't even driven in my car with my eBay mats, but they look like trash compared to these.
                                  If Im not mistaken they are 1 series mats.
                                    1 series mats are a dialed fitment for an E30
                                      yes, e82 mats. they fit OK, but the fronts are a little small. its nice that they are OEM quality, though, vs aftermarket questionable stuff.
                                        https://www.turnermotorsport.com/p-340009-genuine-bmw-e82-floor-mats-e82-128i-135i-1m-coupe/?pdk=Ag
                                          The quality is quite nice for $100. Comes with the anchors too
