  4. ‘91 E30
‘91 E30
    its not a factory skid plate
    • ChrisOC
      ChrisOC
      ChrisO
      Saw you on my way to Taco Bell today, car sounds awesome
        slacker
          A first for me today, car fell off the jack as I was raising it up from the skid plate. It was odd, it just spit the jack out the front. Got lodged in between the valence and the core support. Barely pushed the valence out, blew the lip off and took some coating off a wire loom. Got lucky.
          I think my brothers e30 is running the same skid plate. Did it weld onto the frame rails?
            This type of accident wouldn't have happened on the EVO...
              I realize that, I was offering an idea for an addition to the skid plate to prevent the future from repeating the past.
                Scary! I'm glad nobody got hurt. Did the car roll back or did it spit the jack out the front??
                I have the same skid plate (HIKfab) and I've been putting a hockey puck between the jack and the skid plate (the original rubber pad on the jack is gone). It deforms a bit as the car is lifted and seems to 'stick' a little better once it gets some angle between the two.
                  Didn’t roll back, handbrake was set. Jack I was using had a rubber pad
                    Yes
                      glad you're OK!
                      my guess it was the combination of a very smooth floor allowing the jack to roll easily (possibly a bit of oil residue or dampness?) and maybe going a little higher than normal.
                      when you jack under the plate from the front, you'll lose most of the contact between the jack plate and skid plate after only a few degrees of lift, per my half-assed diagram.  also the plate is a smooth surface, so there is nothing for the 'teeth' of the jack plate to catch on.
                      Yes - same way I have jacked it up a billion times before, this time it wasn’t having it. Usually I use a long use low pro gray jack. This time I was using the blue jack below.
                      After it kicked out the blue one, I swapped to the gray and it lifted no issue.
                      I have since started using a 2x6 inbetween the jack and the skid plate (orientated front to rear inbetween the two channels on the hikfab) to distribute the load and give the jack something to bite into.
                        Finally fixed the valve cover leak, replaced the gasket and all the grommets. One of the studs was twisted apart so I had to rob from the red car. Brooke has been taking it to work all this week
                          When you going to let me take this beautiful beast to class?
                                Still leaks PS fluid, but most of everything else is buttoned up
                                  It is a BMW so if it didn't it must be empty.
                                    Sold the corbeaus, need to ditch the tan(?) carpet. Sounds like Dan has a good solution for the carpet part
                                    pic of vomit colored carpet
                                    new seats should be here wednesday
                                      Looking forward to seeing this!
                                        Did you say that you were going to dye it? Forget what you said in the FB chat.
                                        I think it took like 4 cans of the duplicolor stuff to do mine. Like others have said, black floor mats will cover the wear parts. I just bought these ones.
                                        I rented one of the carpet steamers from Home Depot before hand, worked really well, makes a huge difference.
                                          thanks for info on the mats
                                          @straight6pwr has offered up his old carpet which looks to be gray/anthracite or whatever. Think I’ll just try cleaning that one up really well. If it doesn’t clean up all that well I’ll try the dye route
