  4. Partiallypurplevisuallyviolet - Daytona M3 Build Thread
130 Posts 16 Posters 0 Views 1 Watching
    Nice job guessing the culprit
      Are you back in business now?
        If the slave cylinder is installed right it can't just randomly blow the pin out.  The pin only comes out if you press the clutch pedal without the slave installed to the transmission.
          did you use a new clip?
          make sure the fork was aligned properly? and make sure it wasnt worn through?
          insert the clutch slave into the bellhousing at a straight angle? (that's what she said)
          use the correct TOB?
            Type Of Buttocks?
            • PartiallypurpleP
              PartiallypurpleP
              Partiallypurple
              Finishing it up today after work. Fingers crossed everything will go well 🤞
              • PartiallypurpleP
                PartiallypurpleP
                Partiallypurple
                New clip, didn’t make sure the fork was aligned properly to be honest. Kind of stupid of myself. Didn’t have any problems with the last slave on my other e36 so I figure it was as easy as screwing on and making sure it’s tight. Going to make sure everything is perfect before I even look at that clutch pedal this time
                  you can also test fit the slave before installing the transmission
                    Correct me if I'm wrong, and I could be given this is a 1J, but when the fork is lined up correctly, the slave should sit off the bell housing a little as the dowel is pressing into the arm.
                      Correct, it takes some pushing to get the slave to sit flush on the back of the trans
                      • PartiallypurpleP
                        PartiallypurpleP
                        Partiallypurple
                        Well a whole new clutch setup later and throwout bearing and we are finally back up and running! Spent the day deep cleaning all the interior panels, deciding what was good enough to keep and what had to go! Also made a shift boot/cage for the CAE. Going to wrap it in alcanatara suede but the brushed aluminum isn’t bad till I park the car for winter soon.
                          Looks nice!
                            CAE is a life changer. are you planning on keeping it aluminum or will you darken that up a bit too?
                            • PartiallypurpleP
                              PartiallypurpleP
                              Partiallypurple
                              Which part? The part I made is getting wrapped, the shifter itself will stay as is with probably a white knob to match the letters on the seats and steering wheel. The aluminum should match the lips of the wheels
                                The shaft. 🤭
                                It just doesn't seem like there is any other raw aluminum in the interior.
                                • PartiallypurpleP
                                  PartiallypurpleP
                                  Partiallypurple
                                  The shaft. 🤭
                                  There is now! Just picked these up from a local tire shop they had sitting in the back in a box from the early 90’s. They used to be a MOMO distributor back in the day. Super neat score that’ll match the Recaro Momo Special and fit the period correct theme I’m going for. Also the cage is currently polished/cleared. I can’t find any other pictures or anything on these pedals
                                    Really cool! How did those sit on a shelf for 20years??
                                    • PartiallypurpleP
                                      PartiallypurpleP
                                      Partiallypurple
                                      Sat in the back warehouse where no one could see them.
                                        This is pretty sick
                                          WOAH.. that brings me back.
                                          So oddly, my very first car had a very similar set of those Circa 2004. The guy I bought it from was best friends with the owner of LINK motorsports back in the day. He got a bunch of free parts for the car that was sitting on the shelf. Sadly, this also meant the car was a pile of mismatched parts. Red seats, blue harnesses, red faded to brown steering wheel, etc. I ended up selling my pedals to some kid years ago, nowhere NEAR as clean as those.
                                          Congrats on your find!
