  4. E46 Things
E46 Things
359 Posts 23 Posters 0 Views 1 Watching
    ^Post of the day for that call back. @Daggerty
      The coil pack replacement was well worth it. The S54 is pulling harder than ever!
        much beauty.
          much beauty.
          such wow
            such wow
            So vanos
              Re-glued the saggy A-pillar fabric (it was like having drapes before)  and gave it a bath.
              C89367C9-D965-4F7C-883C-BCBC53D6F287.thumb.jpeg.ee8810ca7ccecac79241175a334d9e73.jpeg491BBDDB-31D5-49AE-B3B4-BF81C7EFCE98.thumb.jpeg.189f95411f4e056f87932cb9c342987f.jpeg
                Napa know how.
                  What glue did you use?
                      For serious?
                        For serious?
                        4.5 stars dude.  Also likely found in the wife's crafting supplies.  Easy peasy.
                          For serious?
                          Yes, seems to be working well
                            Interesting. I always used 3M super 77 or 80. I would be fearful using repositionable spray on something I wanted permanent.
                              Took a little drive with a friend today.
                                Track day next Wednesday the 18th. Things to do:
                                -Bleed brakes
                                -Check lugs
                                -Install missing spacer on front swaybar end link (Big Bear pointed this out during the alignment)
                                -Adjust rear sway bar (left and right sides are set to different holes for some reason, Big Bear pointed this out)
                                UPDATE: Thanks JC for learning me something new. I am now realizing why my E30 sway bars were advertised as having 3 settings despite only having 2 holes.
                                -Check fluids and battery tie down
                                -borrow spare tire kit from father in law’s 335i
                                  As for the rear sway bar, setting the sides to different holes does not make one side act differently than the other, it is like a half setting if one set of holes is too stiff and the other is too soft.
                                    -Bleed brakes
                                    -Check lugs
                                    I've got a slim plastic tote that fits in my trunk that I use for tools and such if you'd like to borrow it.  I'm guessing it'd fit in your car the same as mine.  I'd also be happy to let you take some of my tools if you wanted.  It's always nice to have the stuff there "just in case".
                                      Thanks for the input, I had never considered that
                                         Thanks, I may take you up on that once I start getting things packed up
                                          you should probably set that rear bar to full boner so you can powerslide the carousel
