E46 Things
I'm sad that the car was misrepresented and thus a complete waste of your time, but I'm laughing out loud at "instead of 'I'm sorry we are idiots'"
I've had the exact opposite.
Car was listed as auto (I know, I know) and I show up to look at it and ask the guy why they haven't sold it yet, as it had been listed for a bit.
He told me they wont change the ad, so people keep showing up to buy it and some went as far as asking what the third pedal was for. It's amazing that some people don't even realize that a manual transmission exists... -
Replaced coil packs due to
-OCD
-I have felt a slight isolated random misfire on two occasions during light load cruising
- Random misfire codes stored on the DME despite the engine performing flawlessly 99.9999% of the time
-I had no idea how old they were and wanted to make sure a bum coil didn’t ruin my track day in September
Everything went swimmingly
The date code on the old coils shows 5 years old and matching that date up with the CarFax equates to about 35-40k miles which is newer than anticipated. I can say that startup and idle with the new coils is stronger and smoother than ever and I have some spares for my parts collection.
While everything was apart I found a missing firewall plug that was hiding up in my cabin filter tray. Glad to have removed a potential rodent ingress point
much beauty.
much beauty.
such wow
such wow
So vanos
What glue did you use?
For serious?
4.5 stars dude. Also likely found in the wife's crafting supplies. Easy peasy.
For serious?
Yes, seems to be working well
Track day next Wednesday the 18th. Things to do:
-Bleed brakes
-Check lugs
-Install missing spacer on front swaybar end link (Big Bear pointed this out during the alignment)
-Adjust rear sway bar (left and right sides are set to different holes for some reason, Big Bear pointed this out)
UPDATE: Thanks JC for learning me something new. I am now realizing why my E30 sway bars were advertised as having 3 settings despite only having 2 holes.-Check fluids and battery tie down
-borrow spare tire kit from father in law’s 335i
-Bleed brakes
-Check lugs
I've got a slim plastic tote that fits in my trunk that I use for tools and such if you'd like to borrow it. I'm guessing it'd fit in your car the same as mine. I'd also be happy to let you take some of my tools if you wanted. It's always nice to have the stuff there "just in case".
