  4. Madison - E39 M5 - Thread
m5e39new member
53 Posts 11 Posters 1.2k Views 1 Watching
    I love it!
      Paint looks great!
      • V
        V
        vbhargava
        Minor update: Went to install a shark injector tune to find out that it already has a tune on it. Not sure what it is but certainly explains the excessively sensitive throttle response
          Well thats a nice surprise!
            This is still probably one of the best cars BMW ever made
            • V
              V
              vbhargava
              Finally got both Bimmers out at the same time
              • V
                V
                vbhargava
                Headed over to Accumoto for a suspension consultation. Ended up raising the car 1 inch all around for a more comfortable daily ride and less twitchy backroads experience. Car is feeling much better and just needs to go back for an alignment next week.
                  Accumoto is a cool place, that E36 is fresh!
                  • V
                    V
                    vbhargava
                    New pedals and windshield washer pump! Pretty simple but taking off the wheel well liner can be a pain.
                      What pedals are those/where can I get some?!
                      love it!
                      • V
                        V
                        vbhargava
                        love it!
                        Turner Motorsports but bought through ECS. Contact @patsbimmer1 to order ECS parts at a good price.
                        My only piece of advice for the install is to make sure you have good sharp drill bits. I went and bought new ones near the end and it would have saved me at least 1 hour. #facepalm
                        • V
                          V
                          vbhargava
                          Finally out of hibernation:
                          Todays projects:
                          • cabin air filter change
                          • windshield seal
                          • new cowl fasteners
                          • V
                            V
                            vbhargava
                            Summer plans:
                            • rear subframe bushings
                            • coolant overflow reservoir
                            • bluebus bluetooth module (https://www.bluebus.dev/)
                            • accumulator upgrade
                            • V
                              V
                              vbhargava
                              Two small projects down:
                              Got the car back on the road after upgrading the pressure accumulator and coolant reservoir.
                              IMG_8958.mov
                                Which car is the summer DD? How many miles are on this beast?
                                  I accidentally watched that video about 7 times. Love it.
                                  • V
                                    V
                                    vbhargava
                                    @B C I dont have a garage at home so two of the four cars are almost always in storage. I tend switch between the E39 M5 and an A6 depending on weather. The E30 vert only comes out for a couple days at a time because it doesn't have a working AC and is less safe that the other cars (I am usually the one who drops and picks up my two year old).  It also has an uncracked dash which I am hoping stays that way but it means keeping out of the sun.
                                    Once the E39 is fully sorted, suspension wise, I think I'll use it more heavily for DD duty. E39 currently has 103,000 miles!
                                    • V
                                      V
                                      vbhargava
                                      Its time for the next big project on the M5 due to a loose rear end which is likely caused by bad bushings given that some of them have 100k on them.
                                      Plan:
                                      • Center support bearing
                                      • Drive axle minor refresh including guibo
                                      • Engine mounts
                                      • Transmission mounts
                                      • Differential bushings
                                      • Rear subframe bushings
                                      • Dinan rear sway bar
                                      • All rear control arms and integral links
                                      • Center exhaust hanger
                                      • Rear ball joints
                                      • Hawk HPS and 5.0 brake pads
                                      • High temp brake fluid
                                      • Oil change
                                      Big thanks to @patsbimmer1for helping me source the parts and @jcw0101 for making it happen.
                                        Are rear subframe bushings for these as terrible as they seemed to be in every other car?
                                          How are you liking that Turner pedal set? I am thinking of acquiring some for myself.
