  4. Madison - E39 M5 - Thread
53 Posts 11 Posters 0 Views 1 Watching
  • V
    V
    vbhargava
    What pedals are those/where can I get some?!
    love it!
    Turner Motorsports but bought through ECS. Contact @patsbimmer1 to order ECS parts at a good price.
    My only piece of advice for the install is to make sure you have good sharp drill bits. I went and bought new ones near the end and it would have saved me at least 1 hour. #facepalm
    • V
      V
      vbhargava
      Finally out of hibernation:
      Todays projects:
      • cabin air filter change
      • windshield seal
      • new cowl fasteners
      • V
        V
        vbhargava
        Summer plans:
        • rear subframe bushings
        • coolant overflow reservoir
        • bluebus bluetooth module (https://www.bluebus.dev/)
        • accumulator upgrade
        • V
          V
          vbhargava
          Two small projects down:
          Got the car back on the road after upgrading the pressure accumulator and coolant reservoir.
          IMG_8958.mov
            Which car is the summer DD? How many miles are on this beast?
              I accidentally watched that video about 7 times. Love it.
              • V
                V
                vbhargava
                @B C I dont have a garage at home so two of the four cars are almost always in storage. I tend switch between the E39 M5 and an A6 depending on weather. The E30 vert only comes out for a couple days at a time because it doesn't have a working AC and is less safe that the other cars (I am usually the one who drops and picks up my two year old).  It also has an uncracked dash which I am hoping stays that way but it means keeping out of the sun.
                Once the E39 is fully sorted, suspension wise, I think I'll use it more heavily for DD duty. E39 currently has 103,000 miles!
                • V
                  V
                  vbhargava
                  Its time for the next big project on the M5 due to a loose rear end which is likely caused by bad bushings given that some of them have 100k on them.
                  Plan:
                  • Center support bearing
                  • Drive axle minor refresh including guibo
                  • Engine mounts
                  • Transmission mounts
                  • Differential bushings
                  • Rear subframe bushings
                  • Dinan rear sway bar
                  • All rear control arms and integral links
                  • Center exhaust hanger
                  • Rear ball joints
                  • Hawk HPS and 5.0 brake pads
                  • High temp brake fluid
                  • Oil change
                  Big thanks to @patsbimmer1for helping me source the parts and @jcw0101 for making it happen.
                    Are rear subframe bushings for these as terrible as they seemed to be in every other car?
                      How are you liking that Turner pedal set? I am thinking of acquiring some for myself.
                      • V
                        V
                        vbhargava
                        I hope not but probably
                        • V
                          V
                          vbhargava
                          I love them. I really wanted a low key look and some added traction / surface area and these fit the build perfectly... especially in black. Contact @patsbimmer1 for help sourcing.
                          • V
                            V
                            vbhargava
                            Work in progress by @jcw0101 but its coming together!
                            • V
                              V
                              vbhargava
                              Since we have the exhaust apart it seems like a good opportunity to hear it w/open headers.
                              IMG_9242.mov
                              • V
                                V
                                vbhargava
                                Finally got a hold of some OEM wheels. Still cant believe I ran through the rear tires in 6k miles. 😂
                                  You are doing it right
                                  • V
                                    V
                                    vbhargava
                                    After all the work last summer the car needed an alignment and KMR did a great job. Looking forward to getting out and testing it on the backroads soon.
                                    • V
                                      V
                                      vbhargava
                                      A little something something to hold me in the seat better on backroads.
                                        I need reviews!
                                          I need reviews!
                                          I second this motion
