  4. Madison - E39 M5 - Thread
53 Posts 11 Posters 0 Views 1 Watching
    Welcome! I love the E39 M5's. Im also in the Madison area and will keep a look out for you!
    • V
      V
      vbhargava
      TehRaydarlover said:
      Looks nice! Yeah, cam position sensors are a pain! Let me know if you need any help when you decide to tackle rod bearings haha.
      huh...at what point should I consider doing the rod bearings?
      • V
        V
        vbhargava
        i_love_cars said:
        Every time I see these cars I want to buy one. E39 M5 looks so good.
        Now is the time. Nice ones are becoming harder to find and more $$$. Plenty of project version available cheap too.
        • TehRaydarloverT
          TehRaydarloverT
          TehRaydarlover
          You're probably okay for a while at 100k. just something to keep in mind if you ever have the upper oil pan off for some reason. These were mine after 154k:
          Old bearings are all out and new WPC treated ones are in 🖒
          Cylinder 8 bearing definitely looks the worst, but minus the first two cylinders they all look pretty worn, very glad I decided to change them.
          • V
            V
            vbhargava
            Looking forward to seeing you around Madison. I just bought an E30 that I'll post about shortly.
            • V
              V
              vbhargava
              Finally got around to getting the car paint corrected and detailed.
                I love it!
                  Paint looks great!
                  • V
                    V
                    vbhargava
                    Minor update: Went to install a shark injector tune to find out that it already has a tune on it. Not sure what it is but certainly explains the excessively sensitive throttle response
                      Well thats a nice surprise!
                        This is still probably one of the best cars BMW ever made
                        • V
                          V
                          vbhargava
                          Finally got both Bimmers out at the same time
                          • V
                            V
                            vbhargava
                            Headed over to Accumoto for a suspension consultation. Ended up raising the car 1 inch all around for a more comfortable daily ride and less twitchy backroads experience. Car is feeling much better and just needs to go back for an alignment next week.
                              Accumoto is a cool place, that E36 is fresh!
                              • V
                                V
                                vbhargava
                                New pedals and windshield washer pump! Pretty simple but taking off the wheel well liner can be a pain.
                                  What pedals are those/where can I get some?!
                                  love it!
                                  • V
                                    V
                                    vbhargava
                                    love it!
                                    Turner Motorsports but bought through ECS. Contact @patsbimmer1 to order ECS parts at a good price.
                                    My only piece of advice for the install is to make sure you have good sharp drill bits. I went and bought new ones near the end and it would have saved me at least 1 hour. #facepalm
                                    • V
                                      V
                                      vbhargava
                                      Finally out of hibernation:
                                      Todays projects:
                                      • cabin air filter change
                                      • windshield seal
                                      • new cowl fasteners
                                      • V
                                        V
                                        vbhargava
                                        Summer plans:
                                        • rear subframe bushings
                                        • coolant overflow reservoir
                                        • bluebus bluetooth module (https://www.bluebus.dev/)
                                        • accumulator upgrade
                                        • V
                                          V
                                          vbhargava
                                          Two small projects down:
                                          Got the car back on the road after upgrading the pressure accumulator and coolant reservoir.
                                          IMG_8958.mov
