I haven't updated this in awhile, but I figured I could do a check in.
I have a mound of parts to install in this car and haven't had time to touch it. BUT since Halloween is right around the corner, I might need to get this thing on the road again, as it's perfect for the holiday.
I did manage to finally find a cam that I will use with the gear drive. It's a Comp cams camshaft spec'd at 236/242, .363"/.361" lobe lift and cut on a 111+4 lsa. I am not 100% if it will work, but I mean, what's the worst thing that could happen?
They make more valves every day.
FACT.
Updates without pics are like.....well, I don't know what they are like, but they suck. Do better.
I agree. I will do better next time.
Just for @REKIII I started this for the first time in many months. It made the craziest noises from the fuel tank, but fired right up first try. It was slightly motivating
(Note the pile of parts on the roof waiting to be installed)
And the video isn't uploading
Can't do better due to technical difficulties. -
Can we expect to see this at RA again?
I cant make any promises.
Can we expect to see you at RA again?
smoke machine?
See last response;
smoke machine?
Did a thing last night and its closely relates to this car. Some of you may have already saw this posted on my snapchat (jhenrysnapp if you're a snapchatter) yesterday, but I have been cleaning and moving things in my shop and decided to get the old tires off of the spare style 5's and mount the new tires on. There is still a large amount of work to be done before I can actually mount the wheels on the car, but I was able to remove the tires, and install the new ones and flip the faces and the outcome was quite satisfying.
OEM back pad and barrel Flipped face and semi cleaned barrel New tire installed on flipped face wheel
A video of the wheel next to the car:
bruh
Im sorry, is there something wrong?
how did you attempt to center the face? that could be a lot of wobble with such a heavy tire!
It self-centered 🤪
It self-centered 🤪
i've had a set of these in hand and thought it might be iffy, since the centering lip is on the face side, and the splined bolts are a loose fit into the holes on the face. did you mount the wheels on the car and give em a spin to check for run out?
I know what you mean about the lip on the front of the face, BUT the overall diameter of the face also fits tightly inside of the barrel. So tight, I had to pound it back together with a 6x6 and all my might to get it tight. If you look, you can see I left the bolts in their place so that the nuts are on the "new face side." I did this because the bolts are splined, tapered, shouldered, and press tightly into the barrel before passing through the face. Leaving them in this orientation was the best (technically only) option for a secure hold, and the shouldered portion of the bolts also aided in alignment of the face. I did not mount them on the car, BUT I did mount them on my tire balancer to testy runout and they spin true for the most part, but the tire is a hell of a lot of meat, and I might run balancing beads instead of wasting a ton of sticky weights.
(Sorry for portrait mode, this is from snapchat) UIJW7639.MP4
nice! i thought that there was a gap around the face from the barrel, but I'm probably mistaken.
these will be hilarious when mounted. please put a cat or a $100 bill inside the barrel to exaggerate the size of the lip, like when deep flat lips were a thing.
