726 Posts 28 Posters 9.6k Views 2 Watching
    Well.... Baby update. I have not done much to the car itself, due to a massive of list of other things that take precedent,  BUT I did finally find a set of aggressive tires that "might" fit.
    Image result for 245/75/17 duratrac
    245/75R17's that will fit on the flipped style 5's.
    I know its very late in the winter season, but anytime, is better than no time to enjoy a lifted anything. I hope to mount and test fit overall offset before I actually lift the car. If I can get away with a 1" spacer and not cut into the chassis, I will be stoked.
      Just in time for muddin’ Season
        'notha update-
        I made a trip out to FDL yesterday and Got another set of swing arms, axles, and sub frame from @Sam_Holzmann
        I also got a nice surprise before leaving to pick up the parts. A nice size puddle of coolant under the car. It looks like the cheap radiator that is in it finally failed.
        Next up, I will be mounting the new tires to wheels and test fitting with pics.
          in for jumping video.
            Damn. Now that's two videos I need to complete. Burnout with @Earl on the couch, and a jump. Maybe I could combine them?
              'notha update-
              Sorry to hear. The 8 hours a day I am here is enough for me.
                If you mount a set of seatbelts I would definitely be down for a combo=)
                  Image result for excited gif
                    I learnt something a few days ago. E36 M's came with two different axles.
                    96+ with larger lighter hollow axles, previously the older style is a non-hollow solid shaft. Both interchange but have obviously different part numbers.
                      I haven't updated this in awhile, but I figured I could do a check in.
                      I have a mound of parts to install in this car and haven't had time to touch it. BUT since Halloween is right around the corner, I might need to get this thing on the road again, as it's perfect for the holiday.
                      I did manage to finally find a cam that I will use with the gear drive. It's a Comp cams camshaft spec'd at 236/242, .363"/.361" lobe lift and cut on a 111+4 lsa. I am not 100% if it will work, but I mean, what's the worst thing that could happen?
                        They make more valves every day.
                          Updates without pics are like.....well, I don't know what they are like, but they suck.  Do better.  😉
                            FACT.
                              I agree. I will do better next time.
                                Just for @REKIII I started this for the first time in many months. It made the craziest noises from the fuel tank, but fired right up first try. It was slightly motivating 😁
                                (Note the pile of parts on the roof waiting to be installed)
                                And the video isn't uploading 😦 Can't do better due to technical difficulties.
                                  Can we expect to see this at RA again?
                                    I cant make any promises.
                                      Can we expect to see you at RA again?
                                        smoke machine?
                                          See last response;
                                          smoke machine?
                                          Image result for smoke machine gif
