726 Posts 28 Posters 9.6k Views 2 Watching
    'notha update-
    I made a trip out to FDL yesterday
    Sorry to hear. The 8 hours a day I am here is enough for me.
      Damn. Now that's two videos I need to complete. Burnout with @Earl on the couch, and a jump. Maybe I could combine them?
      If you mount a set of seatbelts I would definitely be down for a combo=)
        Image result for excited gif
          I learnt something a few days ago. E36 M's came with two different axles.
          96+ with larger lighter hollow axles, previously the older style is a non-hollow solid shaft. Both interchange but have obviously different part numbers.
            I haven't updated this in awhile, but I figured I could do a check in.
            I have a mound of parts to install in this car and haven't had time to touch it. BUT since Halloween is right around the corner, I might need to get this thing on the road again, as it's perfect for the holiday.
            I did manage to finally find a cam that I will use with the gear drive. It's a Comp cams camshaft spec'd at 236/242, .363"/.361" lobe lift and cut on a 111+4 lsa. I am not 100% if it will work, but I mean, what's the worst thing that could happen?
              They make more valves every day.
                Updates without pics are like.....well, I don't know what they are like, but they suck.  Do better.  😉
                  FACT.
                    I agree. I will do better next time.
                      Just for @REKIII I started this for the first time in many months. It made the craziest noises from the fuel tank, but fired right up first try. It was slightly motivating 😁
                      (Note the pile of parts on the roof waiting to be installed)
                      And the video isn't uploading 😦 Can't do better due to technical difficulties.
                        Can we expect to see this at RA again?
                          I cant make any promises.
                            Can we expect to see you at RA again?
                              smoke machine?
                                See last response;
                                smoke machine?
                                Image result for smoke machine gif
                                  Did a thing last night and its closely relates to this car. Some of you may have already saw this posted on my snapchat (jhenrysnapp if you're a snapchatter) yesterday, but I have been cleaning and moving things in my shop and decided to get the old tires off of the spare style 5's and mount the new tires on. There is still a large amount of work to be done before I can actually mount the wheels on the car, but I was able to remove the tires, and install the new ones and flip the faces and the outcome was quite satisfying.
                                    OEM back pad and barrel                                                  Flipped face and semi cleaned barrel                          New tire installed on flipped face wheel
                                  A video of the wheel next to the car:
                                  PLFW0312.MP4
                                    bruh
                                      bruh
                                      Im sorry, is there something wrong?
                                        how did you attempt to center the face? that could be a lot of wobble with such a heavy tire!
                                          It self-centered 🤪
