M20 Turbo => M50 turbo fun.
if you are like this guy and know what you are doing
you could have yourself a reliable turbo m20 with little lag that screams on the track.
A turbo M50 will make a little more power with less boost than an M20 and might be the better choice if you want to keep the internals stock.
If it were me I would probably do the M20 just because I feel that if the heat of the turbo caused a cracked head or if the bottom end blew out, another healthy M20 engine could be dropped in for hardly anything.
I never even caught your name!
Lol, I don't know if that was a good thing or bad!
I'm set on the m50 turbo now, so have no fear!
I'm a little late on this post but, a stock m20 with stock head gasket, ARP's, stock intake manifold, and hx35 12cm will easily give you 400+ whp (with a good tune)...
It's proven to handle 1 bar (350whp) all day long.
If you grenade it, no big deal.
Also, TB size doesn't really matter when FI. Most either o-ring or weld, m20's weak point is the head gasket pushing out into the coolant channel. Specifically cylinder #6 (hottest). Unless you plan on detonating, you wont get far.
GL with your new m50.
M20 on a stock head gasket will not make 400HP, nor will one without built internals, they take a little bit of boost alright but they don't make much power per lb of boost.
Not trying to thread jack OP I'm also not sure if it's against the rules to link another forum but here goes...
Here is just one instance. I know he isn't using the stock head gasket but he is using shitty MB head bolts AND stock internals...93 octane.
Stock motor w/ 208k miles.
head was rebuilt @ 185k (valve job minor port cleanup stock cam/springs)
Metrick Blue bolts and Cometic MLS
boosted for over 20k.
437whp/380ftlbs on 20psi
http://www.e30tech.com/forum/showthread.php?t=112167
This thread has a couple turbocharged m20's (with dyno charts) slightly different setups. A lot of them have stock m20's pushing 400whp easily.
http://www.e30tech.com/forum/showthread.php?t=113066&highlight=m20+turbo+dyno&page=2
It's been done and proven...
Again OP, GL with your build.
Rules? What rules?
We're all about spreading the knowledge, thanks for sharing the links. Those are impressive numbers. Would like to see some videos of those cars in action. -
M20B27eta said:
Rules? What rules?
We're all about spreading the knowledge, thanks for sharing the links. Those are impressive numbers. Would like to see some videos of those cars in action.If you read BobRoss' thread he has plenty of dyno and street kill vids
. Here: http://www.e30tech.com/forum/showpost.php?p=1307822&postcount=65 -
M30 turbo>M20. Just saying. I know you got your M50 with big penor power. But either way.
Dat shit cray
Im totally not against m20's in anyway, and I'm totally open to constructive thread jacking. Thanks funny. I had an hx35 12cm and literally everything else to turbo my m20, but for some reason, I went m50. I think basically because for the future, I want to be making big power, and I think that the m50nv is a pretty good base to start? I also like higher revving engines. Welding my head+Oring was over 400$ at my machine shop. Not only that, but I had to pull the engine anyway, so why not buy an m50 for 300$? All i have to do is arps, and mls for a decent 400. I dont know. I'm not saying anyone was right or wrong.
A LOT of other stuff goes with putting in a turbo, I have a pretty good link selection going on right now for all the feed lines, oil blocks, return lines, fittings, injectors, all kinds of crazy freaking suff.
If you have any questions with the swap or anything else for that matter do let me know, I have done it a few times now
The only thing i have left to buy is intercooler piping, oil feed(I have the fittings), do i need to relocate the oil filter? Most people did with m20's. And i have to hook up my oil cooler. Thats about it. and buy mounts and stuff.. I will definitely let you know though
