    I'm coming over son.
      Your logic is definitely sound.
      It would be silly to try and say the M20 is a better engine than the M50 but I think the point at which my jimmies become rustled is when someone has an M20 in a poor state of tune (see also too cheap to hunt down vac. leaks and replace old parts) swaps in a junkyard M50 and pretends the M20 was a total un-fixable pile and the M50 is a rocketship, when in reality, a tune up would have likely yielded the same performance increase.
      One thing to keep in mind about the M20, is that in NA form, it was a very highly optimized engine for its day. The LS1 is praised for being such an optimized engine with only 2 valves per cylinder, but when you do the math, the M20 has a specific output very close or equal to that of the LS1 (depending on the version of LS1) and that is with an archaic EFI system and relatively low compression ratio. Being reasonably optimized means that there is not a whole lot to gain unlike a 350 chev with 190 hp which gains 100hp with a carb, manifolds, and a cam.
      So yes, the M50 is a more advanced engine, has more area under the torque curve, is more refined, and capable of making more power with less sacrifice down low, but the M20 aint a bad gig either, especially when the cost of replacement is so low, especially when your snail-obsession gets out of hand.
        Thanks for the input. If you were me, would you do the swap? I want to be drifting with this car, and also track days. Around 350whp or 400bhp. Trying to keep it semi reliable.
          if you are like this guy and know what you are doing
          you could have yourself a reliable turbo m20 with little lag that screams on the track.
          A turbo M50 will make a little more power with less boost than an M20 and might be the better choice if you want to keep the internals stock.
          If it were me I would probably do the M20 just because I feel that if the heat of the turbo caused a cracked head or if the bottom end blew out, another healthy M20 engine could be dropped in for hardly anything.
            badass!
              Aaah. So I have to pay 800$ for my sisters laptop to be fixed. I really need some persuasion. Is there any stock piston/rod/crank setup that would get me some damn low cr? Like around 7? Still might go m50 but I don't know yet.
                That blow off valve in the video, sounds queer as fuck.
                @ Mitch, good job dipshit! I might be up next week. I'll keep you posted.
                  Little update. Bought a m50nv. 130k on it supposedly. Need to track down an oil pan and stuff. Also sold my hx35 to GunMetalGrey, and he gave me a swap brace. Pretty excited. Cool dude.
                    I never even caught your name!
                      so whats the plan now? Between you and Ben its hard to keep track! Y'all change motor ideas every other day :P
                        Lol, I don't know if that was a good thing or bad!
                        I'm set on the m50 turbo now, so have no fear!
                        • N
                          N
                          Nick_08
                          I'm a little late on this post but, a stock m20 with stock head gasket, ARP's, stock intake manifold, and hx35 12cm will easily give you 400+ whp (with a good tune)...
                          It's proven to handle 1 bar (350whp) all day long.
                          If you grenade it, no big deal.
                          Also, TB size doesn't really matter when FI. Most either o-ring or weld, m20's weak point is the head gasket pushing out into the coolant channel. Specifically cylinder #6 (hottest). Unless you plan on detonating, you wont get far.
                          GL with your new m50.
                            M20 on a stock head gasket will not make 400HP, nor will one without built internals, they take a little bit of boost alright but they don't make much power per lb of boost.
                            • Ryan...R
                              Ryan...R
                              Ryan...
                              If he's got the same car as I last remember, Nick's been running a boosted M20 for some years now. I dont remember the details anymore, but I almost bought a kit off him in like 08 for my bronzit sedan :D
                              • N
                                N
                                Nick_08
                                Not trying to thread jack OP I'm also not sure if it's against the rules to link another forum but here goes...
                                Here is just one instance. I know he isn't using the stock head gasket but he is using shitty MB head bolts AND stock internals...93 octane.
                                Stock motor w/ 208k miles.
                                head was rebuilt @ 185k (valve job minor port cleanup stock cam/springs)
                                Metrick Blue bolts and Cometic MLS
                                boosted for over 20k.
                                437whp/380ftlbs on 20psi
                                http://www.e30tech.com/forum/showthread.php?t=112167
                                This thread has a couple turbocharged m20's (with dyno charts) slightly different setups. A lot of them have stock m20's pushing 400whp easily.
                                http://www.e30tech.com/forum/showthread.php?t=113066&highlight=m20+turbo+dyno&page=2
                                It's been done and proven...
                                Again OP, GL with your build.
                                  Rules? What rules? :rolleyes: We're all about spreading the knowledge, thanks for sharing the links. Those are impressive numbers. Would like to see some videos of those cars in action.
                                  • N
                                    N
                                    Nick_08
                                    If you read BobRoss' thread he has plenty of dyno and street kill vids ;). Here: http://www.e30tech.com/forum/showpost.php?p=1307822&postcount=65
                                      http://youtu.be/KU3hKNWCy8c
                                      M30 turbo>M20. Just saying. I know you got your M50 with big penor power. But either way.
                                        Dat shit cray
                                          That m30 fuckin rips. And sounds amazing
