561 Posts 19 Posters 6.3k Views 1 Watching
  • Brian.B
    Brian.B
    Brian.
    lol, ebay clutches.
    instagram @howdoyoudrivethat
      Looks like your flywheel may be off to the machine shop for some more material removal and balancing.
        Brian said:
        lol, ebay clutches.
        lol....not
        Some ebay clutches are actully decent. Especially for the price. I know XTD makes a decent clutch for the price. Just because something is sold on ebay, doesn't mean it is junk. Look at Condor Speed Shop.
          damn. That means I have to get new flywheel bolts also, no?
            lol....not
            Thank you sir. I did my research on this and a ton of people are running F1 clutchs on bmw's with success. The only downside I have seen is clutch chatter, which I could care less about.
              Flywheel bolts are TTY (torque to yield) and need to be replaced each time they are torqued to spec then removed. Sure, you can re-use them, but if they back out 500 miles after everything is back together then it would be incredibly annoying to have to do the job over, while risking damage to the transmission from a loose clutch assembly/flywheel flailing about within the confines of the bellhousing.
                GOD DAMNIT. Thanks, But that blows. They were like 30$.
                  Screw it. I looked it up and a whole bunch of people have reused them. Ill put some loctite on there for some piece of mind ;)
                    dont screw it up
                      dont screw it up
                      That was hilarious. me gusta. I promise I won't ;)
                        Had a real night day today. Taking the flywheel to the machine shop tomorrow hopefully, and getting the back shaved
                        Down and hopefully lightened a bit.
                        Ripped the dash out.
                        8A70C9A2-1947-40AE-9A22-98499205441F-106
                        Anyone have a hint for getting the fuse box through/getting the wiring out some how?
                        523F6571-711B-4B67-8B40-28F3DDAAD483-106
                        When we tore the carpet out we found some rust. I will be cutting basically that whole piece out and welding in a new sheet.
                        Anyone have opinions on a dash? What about fitting a couple bent street signs and mounting them and putting the stock gauges and stuff back in?
                        That is all till Saturday probably.
                        • JeffJ
                          JeffJ
                          Jeff
                          I too had floor herpes once upon a time:/
                          1976 530i e12
                          1990 325ix e30
                          1992 325i e36
                          1995 740il e38
                          2001 330xi e46
                          ^More to come :)
                            It sure sucks. Whatever. I like welding and such activities.
                              Herpes is for life man
                              • JeffJ
                                JeffJ
                                Jeff
                                Damn:( I tried cutting them off too
                                1976 530i e12
                                1990 325ix e30
                                1992 325i e36
                                1995 740il e38
                                2001 330xi e46
                                ^More to come :)
                                  ouch
                                  • JeffJ
                                    JeffJ
                                    Jeff
                                    ouch
                                    it was quite messy
                                    1976 530i e12
                                    1990 325ix e30
                                    1992 325i e36
                                    1995 740il e38
                                    2001 330xi e46
                                    ^More to come :)
                                      mind-blown.jpg?w=412
                                      Removing the ring off the backside of the flywheel should get the flywheel weight  from 18.5 lbs to roughly 14 lbs. Its a nice way to help your acceleration a bit since the rule of thumb is that removing dynamic mass has about the same impact on performance as removing 2-3 times the static mass. So it would be like removing 10-15 lbs from the car.
                                      But nevermind the flywheel lightening, because from the looks of it, your car is trying to lighten..... itself.
                                        LOL. "Had a real NICE day today." Is what it was supposed to be. I just hope it doesn't cost too much. I always wanted a lightened flywheel anyways. And maybe he can get me some dowel pins.... We whipped out the heat gun last night and got high off all the tar. Wait.. I mean we removed the tar. It sucked. But the car is getting lighter and lighter every day. Real fun.
                                          How long did it take to get the trunk tar out? I got lucky. I peeled all mine up by hand in large chunks in about 5 minutes.
