561 Posts 19 Posters 6.3k Views 1 Watching
    snap oversteer said:
    No love for the crab manifold (m20) anymore?
    maybe tomorrow. m5x's just look sexier ;)
      Someone please find me some motor mount arms. Anyways, how many dowel pins do I need for the flywheel?
        Looks like (3) of one style and (1) of another
        http://realoem.com/bmw/showparts.do?model=HD53&mospid=47404&btnr=11_4817&hg=11&fg=20
          My flywheel is from an m20! Supposedly a single mass from an e. I'll try to find it.. Thanks for the site though!
            Did you get the back side of the flywheel machined down for proper fitment? What clutch are you using?
            Yes, use REALOEM.com, just make sure to click "archive' to find e30 stuff
              Damn. I might have done this wrong.
              Does this look like not enough room?
              4E965E0B-A24F-40A2-9513-10D3C19870A3-789
              7CEF705F-9A4A-4C56-86D1-F8E0D1AB3ED7-789
              Some 6 puck eBay clutch. Supposedly got good review.
              D2ACEE8C-F98D-42CF-B1C1-F09231BE912F-789
                lol, ebay clutches.
                  Looks like your flywheel may be off to the machine shop for some more material removal and balancing.
                    Brian said:
                    lol, ebay clutches.
                    lol....not
                    Some ebay clutches are actully decent. Especially for the price. I know XTD makes a decent clutch for the price. Just because something is sold on ebay, doesn't mean it is junk. Look at Condor Speed Shop.
                      damn. That means I have to get new flywheel bolts also, no?
                        lol....not
                        Thank you sir. I did my research on this and a ton of people are running F1 clutchs on bmw's with success. The only downside I have seen is clutch chatter, which I could care less about.
                          Flywheel bolts are TTY (torque to yield) and need to be replaced each time they are torqued to spec then removed. Sure, you can re-use them, but if they back out 500 miles after everything is back together then it would be incredibly annoying to have to do the job over, while risking damage to the transmission from a loose clutch assembly/flywheel flailing about within the confines of the bellhousing.
                            GOD DAMNIT. Thanks, But that blows. They were like 30$.
                              Screw it. I looked it up and a whole bunch of people have reused them. Ill put some loctite on there for some piece of mind ;)
                                dont screw it up
                                  dont screw it up
                                  That was hilarious. me gusta. I promise I won't ;)
                                    Had a real night day today. Taking the flywheel to the machine shop tomorrow hopefully, and getting the back shaved
                                    Down and hopefully lightened a bit.
                                    Ripped the dash out.
                                    8A70C9A2-1947-40AE-9A22-98499205441F-106
                                    Anyone have a hint for getting the fuse box through/getting the wiring out some how?
                                    523F6571-711B-4B67-8B40-28F3DDAAD483-106
                                    When we tore the carpet out we found some rust. I will be cutting basically that whole piece out and welding in a new sheet.
                                    Anyone have opinions on a dash? What about fitting a couple bent street signs and mounting them and putting the stock gauges and stuff back in?
                                    That is all till Saturday probably.
                                    • JeffJ
                                      JeffJ
                                      Jeff
                                      I too had floor herpes once upon a time:/
                                      1976 530i e12
                                      1990 325ix e30
                                      1992 325i e36
                                      1995 740il e38
                                      2001 330xi e46
                                      ^More to come :)
                                        It sure sucks. Whatever. I like welding and such activities.
                                          Herpes is for life man
